SteveShannon
    464
  1. Wrong. 95.305(e) No person is authorized by this section to operate a United States Government Radio station. 95.1705(a) Eligibility (1) Individual licensee (2) Licensee’s family (3) Licensee May allow anyone to communicate an emergency message (4) Grandfathered licensees (which includes governmental units allowing its employees). So, no, there’s no current way for a government unit to setup and operate a repeater. I greatly abbreviated the sections above, but I don’t think that changed the conclusion.
  2. That sounds perfect!
  3. I don’t know what power you’re outputting, but you’re probably not going to be transmitting at a high duty cycle. I assume you’re not going out on the boat to talk on the radio. If you put the radio onto a mast you’re in even better shape. I would be sure and get some oxide preventing compound to put between all the metal pieces. Any electrical supply store or even Ace or Menards should have it. Aluminum oxidizes very quickly and aluminum oxide is very hard and non-conductive. Then, when you’re ready to attach the bracket, sand the contacting surfaces and apply the oxide preventative before attaching them together.
  4. This sentence made me think you owned the repeater: Those repeater output channels are available as FRS channels as well. It’s entirely possible they’re doing everything by the book.
  5. I see three in Long Island
  6. That one is only 19 ga. thickness. It’s meant to be attached to a fiberglass roof. A cookie sheet, pizza pan, or pie plate like this will work: 10 Inch Round Pie Pan for Baking, Aluminum Commercial Grade Pie Plate by Tezzorio https://a.co/d/2fHKb9h Don’t let us convince you that the size is too critical. These antennas are typically fastened to a metal roof of indeterminate size. Also you’re on the water. That’s just perfect in terms of terrain. I’ve never put an antenna on a boat, and I don’t know what your boat is like or what it has for mounting, but do whatever is easiest. Edit: I told I’d never put an antenna on a boat. It appears that for marine applications the body of water serves as the ground plane. I really don’t know how you take advantage of that.
  7. Maybe it’s one of those “if you build it they will come” things. ? Although I have 146.520 programmed into my radios, the few times I’ve left the frequency there I’ve heard nothing. Of course that is here in Montana and doesn’t reflect congested urban areas.
  8. Welcome to MyGMRS. Please tell us about yourself and the requested antenna. Is it for GMRS? Do you have access to any materials which might be used to build yourself a J-pole or 1/4 wave ground plane antenna? I’d be happy to post links to DIY videos? Could you use a mobile antenna? What is your mounting situation? Do you have feedline already or is that part of the request? No matter what, best wishes to you!
  9. I completely agree.
  10. I hadn’t heard about it either. Is it really a thing? What kind of adventure comes with the frequency? ?
  11. So, you’re intentionally overpowering the transmissions of others (at the local store/business) on the same frequency? Why not simply move to a different frequency?
  12. Agreed. This is a case where non-compliance is harmless as long as the person using the radio is acting responsibly. But for people who worry about strict compliance with the letter of the regulations, having it spelled out may help.
  13. This!! Two of the Radioddity DB20G radios with one configured for GMRS and the other opened up to the ham bands and there’s not even a question about compliance.
  14. 1. Make sure you have the correct driver for the cable you’re using. Win 11 changed the model for drivers and manufacturers had to come up with new drivers. 2. Then just use the software that the manufacturer recommends for the radio.
  15. https://www.acehardware.com/departments/plumbing/pipe-fittings/test-plugs but every plumbing supply place should stock them.
  16. When you’re looking at the information for a repeater, the Input tone is the tone your radio must transmit to the repeater. The Output tone is the tone the repeater transmits, and which your radio receives. At first, you’re probably better off leaving it blank. That will allow you to hear everything. Once you know your transmissions are being received by the repeater, then you can add a receiver tone to match the repeater‘s Output tone.
  17. That’s right! once it’s working like that you can decide whether you want to put a tone on receive. With the tone left blank you will hear everything transmitted on that frequency. With the receive tone set to 88.5 you’ll only hear transmissions that are sent using a tone of 88.5. i always leave receive tones blank until I’m sure.
  18. Yes, the repeater listens on a 5 MHz higher frequency than it transmits. The setting for REPT15 is correct. If you don’t transmit on 467.550 there’s no chance the repeater will hear your transmissions Set your output tone to 88.5 Hz, but for now leave your receive tone blank. That way you’ll receive everything transmitted on 462.550
  19. Current FRS radios do not transmit on the 467 MHz repeater input frequencies, but they are allowed to transmit on the repeater output frequencies. So you might not be able to tell them apart. That doesn’t mean they’re in violation. The frequencies are simply shared.
  20. I’ve scratched the surface, but that’s all. I bought one of the dongles also. I’m sure it isn’t the quality of my Yaesu transceiver, but for something the size of my index finger it’s amazing!
  21. I agree, Randy, that your work has truly helped spotlight a problem. I can’t pretend to understand all the moving parts, especially political in nature. I feel that the Salton Sea is just a symptom of a far greater problem.
  22. There are lots of GMRS transceivers which can receive on the amateur bands, but not transmit on them. Although people have found ways to “open up” transceivers to do what you’re asking, the rules for GMRS include this little nugget which is pretty specific: No GMRS transmitter will be certified for use in the GMRS if it is equipped with the capabilities to operate in services that do not require equipment certification, such as the Amateur Radio Service.
  23. I think you mean something like an Allstar node. On the store associated with this page there might even be a package deal.
  24. What a refreshing attitude. Don’t worry, we’ll change that! ?
  25. Yeah, sorry about that ?
