Hunter399
Hunter399's Achievements
  1. Just as an update, sent my radio in last week. Received the tested replacement and I get 48.7 watts. So that’s much better now!
  2. For those interested I sent my radio back to midland and they are gonna test the new one before sending back out. In talking with them they sent me their testing document. It’s Interesting to me you could potentially get a MXT400 and if you’re lucky have higher watts versus an unlucky MXT500 owner.
  3. I was debating if I needed to run a small ground wire from my NMO mount to my rack. I have no interference and get good SWR numbers. Probably my ocd kicking in. Would this even help? I assume it’s not needed in this case?
  4. Have they returned it and did the new one read higher? Debating returning mine as well
  5. I need to measure the volts better, I wasn’t thinking of the loss across how far the wire is i know the amps are spot on.
  6. So as long as my power going to the radio is correct I shouldn’t be concerned it’s only putting out the 40 watts?
  7. Due to not testing power with a dummy load?
  8. So I tested my amps and I am showing 7.5 amps at 14.6 volts. My electrical system runs higher volts for my agm batteries etc. so with the higher voltage I am within that 8 amp range discussed. Still only showing 40-41 watts, I’ll have to call as well.
  9. I’ll have to check my amps now as even though my MXT500 is installed on my tacoma I have it connected to a digital switch controller that measures amps, volts etc. I am only averaging 40 watts to the antenna as well. Rookie setup as I am new to this but figured I’d add some data
  10. I did reach out today and they are sending a new antenna. So I will test that new one when it arrives, for now just running around with the 6db on. If this new one doesn’t work I’ll try a laird one. I forgot to ask them regarding my 40 watt output. Are they sending you a new one? I don’t have a dummy load for testing, isn’t that the only accurate way to measure power or is through the antenna and wire ok?
  11. I assume if my swr is good on the other two antennas then my wire routing and location are good? Also, with the power reading at 40 or so watts on the other two antennas is normal? Off a 50 watt radio is that normal loss?
  12. Hey guys, I just received my SWR meter and ran some tests to check my antennas and triple check a good mounting location etc. My 6db antenna and the little 2.4db antenna included in the MXT500 box are both good at 1.00 to 1.01 across all frequencies. Now my midland ghost antenna, which I planned on being my primary antenna is showing 1.67 to sometimes 2.00 on some frequencies which is bad. Also noted the watts being higher. Is this a bad ghost antenna? pics included for reference. Thanks in advance.
  13. Thanks again for the help guys! So on my handheld KG-935G I keyed up and received a Morse code return. So I assume It worked! Just need to get my MXT500 setup
  14. I was confused by that as well. Setting up tones on my midland MXT500 is kinda a pain. Do you set 141.3 for both TX and RX I assume?
  15. Do you guys know if the shark fin on my truck. FM/GPS receiver would cause interference?
