WRUU653
    43
Everything posted by WRUU653
  1. The KG-S88G is UHF only, it's more basic but uses superheterodyne and has great quality, it's waterproof, and seems rugged in it's build. easy to program in the radio. Chirp is not available for it but if your a windows guy they have their own software. Great for GMRS coms, using on a jeep trip or kayak. No FM, no weather channels. The KG-935G is UHF and VHF receive, FM and weather channels. It's going to be better if you want to scan. Not a superheterodyne but still really good quality sound for TX and RX. It's not waterproof. both the new KG-935G Plus and the KG-S88G have USB charging but you'll have to remove a plate with screws for the KG-S88G because of the waterproof rating. I have both of these and I like them both. I keep the S88G programmed fairly basic and use it for GMRS coms, GMRS scanning and to take out in the world for talking. The 935G Plus is my go to if I want to scan and listen but still be able to communicate but it's not going in the boat with me or in the mud off roading. I hope this helps.
  2. Repeaters are required to identify. You have to read the whole thing. You do see where it says “if” don’t you? You can’t decide to stop reading something in its entirety and glean only the meaning you want. I mean you can but you’re still incorrect.
  3. I believe if the info from the repeater owner hasn’t been updated on mygmrs.com in over a year. We have one here that is still active but the owner needs to update on the site it would seem.
  4. How do you know they are on a repeater and not talking simplex?
  5. Incorrect. They are not required to ID if it’s only being used by people under the same license (family) and they identity with that call sign. That’s it, in all other scenarios the repeater must identify as far as the FCC rules are concerned. c) Any GMRS repeater station is not required to transmit station identification if: (1) It retransmits only communications from GMRS stations operating under authority of the individual license under which it operates; and, (2) The GMRS stations whose communications are retransmitted are properly identified in accordance with this section.
  6. I was wondering why more people don’t go with an antenna that doesn’t need a ground plane when one isn’t easily available.? Would it be safe to say all things being equal that an antenna with a ground plane is best? Also is there any benefit to a non ground plane type antenna in an application that does have a ground plane?
  7. I like the idea of controls on the mic as well. Retevis has one now also. I think it’s 20 watt. Looks like it has RX on the lower wattage 8-14 channels. Midland doesn’t bother to put them in since you can’t TX on them. I’m not ready to pull the trigger on the mobile yet, I’ve been just watching what comes out. I’m sure as soon as I’ve made a decision and purchase something new will come along ?
  8. You would still be able to communicate if you don’t have that. My understanding though it is better that your settings match those that you are communicating with for a clearer reception. I personally don’t have a separate set of programmed channels just for narrow band FRS settings but if you are talking with FRS radios (bubble packs) a lot I suppose it would make sense to have it if you got the room.
  9. ??? you got me man. Getting older myself. I hadn’t watched it in a while but I’m fairly certain if superheterodyne is what you want in a mobile the Wouxun radios are going to be the ones. Though I think solid and simple the Midlands have a good reputation though I don’t have one. Thanks for the laugh and thank you for your service.
  10. They don’t have one yet for that radio.
  11. And you’re right, you got to dig for Midland specs ?
  12. Well @buttholejim if that’s your name ? I do believe Midlands are SOC.
  13. I am unaware of a list of all GMRS radios of any organized fashion. You’ll have to go shopping ? but that’s the fun of it. 50 watts is going to be the max though for mobile/base radios.
  14. If you are in frequency mode you can scan frequencies for days. Even the GMRS frequencies/channels had to be added by someone somewhere and they are a specific set of channels/frequencies so easy to preload that. Just as you would add repeater programming for your area you can add local Ham frequencies. Adding will be easier with the software.
  15. You can but that’s a lot of scanning and if no one is there you wouldn’t know if you passed over a frequency used in your area. Best to put in what you want to scan.
  16. That’s a big 10-4 ?
  17. Check these for Ham frequencies near you http://www.interceptradio.com and https://www.radioreference.com then program them in like other frequencies you have added.
  18. Okay what I think is important from all the discussion here is that we start saying MURSY MURS ? No… just me then? Mursy, sounds like a 20’s gangster. ? I’m going, I’m going ?
  19. Cooperative use of GMRS stations. GMRS licensees may share the use of their stations with other persons eligible in the GMRS, subject to the conditions and limitations in this paragraph. (1) The GMRS station to be shared must be individually owned by the licensee, jointly owned by the participants and the licensee, leased individually by the licensee, or leased jointly by the participants and the licensee. (2) The licensee must maintain access to and control over all stations authorized under its license. (3) A station may be shared only: (i) Without charge; (ii) On a non-profit basis, with contributions to capital and operating expenses including the cost of mobile stations and paging receivers prorated equitably among all participants; or (iii) On a reciprocal basis, i.e., use of one licensee's stations for the use of another licensee's stations without charge for either capital or operating expenses. (4) All sharing arrangements must be conducted in accordance with a written agreement to be kept as part of the station records. I posted this in another thread here (a thread that must have gone sideways because it’s gone now?) but technically the FCC says you can’t charge fees for repeater use. Contributions yes. As for the question of using a repeater without permission. It’s equipment that belongs to another. Get permission.
  20. The black one, get the black one. No the one on the left… ? but seriously they are two completely different animals. Sure they’re both radios but it’s like saying should I get a Jeep or a motorcycle. I don’t know, what do you want to do? But as you have a license for one maybe that will inform your decision. You will need to figure out what it is you want to do with the radio. Or get both ?
  21. I didn't want to assume but I thought maybe she might. This guy made a video... No it's not that guy ? Yaesu FT-60 vs Wouxun KG-S88G | The Blind Radio Taste Test good luck with whatever you decide.
  22. To the best of my knowledge Yaesu and Elecraft don't make a part 95 approved radio (I'm not telling). Here is a little more on wide vs narrow though it's pretty much as @wayoverthere and @KAF6045 have explained. https://www.ailunce.comhttp//www.ailunce.com/blog/what-is-the-difference-between-narrowband-and-wideband-on-gmrs-radios
  23. My recollection on the Midlands is the MXT115 isn't wide band but the MXT400 is so I would go for the 400 over the 115. Someone who has these radios could tell you more.
  24. Hey John, the Baofeng UV-9G only transmits in channel mode. You can save as many GMRS channels as it will hold (127 I think) for different repeaters settings and what not but you can't transmit in frequency mode.
  25. I do have a recommendation though it’s over your $100 dollar budget ($139.99). The Wouxun KG-S88G is a super Het radio, UHF only, IP67 water proof. It’s pricey for its features but really good quality, good sound, solid, small and simple. I chose this as one of my HT radios because I wanted a radio that I could hand the wife that worked and wasn’t laden with a lot of bells and whistles that would intimidate her. I have other radios and other favorites for different things but for simple GMRS coms I reach for the KG-S88G. I may need to get another one. Hope this helps. Geez that souded like a commercial... I don't always drink beer but when I do... ?
