Guest Posted May 5 Report Posted May 5 I've got a repeater set up at my house. My antenna was damaged but I was able to fix it. I'm looking at replacing the antenna anyway. It's currently rated at 7.5db. I can get a comet that is rated at 9db for around 150 quid. I'm going to replace it either way, I'm just wondering if the extra DB and a half will make a noticeable improvement. I want to get the highest performing antenna I can under, say $200. It seems like there's an astronomical increase in price above 9db. The cheapest 10dbi can find is $2,000 it goes from $150 to $2,000. The antenna is mounted as high as I can get it and I've replaced the coax. I found a deal on 1/2 inch heliax. Quote
kidphc Posted May 5 Report Posted May 5 If your antenna is 100 feet in the air an additional 1.5 db might be worth it.As you increase db the antenna's radiating pattern on an omni-directional antenna gets flatter. It sends more of it signal to its horizon. I would recommend plugging the info into a one of the free typographical antenna coverage calculators to quickly ascertain if it is worth it. They changed this tool it seams. It use to allow you to map it out and set each site differently with gain and antenna values. This is what I use to recommend. https://www.scadacore.com/tools/rf-path/rf-line-of-sight/Have you thought about a yagi on with a TV rotator?Sent from my SM-S901U using Tapatalk WRYZ926 1 Quote
LeoG Posted May 6 Report Posted May 6 I have the 712efc and the paperwork that came with it claims 9.8dBi. It's on the bag and in the paperwork so that's what I assume it is. So it's even bigger than 7.2 Quote
nokones Posted May 6 Report Posted May 6 4 hours ago, WRXQ831 said: I've got a repeater set up at my house. My antenna was damaged but I was able to fix it. I'm looking at replacing the antenna anyway. It's currently rated at 7.5db. I can get a comet that is rated at 9db for around 150 quid. I'm going to replace it either way, I'm just wondering if the extra DB and a half will make a noticeable improvement. I want to get the highest performing antenna I can under, say $200. It seems like there's an astronomical increase in price above 9db. The cheapest 10dbi can find is $2,000 it goes from $150 to $2,000. The antenna is mounted as high as I can get it and I've replaced the coax. I found a deal on 1/2 inch heliax. Some times deals are not deals. What brand heliax are getting a such a deal on? Quote
WRKC935 Posted May 6 Report Posted May 6 Couple things to point out. dBi and dBd are two different values. dBi is going to be 2.5dB less than dBd. Because the dBd "d" stands for dipole. Which has 2.5dB of gain above a isotropic radiator. Which is the 'i' in dBi. I don't own the Comet that others have talked about. The circles I run in and company I keep gets me DB-408's and DB-420's for my stuff. Those of course are the 2K dollar antenna's you mentioned. But a guy in Columbus put one up on his repeater and it was a night and day difference between the 6dBi antenna he got with the repeater and that one. It probably added 5 to 10 miles of range or better to his repeater, all other things being the same. No change in mount height. Now, be aware that you can have too much gain if you have a lot of height. The realized gain in an antenna is accomplished in moving the radiation pattern. Think about it like a 100 watt lightbulb. If the light is going all directions, at all angles, no specific direction or angle gets any more light then another. To create gain, an antenna take the unused light radiating up and down and points in to the horizon. The more this is done, the higher the gain. When you get the gain high enough, there isn't much radiation down. So with a bunch of height, you overshoot the signal where you want it to go. Mind you it requires a LOT of height. But if you are on a mountain, and get a super high gain antenna, the valley below will NOT see much if any signal. Just be aware of that. Quote
Guest Posted May 6 Report Posted May 6 18 hours ago, nokones said: Some times deals are not deals. What brand heliax are getting a such a deal on? I admit I'm still learning but Andrew LDF4-50A kept coming up in Google search as the best option for UHF. I think the guy I bought it from is a tower worker of some sort. I suspect it's either something he took off a tower or is the end of a roll and was too short for them to use. Quote
Guest Posted May 6 Report Posted May 6 You all are giving me much to think about. Lots of good information. Thank you! I've been slowly trying to learn about DBI. It's a newer term, at least for me. I've always understood of DB of gain was compared to a dipole. But I guess DBI is a little different. Kinda sounds like antenna manufacturers are cooking the books to make their numbers look better. The comet CA-712efc is the antenna I'm currently looking at. It seems to have the best performance within my budget. I admit, the repeater is an inexpensive retevis. I was never impressed from day one, but come to find out the antenna that came with it was damaged from the factory. I've since repaired it and upgraded the coax. It's made a huge difference. I'm trying to squeeze as much performance out of it that I can. I'm upgrading here and there as the funds become available. I'm also learning what I can about antenna gain. I've come to understand more about the higher gain antennas having a flatter radiation pattern as others have mentioned here. I don't think I have enough height for that to be a problem. I'm in flat, flat kansas. I only have trees to contend with. I understand if it were a mountainous region, a lower gain antenna would help radiate upwards and downwards depending on the elevation of the antenna to the surrounding terrain. These are all things I've been piecing together in what little time I have to devote to the hobby, I'm sure you parents will understand. Again, thanks for all your advise. Quote
WRUE951 Posted May 6 Report Posted May 6 for an all around basic and fair cost base antenna, It's gong to be hard to beat a Tram 1486. The trick is to tune them correctly. WRYZ926 1 Quote
OffRoaderX Posted May 6 Report Posted May 6 49 minutes ago, WRUE951 said: It's gong to be hard to beat a Tram 1486. The trick is to tune them correctly Which is not only very simple, but the antenna is very forgiving, so it has a wide margin of error. WRUE951 and WRYZ926 2 Quote
WRYZ926 Posted May 7 Report Posted May 7 The few Tram antennas I have used or setup for others were all easy to tune. And the included instructions are good. I do use a Comet CA-712EFC and it has been a good antenna that has survived several storms with 50MPH + winds without issue. Quote
LeoG Posted May 7 Report Posted May 7 The 712efc is rated at 112mph. I'd be surprised if it could handle that. My SWR is between 1:1 and 1.01:1 across the entire band, including 467mhz repeater channels. I was amazed. Best I got with my other antenna was 1.15:1 at the optimum frequency. Quote
WRYZ926 Posted May 7 Report Posted May 7 I doubt that the 712EFC will stand up to 112 MPH winds either. We had winds high enough to blow down a 24-36 inch diameter maple tree on Easter Sunday. The winds were getting close to 70 MPH that day and my vertical antennas sure were dancing around. Quote
tcp2525 Posted May 7 Report Posted May 7 21 hours ago, WRXQ831 said: Now you're talking! There's only one Heliax and you got some. Beats the hell out of using that cheap LMR stuff. Quote
tcp2525 Posted May 7 Report Posted May 7 19 hours ago, WRUE951 said: for an all around basic and fair cost base antenna, It's gong to be hard to beat a Tram 1486. The trick is to tune them correctly. Yep, but you gotta feed it with Heliax for it to really wake up and perform. And if you want to get an extra 1.5db out of the 1486, you need to polish the brass elements with Brasso to a mirror finish prior to putting it in the radome. Quote
