  • 3
DB-20G now on Chirp
11 minutes ago, WRYS709 said:
PS: Why did you select this clunky "let's vote on each response" style of dialogue for this issue?!?  I find it distracting, annoying and downright unhelpful for reading a commentary on these issues!
I gave you an upvote for that.
I have done more testing but I get the impression that no one here would care.  And I don't see a pattern.
14 minutes ago, WRNC421 said:
Working just fine for me (see attached). Care to share a screen capture of the error? You can also submit a bug report using the Help menu.
OK, but it doesn't work for me!  There's not much to see on a screen capture - the lines are blank except for the channel number higlighted in red.  I looked at Dan's requirements for submitting an issue and I don't agree and will not be doing that.
53 minutes ago, UncleYoda said:
By quirky I meant how it works, such as keys to press (CTRL-BKSP instead of DEL), and that it tries to anticipate what to put in some columns based on what you enter in others, and that it doesn't show RX DCS when tones are same, and so forth.
Got it. Thanks for that clarification of "quirky".  Admittedly, I have not used many of the CTRL key sequence shortcuts so that may be why I've not experienced the same issues.
47 minutes ago, WRYS709 said:
Technically speaking some radios' CPS software is still required to be able to change certain non-Channel oriented settings that are not covered in Chirp and hence in those situations, I prefer the OEM CPS software for sure!
Vote on each response? Please explain. I'm not sure I follow. I didn't think I put a voting poll above the thread?  I saw the up down carrot on the left of each post. If that is something I added to this thread it was totally by accident.
Sort by vote is default for Technical Discussion section.  And it resets to that every time you open the topic.
Oh interesting, I've been using the forum for awhile and never realized this. Maybe I should have posted this thread somewhere else. My apologies.
Yeah: it is from the format you chose to use for your original post. I suspected it was inadvertent!
its a true PITA!
I avoid most of the threads that use this style, but I am committed to following up on DB20-G support.
On 6/7/2025 at 4:11 PM, UncleYoda said:
I mentioned one thing, regarding ch. 8-14, that might be different (don't know yet).
Chirp has been instrumental in helping “unlock” certain GMRS radios that come from the factory locked down to satisfy FCC requirements. The Baofeng UV-5X(G) comes to mind.
Since the DB20-G has an easy procedure from day one to “open” it using its keypad, using Chirp to enable transmission on Channels 8-14 is superfluous.
No it ain't!  (if it works)  You can keep all your other GMRS channels and (maybe) use those for something else, including the standard GMRS channels.
It is not clear to me what point of mine you are disagreeing with here.
I have previously linked to  a “GMRS” codeplug for DB20-G use consistent with Part 95E rules after “opening” the DB20-G.
Transmission on Channels 8-14 on a mini-mobile is NOT consistent with Part 95E.
44 minutes ago, UncleYoda said:
The part I quoted. (that should have been obvious)
It was not obvious because my statement is factually correct and yours is, at best, irrelevant!
Your making a statement about “features” of the DB20-G in Chirp that you admit you have not even tested!
But whether it works or not in Chirp, transmission on Channels 8-14 has been available on the “opened” DB20-G since Day One!
No need for testing in Chirp!
Furthermore, IMHO, transmitting on Channels 8-14 at 20 watts and/or Wideband FM, is morally reprehensible!
The ONLY time one should be doing that, if at all; is if they heard a weak signal on Channels 8-14 requesting EMERGENCY help!
Only in your mind.
Quote
I was commenting on the setting being available in the software.  It's there, that's it.  I will test it when I feel confident again in Chirp not messing the radio up.
Quote
You still don't understand that this is different than fully open.  Fully opening makes it a non-compliant radio.  Just putting in other GMRS frequencies at the appropriate power level does not.   But you can't seem to grasp the difference so I'm done with this.
  • -4
10 hours ago, UncleYoda said:
Chirp is quirky for DOS/Windows users.  Be sure to read the online help page.
It's definitely worth exactly what you paid for it. Why would anyone complain about free software?
