I have a pair of B-Tech GM-15 handhelds, and one of the screws fastening the belt-clip has been lost.
Can anyone tell me what size and thread-count is that tiny little screw, and where I could purchase one? It's far smaller than the smallest thing I can find at Lowes Home Improvement!
Or better yet, does anyone sell compatible replacement belt clips--with a stronger spring that doesn't allow the radio to come loose at the slightest jostling?
Thanks for any help!
6 answers to this question
I found replacement belt clips on Amazon saying they're compatible with the Baofeng UV-5R series. Can anyone confirm whether the screw hole placement on the UV-5R is the same as on the GM-15 PRO ? My GM-15 PRO unit measures 1 inch on center. They sure look the same, but I'm just trying to be sure before I commit to spending $.
Thanks!
Thanks!
No idea, but if the screw threads don’t match you’re screwed. Pun intended.
