nokones Posted 14 hours ago Report Posted 14 hours ago 3 hours ago, OffRoaderX said: Here is what will happen if you break the FCC rules and use a H.A.M.s Radios repeater without a license to talk with your friends. The helpful/socially adjusted licensed operators will likely inform you that you're breaking the rules and politely ask you to stop If you continue, "some people" will become very sad and complain very loudly and make baseless threats If you continue to continue, the local H.A.M. posse could initiate a fox-hunt - either the old fashioned way or by use of something like a KrakenRF which makes it very fast and easy to locate a transmitter Assuming you continue long enough for them to find you, now they know where you were transmitting from They could knock on your door - but this would be very ill-advised for them. At a minimum they would be trespassing if you tell them to STFU and leave as they have zero legal authority to do anything. At worst you could come outside and bitch-slap their fat-asses, call them names, make fun of their clothes, and make them cry. They could pull out the BIG GUNS and file a complaint with the FCC. But based on the FCC's number of enforcements over the last 15 years, there is a 99.9999998% statistical certainty that the FCC will do NOTHING It's a joke how so many of you clowns keep repeating these lies or insinuating that something horrible will happen if an outsider breaks your precious hobby's rules and THIS is exactly why so many normal-people make fun of you and your entire hobby. TL;dr: NOTHING OF CONSEQUENCE WILL HAPPEN. What would happen if a scofflaw pisses off the Sad Hams while mobile? Will these Sad Hams be able to pin point who this scofflaw is while driving around? Quote
OffRoaderX Posted 14 hours ago Report Posted 14 hours ago 7 minutes ago, nokones said: What would happen if a scofflaw pisses off the Sad Hams while mobile? Will these Sad Hams be able to pin point who this scofflaw is while driving around? Actually, yes.. If they are using a doppler type locator like the KrakenRF, it's fairly easy to do. I've done it myself. But again, the next question is "then what?" SteveShannon 1 Quote
nokones Posted 14 hours ago Report Posted 14 hours ago 12 minutes ago, OffRoaderX said: Actually, yes.. If they are using a doppler type locator like the KrakenRF, it's fairly easy to do. I've done it myself. But again, the next question is "then what?" Ok, so I can clearly understand this, if I was driving around and I key up for about 30 seconds and no more than 60 seconds and the Sad Ham's Kracken pin points my location at that time, and I am still driving down the Boulevard and I keyed again a 1/4 or 1/2 mile down the road for another 30-60 seconds, and key again briefly some distance away and then stop keying, how would this Sad Ham be able to figure out who I was after I stop keying? Just curious how would they be able to continue the tracking after the keying stops. I likely doubt that anyone could muster up a posse that quick and go search for the person that was just keying briefly a few times and stopped keying. Quote
OffRoaderX Posted 13 hours ago Report Posted 13 hours ago 58 minutes ago, nokones said: if I was driving around and I key up for about 30 seconds and no more than 60 seconds and the Sad Ham's Kracken pin points my location at that time, and I am still driving down the Boulevard and I keyed again a 1/4 or 1/2 mile down the road for another 30-60 seconds, and key again briefly some distance away and then stop keying, how would this Sad Ham be able to figure out who I was after I stop keying? Just curious how would they be able to continue the tracking after the keying stops. I likely doubt that anyone could muster up a posse that quick and go search for the person that was just keying briefly a few times and stopped keying. Two issues here: Mustering the posse and/or just getting the Kraken antenna array setup on the car and getting said car to your general location can take time -you could very well be long gone by then If you are SMART about it, keying only a few seconds at a time, then moving, it would be very difficult - if you only did it 2 or 3 times, it could event be impossible.. BUT - if you are having an ongoing conversation, even while driving or as in the case of the guy that I caught jamming one of our repeaters, continuously keying while driving, it gets easier. TL;dr: If you're smart, its nearly impossible.. If you're an idiot that thinks you are immune to being caught, it gets easier when using a Kraken. Luckily all of our repeater jammers have been idiots. Raybestos and SteveShannon 2 Quote
Raybestos Posted 12 hours ago Report Posted 12 hours ago 1 hour ago, nokones said: Ok, so I can clearly understand this, if I was driving around and I key up for about 30 seconds and no more than 60 seconds and the Sad Ham's Kracken pin points my location at that time, and I am still driving down the Boulevard and I keyed again a 1/4 or 1/2 mile down the road for another 30-60 seconds, and key again briefly some distance away and then stop keying, how would this Sad Ham be able to figure out who I was after I stop keying? Just curious how would they be able to continue the tracking after the keying stops. I likely doubt that anyone could muster up a posse that quick and go search for the person that was just keying briefly a few times and stopped keying. KrakenRF uses a unique technology which bends time and space to allow tracking of signals that were transmitted up to several days ago. By allowing repeated trips back to the time these transmissions were made, KrakenRF makes tracking of even single brief transmissions easy. WRTC928 1 Quote
nokones Posted 11 hours ago Report Posted 11 hours ago 1 hour ago, OffRoaderX said: Two issues here: Mustering the posse and/or just getting the Kraken antenna array setup on the car and getting said car to your general location can take time -you could very well be long gone by then If you are SMART about it, keying only a few seconds at a time, then moving, it would be very difficult - if you only did it 2 or 3 times, it could event be impossible.. BUT - if you are having an ongoing conversation, even while driving or as in the case of the guy that I caught jamming one of our repeaters, continuously keying while driving, it gets easier. TL;dr: If you're smart, its nearly impossible.. If you're an idiot that thinks you are immune to being caught, it gets easier when using a Kraken. Luckily all of our repeater jammers have been idiots. Thanks Randy. I hope you're doing OK and surviving since Cheetos shut down their local factory. Quote
amaff Posted 11 hours ago Report Posted 11 hours ago 6 hours ago, WRKC935 said: Here we go with the 'I need to mod my radio so I can talk to the Po Po, just in case." That's a gorgeous strawman you've built there lol No one (and definitely not in the post you quoted) was talking about public safety frequencies. WRXB215 1 Quote
WRTC928 Posted 11 hours ago Report Posted 11 hours ago 4 hours ago, Lscott said: I guess I should have explained it better. There is what the rules say, then there is what really happens in practice. There are all kinds of rules and even laws where breaches will be ignored or forgiven when it's done for a legitimate emergency. Which is a perfectly reasonable approach, IMO. Quote
OffRoaderX Posted 11 hours ago Report Posted 11 hours ago 31 minutes ago, nokones said: I hope you're doing OK and surviving since Cheetos shut down their local factory. Its been a struggle, but we will get through this difficult time. Quote
WRKC935 Posted 8 hours ago Report Posted 8 hours ago 2 hours ago, amaff said: That's a gorgeous strawman you've built there lol No one (and definitely not in the post you quoted) was talking about public safety frequencies. No strawman to it. It might NOT have been what you were referring to, but I can promise you that even today with statewide 700/800 radio systems the ARES guys STILL 100% believe that they should have access to that system and every analog public safety repeater on the air. And it's not just the ARES crowd. The number of average hams that 100% believe that little blurb in part 97 about 'any means at your disposal' means talking to the Po Po is completely acceptable and expected. I had this discussion with a couple hams about 10 years ago. They were adamant that was what it meant. I had to talk to the FCC on business related stuff and ask them as a side question about it and that is exactly what they said. Ham operators can use any HAM frequency in the ham allocation during an emergency. But that was it. They went further to state that modifying a Part 97 (ham) radio was against the rules and at no time should a part 97 radio be used on part 90 frequencies. They also said that even if they were using commercial part 90 radios, that without prior authorization being issued that they would be in violation. They emailed me all of this and I actually printed it out and had it laminated and would stuff it in the face of the hams that were convinced they were authorized by the regulation to talk to the public safety dispatchers on their channels, from their personal radios, if there was an emergency. I run into this about once a month. Someone will bring a radio into the shop they want loaded with public safety frequencies they got from radio reference. Half of the stuff isn't even on the air any more. Hell, some of it I pulled from service. We just tell them that they need letters from the fire chief / sheriff / someone on letterhead with an MOU and we will be happy to program them in. Without the MOU in hand they get nothing. gortex2 1 Quote
gortex2 Posted 2 hours ago Report Posted 2 hours ago Whats really sad is the amount of folks on this forum that encourage folks to break the rules. Regardless if its uncertified radios, using non gmrs frequencies like ham. Then on top of it it we tell folks dont worry no one cares or can do anything. What happened to be a stewardess of the hobby/service ? Lately this forum isn't much better than the prepper forums out there. WRYZ926 and WRXL702 1 1 Quote
