jfarr669 Posted Thursday at 08:47 PM Report Posted Thursday at 08:47 PM The lower wattage for handhelds was usually 5 watts at VHF and 4 watts at UHF and 3 watts for 700/800mhz. It is a RF exposure limit. Many public safety officials use a remote speaker/mic where the handheld/portable is still worn on the side of the body while transmitting. Anything more is considered "harmful exposure". You should stay about 3 feet away from a transmitting mobile radio with a mounted antenna, as most mobiles transmit at 15-50 watts, plus the antenna gain, if any. Quote
Lscott Posted Friday at 05:27 PM Report Posted Friday at 05:27 PM The attached papers give a bit more info on RF power exposure limits. This can get rather technical. Limits for Maximum Permissible Exposure (MPE).pdf CNIRP GUIDELINES FOR LIMITING EXPOSURE TO ELECTROMAGNETIC FIELDS (100 KHZ TO 300 GHZ).pdf SteveShannon 1 Quote
AdmiralCochrane Posted Friday at 09:20 PM Report Posted Friday at 09:20 PM It can get rather technical but 50 watts of non-ionizing radiation is 50 watts. Don't touch a 100 watt light bulb and don't hold on to a 50 watt bulb for too long. SteveShannon 1 Quote
nokones Posted yesterday at 01:41 AM Report Posted yesterday at 01:41 AM On 7/31/2025 at 9:28 AM, LeoG said: A fixed station transmits and received from another fixed station. It doesn't talk to mobiles or HTs. Usually they have line of site towers so 15 watts is usually more than enough for good communication. And in almost every case, use yagi antennae pointing at each other. They (FCC) should refer to them as Operational Fixed Stations like they do in the Part 90 rules and regs. Quote
LeoG Posted yesterday at 01:46 AM Report Posted yesterday at 01:46 AM I was going to mention that specifically but I mentioned it in an obscure sense when I gave my microwave example. AdmiralCochrane 1 Quote
AdmiralCochrane Posted 4 hours ago Report Posted 4 hours ago On 8/1/2025 at 9:46 PM, LeoG said: I was going to mention that specifically but I mentioned it in an obscure sense when I gave my microwave example. My old microwave in my kitchen is 1200 watts, capable of a really nasty burn SteveShannon 1 Quote
LeoG Posted 1 hour ago Report Posted 1 hour ago When I put my radio in the MW it comes out with a higher wattage. Transferal from the 1200 I guess... Quote
