SteveShannon Posted 6 hours ago Report Posted 6 hours ago 1 minute ago, WRXB215 said: I only needed one. Just had to be able to pan around to prove I wasn't cheating. Are you done? How did it go? Quote
WRXB215 Posted 6 hours ago Report Posted 6 hours ago 5 minutes ago, SteveShannon said: Are you done? How did it go? I took the test in January 2024. Just changed my call sign this April. Quote
SteveShannon Posted 6 hours ago Report Posted 6 hours ago 10 minutes ago, WRXB215 said: I took the test in January 2024. Just changed my call sign this April. Oops, sorry. I failed to see that it was your post instead of @WSAA635 WRXB215 1 Quote
WSAA635 Posted 5 hours ago Author Report Posted 5 hours ago Just finished my test, 34 out of 35. I'm a HAM, LOL. WRXB215 and WRYZ926 2 Quote
WRXB215 Posted 3 hours ago Report Posted 3 hours ago 1 hour ago, WSAA635 said: Just finished my test, 34 out of 35. I'm a HAM, LOL. Congratulations! I knew you could do it. WSAA635 1 Quote
WRYZ926 Posted 2 hours ago Report Posted 2 hours ago 2 hours ago, WSAA635 said: Just finished my test, 34 out of 35. I'm a HAM, LOL. Congratulations! Now the wait begins. You will get an email from the FCC telling you your license is approved and a link for you to pay your $35. It should only take a few days as long as the VE submits everything electronically. Double check your spam folders too. Now you will have so many other squirrels to chase with your amateur license. Tech gives you AM, single side band, CW (morse code) and digital mode privileges on 10m. You also get CW privileges on 15m, 40m, and 80m. There is plenty to do with the 2m, 1.25m, and 70cm bands. You might end up enjoying talking to the space station when it passes over. It took 3 weeks for my technician and three weeks for my general since my local VE is stuck in the Stone Age and mails everything through USPS. Quote
WRYZ926 Posted 2 hours ago Report Posted 2 hours ago PS: Getting your general opens up all of the HF bands if you are interested. The general test is not hard, especially if you start studying now. Quote
WSAA635 Posted 2 hours ago Author Report Posted 2 hours ago I can do 10M with the Tech License but I don't have any radios that'll do that band. The test team said they'd summit things today any I should be processed tomorrow or next day. I'm going to reprogram a couple of my radios for HAM use. I just need to figure out which frequencies to use. Quote
WRYZ926 Posted 2 hours ago Report Posted 2 hours ago Here is a good band plan that shows what modes can be used on each band. Icom band plan And the ARRL band https://www.arrl.org/images/view//Charts/Band_Chart_Image_for_ARRL_Web.jpg The ARRL band plan does better at showing what portions you can use per each license. Quote
WSAA635 Posted 2 hours ago Author Report Posted 2 hours ago 1 minute ago, WRYZ926 said: Here is a good band plan that shows what modes can be sued on each band. Icom band plan And the ARRL band https://www.arrl.org/images/view//Charts/Band_Chart_Image_for_ARRL_Web.jpg Thanks but I was thinking more about what "channels"(aka Frequencies) to add. I know there's National Calling Freqs. and some other standard channels and a lot of repeater channels. I just need to figure out what they are so I can make up a code plug for my radios. Quote
WRYZ926 Posted 1 hour ago Report Posted 1 hour ago I won't be much help on DMR since I have yet to use that mode. The national calling frequencies and local repeaters are a good start. Also look to see if there are any local DMR repeaters in your area. Asking on a local DMR repeater would be a good place to start. Quote
BoxCar Posted 1 hour ago Report Posted 1 hour ago 27 minutes ago, WSAA635 said: Thanks but I was thinking more about what "channels"(aka Frequencies) to add. I know there's National Calling Freqs. and some other standard channels and a lot of repeater channels. I just need to figure out what they are so I can make up a code plug for my radios. Just to clear some confusion, channels and frequencies are often interchanged but they are not the same in all cases. A channel always contains a frequency - GMRS is an example. Frequencies can be assigned to a channel but they are also free-standing. In the amateur world we talk frequencies, but use channels when any other service uses them. AdmiralCochrane 1 Quote
WSAA635 Posted 1 hour ago Author Report Posted 1 hour ago Yep, I kind of figured that since HAM Frequencies are not really SET to a Channel like GMRS. It's like in Fly Fishing, they call a "Bobber" a "Strike Indicator", same thing only different. LOL. I put together a list of National Calling Freqs and some of the local Repeaters(I've never seen so many Repeaters, especially on 70cm) so I'll make up a code plug with them and write them to one of my radios to test them out once I get my call sign. Quote
