SWR of 1.75, can i do better or leave it as is?
Hello All!
New to GMRS and having a blast learning and getting gear together. I recently did a install on Gen 3 Tacoma and I am getting a SWR of 1.75. Below is my build. Looking for some suggestions on how to get the SWR a bit lower, or being what it is, maybe just accept the 1.75 and call it good. Appreciate all suggestions!
Equipment Utilized:
Btech GMRS50-Pro - https://baofengtech.com/product/gmrs-50pro/
Midland MXTA24 NMO - https://www.amazon.com/dp/B0842B1WFS
MIdland MXTA26 Antenna - https://www.amazon.com/dp/B084BPXNC5
Ditch Light Bracket - https://www.amazon.com/dp/B0FG7P4DWY With a 3/8" Stainless Steel washer for fitment.
Surcom Sw-102S - https://www.amazon.com/dp/B01M7QPXEY
NMO Mount to Ditch bracket. Recognize the antenna is not perfectly straight up and is at an angle, I'll try to figure out how to get this mount more straight up, but the way my ditch light bracket is, this may not be easily achievable.
I then ran it across the engine bay and then into the cabin through a gromet.
Both the power and NMO cable were tucked under panels.
I then created a mount for the BTECH GMRS50-PRO and connected everything behind the drivers side backseat storage.
Current readings on meter.
Once BTECH releases their Mic extension, i will run the mic extension wire from the back panel to the front drivers seat, so i can control the whole radio via the BTECH mic remote.
Thanks!
Try it on different channels. See what the SWR is on the channels you transmit on the most. Don’t forget the 467 MHz main channels.
To answer your other question, you can tune the antenna by lengthening or shortening it. Changing the location of the mount can also affect the SWR. Antennas have a dip at a single frequency where they’re tuned best. An antenna analyzer helps you know whether the antenna is too long or too short. There’s nothing wrong with 1.75:1.
10 hours ago, TxHunter777 said:
Hello All!
Equipment Utilized:
Thanks!
That's a nice neat installation! I like it when people post stuff like this. Good material to reference for ideas.
Anything under 2.0 is okay.
Definitely check the SWR on the repeater channels (467 MHz) as they will have a different SWR compared to the 462 simplex channels. As others have mentioned, there will be a curve to the SWR. Generally 467 will be higher or lower than 462 depending on if the antenna is short or long.
The best I did was when tuning a Tram 1174 for GMRS. I got the SWR down to 1.4 on 467 and 1.2 on 462. Yes I could have kept trying for the perfect SWR but it wasn't worth the time and effort. My two Comet 2x4SR antennas are at 1.7-1.8 on 467 and 1.4-1.5 on 462. Again that is good especially considering the SWR is at 1.8 or less on the other bands that the 2x4SR works on.
While a Surecom will work to tune antennas, you will have to check multiple times across the frequency/channel range to find where the SWR is high or low. This is where a NanoVNA or antenna analyzer comes in handy. They will do a sweep and show the high and low spots.
Ran some channels SWR, is as follows. Was not able to connect to 467 repeater yet, so I will have to figure out how to do that.
Channels:
1 - 1.54
2 - 1.55
3 - 1.55
15 - 1.73
16 - 1.73
17 - 1.73
22- 1.73
23 - 1.6
You can still check the SWR on repeater channels even without actually connecting to a repeater.  And you don't need to worry about tones when testing SWR. Just say your "call sign testing" just in case.
I think I will have to program my unit then (still learning how to use it) as the only 467 mhz channels that are pre-programmed are 8-14 which the unit will not transmit on. Will do some more research and report back !
Thanks!
Thanks!
Won’t it transmit on RP15-RP22 (aka 23-30), the repeater channels?
In both of my setups I had a noticeable degradation of reception when the SWR got over 1.7
The base station issue was water so that might be the degradation effect.  But now my repeater is at 1.76 and I'm noticing a bit of loss.
Or I'm nutz
LEDs are known to cause interference. The cheaper ones are worse.
I have some Amazon 4 foot LEDs along with some cheap screw in LEDs from Walmart in my garage. all of them cause a lot of interference on my dual band and GMRS radios when the lights are on and I have radios on inside the garage.
Cover the driver/power supply with tinfoil to see if it reduces.  If it does put it in a metal box.
Unless it's already surrounded by metal cause in that case you're done.
16 hours ago, gortex2 said:
The antenna mount doesn't look right. Those teeth should be smack into the steel bracket. Can you get a better picture of your mount assembly ?
I swapped the Stainless steel washer from the bottom to the top of the mount. Tightened it down as tight as it will go. Teeth are closer, but not digging in to the bracket. Looks like the teeth are not pointed up, they are more pointed out. Perhaps without the stainless steel washer i can get closer, but I am needing to use a stainless steel washer because the mount i received has a .7" hole vs a 3/8" required for the NMO mount. Ran test again with this setup and no visible changes in swr. I can explore getting a bracket designed specifically wiith a 3/8" (midland sells one but its like $25 vs the $8 i spent), but i am not sure if i will see any changes in swr.
15 hours ago, nokones said:
You need to check the reception with the Ditch Light activated to see if the LEDs will interfere with your signal.
Yeah I will do that next. I very rarely use these ditch lights anymore, so I am not concerned with running them at the same time.  Considered even taking them off, but since they are already wired up, i left them on.
I suppose I could fabricate a metal enclosure vs the thrown together wood mount i did. The wood mount was made with just left of materials i had which was part of the fun, and fits surprisingly perfect.
I believe Leo was recommending enclosing the driver/power supply for the LED lights, not replacing the wooden mount for the radio that you made.
In my mind I was thinking of those rolls of LEDs that you lay out.  In reality he probably meant a shop light style fixture with LED lights in it which would mean the driver is surrounded by metal already.  The cheap power supplies that drive LEDs are usually noisy and get pretty hot when driven to max.  Whenever I build with them I like to make sure there's a few amps in reserve basically to keep the driver from putting out max current keeping it cool and it's life longer.  Putting it in a metal container might make the heating worse.
