WSEL330 Posted 4 hours ago Report Posted 4 hours ago Elmer/Elmo/Radio dorks/Etc..(not meant to be derogatory, affectionate), As the title says, I am new (KR4FHF). I have a TYT TH-9800. Getting at 1.01-1.65 SWR between freqs on 70cm and 2m. Coax is rg58 (I know....And length in this case made no difference with my problem). Antenna is about 60' up but I am on a wooded lot. I have it in as clear of a spot as I can hanging from a tree. I adjusted the height according to SWR. Repeaters report decent signal report. I have been on nets with no one saying anything about my trans. While listening, the speaker will start strong with great signal. Then the audio degrades but signal the same. I find if I 'key' quickly, the speaker comes back strong again but then fades again. My HAM study suggests that my radio does not have the features to 'track the fluxuating freq' OR I have a problem with capacitance and/or inductance somewhere. Surprisingly, the antenna tuned for 70cm and 2m works with an SWR of 1.2 on my GRMS tuned at a 462.575ish. I have swapped the coax cables back and forth (RG58 and RG213) as well with no change in fading. I this a product of my location and propagation problems due to my climate? Need some learnin', enlighten me oh wise HAM family. Quote
WRUU653 Posted 4 hours ago Report Posted 4 hours ago I’m curious what you are using for a power source. Quote
WSEL330 Posted 4 hours ago Author Report Posted 4 hours ago 2 minutes ago, WRUU653 said: I’m curious what you are using for a power source. Jesverty SPS-3011 set at 13.8V Quote
WRUU653 Posted 4 hours ago Report Posted 4 hours ago Just now, WSEL330 said: Jesverty SPS-3011 set at 13.8V Well that shoots down that theory… SteveShannon 1 Quote
WSEL330 Posted 4 hours ago Author Report Posted 4 hours ago 1 minute ago, WRUU653 said: Well that shoots down that theory… But thank you, Sir. WRUU653 1 Quote
SteveShannon Posted 4 hours ago Report Posted 4 hours ago 26 minutes ago, WSEL330 said: Elmer/Elmo/Radio dorks/Etc..(not meant to be derogatory, affectionate), As the title says, I am new (KR4FHF). I have a TYT TH-9800. Getting at 1.01-1.65 SWR between freqs on 70cm and 2m. Coax is rg58 (I know....And length in this case made no difference with my problem). Antenna is about 60' up but I am on a wooded lot. I have it in as clear of a spot as I can hanging from a tree. I adjusted the height according to SWR. Repeaters report decent signal report. I have been on nets with no one saying anything about my trans. While listening, the speaker will start strong with great signal. Then the audio degrades but signal the same. I find if I 'key' quickly, the speaker comes back strong again but then fades again. My HAM study suggests that my radio does not have the features to 'track the fluxuating freq' OR I have a problem with capacitance and/or inductance somewhere. Surprisingly, the antenna tuned for 70cm and 2m works with an SWR of 1.2 on my GRMS tuned at a 462.575ish. I have swapped the coax cables back and forth (RG58 and RG213) as well with no change in fading. I this a product of my location and propagation problems due to my climate? Need some learnin', enlighten me oh wise HAM family. That sounds like a problem with the radio. Can you contact customer service and maybe get a replacement? AdmiralCochrane and WRUU653 2 Quote
WRUU653 Posted 4 hours ago Report Posted 4 hours ago The “quick keying brings it back momentarily” has me suspicious of a loose connection in the radio and the additional power demand is temporarily making the connection better. I’m with @SteveShannon on contacting customer service. SteveShannon 1 Quote
WSEL330 Posted 4 hours ago Author Report Posted 4 hours ago 2 minutes ago, SteveShannon said: That sounds like a problem with the radio. Can you contact customer service and maybe get a replacement? Bummer, I'll see what I can do...Any low budget options for this type of Radio (70cm-2m). Course I am going for my general and realize I will have several radios eventually as the rabbit hole swallows me up! Quote
SteveShannon Posted 4 hours ago Report Posted 4 hours ago 2 minutes ago, WSEL330 said: Bummer, I'll see what I can do...Any low budget options for this type of Radio (70cm-2m). Course I am going for my general and realize I will have several radios eventually as the rabbit hole swallows me up! The Radioddity db20g is a 20 watt GMRS radio that is easily unlocked to operate on 2m and 70 cm. Several of us have one or more. Best wishes for your general!! WRUU653 and TNFrank 2 Quote
WRUU653 Posted 4 hours ago Report Posted 4 hours ago Real budget I like the Anytone AT-779 or one of it’s equivalents. Quote
WRUU653 Posted 4 hours ago Report Posted 4 hours ago 1 minute ago, SteveShannon said: The Radioddity db20g is a 20 watt GMRS radio that is easily unlocked to operate on 2m and 70 cm. Several of us have one or more. Best wishes for your general!! You beat me to it SteveShannon 1 Quote
SteveShannon Posted 4 hours ago Report Posted 4 hours ago 6 minutes ago, SteveShannon said: The Radioddity db20g is a 20 watt GMRS radio that is easily unlocked to operate on 2m and 70 cm. Several of us have one or more. Best wishes for your general!! 5 minutes ago, WRUU653 said: Real budget I like the Anytone AT-779 or one of it’s equivalents. @WSEL330 - just so you know the AT-779 and the Radioddity are basically the same radio, just different name plates. There’s another brand also that sells their version of the same radio but I’m old and I don’t remember the name. WRUU653 1 Quote
WRYS709 Posted 4 hours ago Report Posted 4 hours ago 9 minutes ago, WRUU653 said: Real budget I like the Anytone AT-779 or one of it’s equivalents. I find that my AT-779UV and my DB20-G into to my rooftop Comet CX-333 tribander, outperform my Yaesu FT-857d on 2 meters and 70 cm FM. WRUU653 1 Quote
WSEL330 Posted 4 hours ago Author Report Posted 4 hours ago 3 minutes ago, SteveShannon said: @WSEL330 - just so you know the AT-779 and the Radioddity are basically the same radio, just different name plates. There’s another brand also that sells their version of the same radio but I’m old and I don’t remember the name. I share your old thing, that's why I ask via type so I can look back at it! SteveShannon 1 Quote
WRUU653 Posted 3 hours ago Report Posted 3 hours ago 13 minutes ago, SteveShannon said: @WSEL330 - just so you know the AT-779 and the Radioddity are basically the same radio, just different name plates. There’s another brand also that sells their version of the same radio but I’m old and I don’t remember the name. Retevis RA25. I had to look it up, I couldn’t remember either SteveShannon 1 Quote
WRUU653 Posted 3 hours ago Report Posted 3 hours ago 10 minutes ago, WSEL330 said: I share your old thing, that's why I ask via type so I can look back at it! If memory serves me (and sometimes it doesn’t) I believe all three can be unlocked but you can also order either GMRS or ham versions as well. Quote
WRYS709 Posted 3 hours ago Report Posted 3 hours ago 8 minutes ago, WRUU653 said: Retevis RA25. I had to look it up, I couldn’t remember either I have never had a Retevis Ra-25 in my hands, but in an attempt to help a Ham that had one, I found that the Retevis version of the CPS software created codeplugs that I could not open in the Radioddity CPS software. So I have concluded that the Retevis model is not a 100% clone and I avoid it. Chirp (and/or the RT Software) may make this issue moot! Quote
WRXB215 Posted 3 hours ago Report Posted 3 hours ago Don't forget to check out the AnyTone 778UV while you're at it. Quote
WSEL330 Posted 3 hours ago Author Report Posted 3 hours ago 18 minutes ago, WRXB215 said: Don't forget to check out the AnyTone 778UV while you're at it. Thank you all. My first stop is call/contact them and see what can be done.... WRUU653 1 Quote
AdmiralCochrane Posted 2 hours ago Report Posted 2 hours ago This is why I bought the extended warranty on my 9800. Not this exact problem, but numerous similar problems. Mine has been great. SteveShannon 1 Quote
