nokones Posted November 19, 2025 Posted November 19, 2025 I assume this would be considered as a GMRS Athletic Exercise Ball being a 65 cm in size that matches the 462 MHz wave length which is 64.9 cm. I supposed one would expect this be a circular radiation pattern as opposed to being directional. SteveShannon, WRTC928, AdmiralCochrane and 2 others 2 3 Quote
amaff Posted November 19, 2025 Posted November 19, 2025 That did not go where I thought it was going to go SteveShannon 1 Quote
HHD1 Posted November 20, 2025 Posted November 20, 2025 The ribs suggest spurious RF emissions... WRTC928, NCJeb and SteveShannon 3 Quote
Blaise Posted November 21, 2025 Posted November 21, 2025 A sphere is not an unheard-of way to represent sinusoidal data in three dimensions... SteveShannon and HHD1 2 Quote
WRTC928 Posted November 21, 2025 Posted November 21, 2025 Darn! I thought you were going to invite me to a fancy-dress party for radio nerds. SteveShannon 1 Quote
Davichko5650 Posted November 21, 2025 Posted November 21, 2025 Just now, WRTC928 said: Darn! I thought you were going to invite me to a fancy-dress party for radio nerds. A Communications Cotillion? SteveShannon and WRTC928 2 Quote
Blaise Posted November 23, 2025 Posted November 23, 2025 It's more of a reception, really... WRQC299, SteveShannon and amaff 1 2 Quote
WRVR303 Posted January 1 Posted January 1 Looks like the mythical isentropic radiator that antennas get compared to! SteveShannon 1 Quote
AdmiralCochrane Posted January 1 Posted January 1 2 hours ago, WRVR303 said: Looks like the mythical isentropic radiator that antennas get compared to! That made me fall down a rabbit hole of describing something at work. Here is the related HVAC super trivia rabbit hole: You may have noticed that HVAC drain lines are sized massively larger than the water that runs out of them. As dictated by International Plumbing Code, condensate drain lines are sized for gravity flow drainage, as if the full BTU capacity of the machine removed water from the air flowing thru the machine without doing any sensible heat temperature change. Air would enter at some very high humidity (possibly greater than 100% RH or perhaps at a greater CFM flow rate than the fan could actually move it) at, let's say 90° and leave at 0% RH at 90°. The drain size must allow gravity flow exit of that calculated volume of water flow. This would not be isenthalpic/isoenthalpic, but the opposite, perhaps "endoenthalpic". SteveShannon 1 Quote
