mbrun Posted February 27, 2021 Author Report Posted February 27, 2021 On 2/26/2021 at 8:02 PM, n4gix said: It's useful only if you have a real need to monitor two separate frequencies simultaneously, which I definitely must have. With "dual watch" if one frequency is in use, it will stop the "dual watch" and you very well could miss any traffic on the other frequency. With "dual band" on the other hand, you will never miss any traffic on either frequency, although you might need to quickly lower volume on the receiver you don't need to listen to! TDR is a double edge sword. It is great when you need to monitor multiple two frequencies or scan two ranges at the same time. But on an HT it can be bad when you find yourself talking on one side of the radio while audio is being received on the other. The audio from receive side gets picked up by the microphone and retransmitted on the other side, while is simultaneously distracts you, the talking operator. While I really do like having TDR, I find I have to immediately disable now if I am going to use the radio for its intended purpose, two-way radio communications. I have been caught off guard multiple times in the middle a communications when suddenly the speaker starts reproducing audio from another channel. I wish my radios had the option that would enable muting of the second side when the PTT button is pressed. A user preference setting. Extreme 1 Quote
WRKU973 Posted March 22, 2021 Report Posted March 22, 2021 I have this radio and like it tremendously. Quote
MozartMan Posted March 22, 2021 Report Posted March 22, 2021 On 3/22/2021 at 11:45 AM, Mr. Pink said: I have this radio and like it tremendously. Mr. Pink, How/when did you get it? Bettersaferadio website still shows "Pre-Sale" status. https://bettersaferadio.com/wouxun-kg-uv9g-pro-gmrs-two-way-radio-shtf-scanner/ Quote
BSRMark Posted March 24, 2021 Report Posted March 24, 2021 On 2/27/2021 at 12:46 AM, mbrun said: TDR is a double edge sword. It is great when you need to monitor multiple two frequencies or scan two ranges at the same time. But on an HT it can be bad when you find yourself talking on one side of the radio while audio is being received on the other. The audio from receive side gets picked up by the microphone and retransmitted on the other side, while is simultaneously distracts you, the talking operator. ... I wish my radios had the option that would enable muting of the second side when the PTT button is pressed. A user preference setting. The Wouxun KG-UV9G and KG-UV9P (and the rest of the 9-Series line) all have control over the TDR muting. You can have the radio mute the sub-band when the main band is Rx/Tx, or both. I always have it muted on Tx unless I'm doing cross-band sat work, in which case you sometimes want to hear the other side, but with an earpiece, as you should always use when full TDR without muting is used. Quote
mbrun Posted March 24, 2021 Author Report Posted March 24, 2021 On 3/24/2021 at 4:26 AM, BSRMark said: The Wouxun KG-UV9G and KG-UV9P (and the rest of the 9-Series line) all have control over the TDR muting. You can have the radio mute the sub-band when the main band is Rx/Tx, or both. I always have it muted on Tx unless I'm doing cross-band sat work, in which case you sometimes want to hear the other side, but with an earpiece, as you should always use when full TDR without muting is used. Which menu setting on the radio does this? MichaelWRHS965KE8PLM Quote
srbecker Posted April 15, 2021 Report Posted April 15, 2021 I just ordered this radio. I am pretty excited for it and will follow this forum so I can learn of any tips or tricks you guys post about. BSRMark 1 Quote
BSRMark Posted April 15, 2021 Report Posted April 15, 2021 On 3/24/2021 at 1:32 PM, mbrun said: Which menu setting on the radio does this? MENU_60 "S-MUTE" with 4 options: RX, TX, Both, Off. Quote
mbrun Posted April 15, 2021 Author Report Posted April 15, 2021 On 4/15/2021 at 8:10 PM, BSRMark said: MENU_60 "S-MUTE" with 4 options: RX, TX, Both, Off.Perfect. Thanks! MichaelWRHS965KE8PLM BSRMark 1 Quote
Jronco Posted May 2, 2021 Report Posted May 2, 2021 I am new to GMRS. Ihave two radios on order. The Wouxun KG-1000G for my vehicle and the KG-UV9G PRO for a family member (expecting to get it late May/early June). I am looking for a programming cable. Can anyone tell me what the difference is between the Wouxun KG-UV9D Advanced Programming Software & USB Cable Kit and Wouxun PCO-009 WXUSB “Red” Programming Cable for Wouxun Radios besides the KG-UV9D cable comes with software? Can I get the PCO-009 and download the software separately? Quote
mbrun Posted May 2, 2021 Author Report Posted May 2, 2021 On 5/2/2021 at 4:18 PM, Jronco said: I am new to GMRS. Ihave two radios on order. The Wouxun KG-1000G for my vehicle and the KG-UV9G PRO for a family member (expecting to get it late May/early June). I am looking for a programming cable. Can anyone tell me what the difference is between the Wouxun KG-UV9D Advanced Programming Software & USB Cable Kit and Wouxun PCO-009 WXUSB “Red” Programming Cable for Wouxun Radios besides the KG-UV9D cable comes with software? Can I get the PCO-009 and download the software separately? This is the cable I use with all my current models of Wouxun HTs: https://www.buytwowayradios.com/wouxun-pco-001.htmlThis includes a KG-UV9P which the 9G is based on, KG-805G, KG-905G, and KG-UV8H. I speculate that the 001 and 009 cables are identical, just one part number used by BSR and one by BTWR.Software is freely downloadable. The 9D software is fully compatible with the 9P, and my understanding is the 9G is similarly compatible. I see also that BSR has model-specific software available to freely download as well. You should be able to download and play with it before even ordering a cable.MichaelWRHS965KE8PLMEdit: It just occurred to me. If the software & cable combination is actually RTS Systems software, you will need the RTS Systems cable. My current understanding is RTS software will only work with the radio when using an RTS Systems cable. However, if it is Wouxun software then Wouxun cable is fine. Quote
WyoJoe Posted May 2, 2021 Report Posted May 2, 2021 I have both the KG-UV9P and the KG-UV9G, and using the same cable I've used for my Baofeng and TYT handhelds, I've been able to successfully read from both Wouxon radios with Chirp using the KG-UV9D profile. I haven't tried writing anything to the KG-UV9G, but I had no problem writing to the KG-UV9P. pcradio and Jronco 1 1 Quote
Jronco Posted May 2, 2021 Report Posted May 2, 2021 On 5/2/2021 at 6:11 PM, mbrun said: This is the cable I use with all my current models of Wouxun HTs: https://www.buytwowayradios.com/wouxun-pco-001.html This includes a KG-UV9P which the 9G is based on, KG-805G, KG-905G, and KG-UV8H. I speculate that the 001 and 009 cables are identical, just one part number used by BSR and one by BTWR. Software is freely downloadable. The 9D software is fully compatible with the 9P, and my understanding is the 9G is similarly compatible. I see also that BSR has model-specific software available to freely download as well. You should be able to download and play with it before even ordering a cable. Michael WRHS965 KE8PLM Edit: It just occurred to me. If the software & cable combination is actually RTS Systems software, you will need the RTS Systems cable. My current understanding is RTS software will only work with the radio when using an RTS Systems cable. However, if it is Wouxun software then Wouxun cable is fine. Expand Thanks for the info! I appreciate it! Quote
