#1
Posted 29 October 2020 - 04:11 PM
Can anyone walk me through it?
#2
Posted 29 October 2020 - 05:36 PM
Go to one of the repeater channels, select the proper access codes and you should be all set.
#3
Posted 30 October 2020 - 03:38 AM
I recently purchased this mobil device and need some help programming repeaters.
if you don't have it, the manual is here: https://midlandusa.c...ners-Manual.pdf
out of the box, you probably have to enable the repeater channels in the menu (look for option 'rp' and set it to 'on').
next, pick the repeater you want to access, note the frequency and tone, and figure out which channel it equates to. (pg 27 has a chart of channel to frequencies). switch to that channel, then back into the menu, and you have to set the tones. page 28 has the code charts; see what code the tone equates to, and set it in the menu. from there, you should be set on the basics.
- kipandlee likes this
#4
Posted 11 January 2021 - 04:24 PM
I've enabled the repeater channels and setup a couple area repeaters, but noticed the repeater channels aren't scanned when using channel scan function.
#5
Posted 11 January 2021 - 07:38 PM
Not exactly convenient to respond to something on that repeater, I admit, since when you come off scan it goes to whatever you were on prior to scanning
#6
Posted 12 January 2021 - 08:38 AM
Realistically, if you don't have pl tones input on the simplex (15-22) channels, you'll hear any traffic coming from the repeaters as well, since the receive side of the repeater channels 15-22 is the same as their simplex counterpart.
Thanks wayoverhtere.
My MXT90 allows me to remove or add back channels to the scan. If I only want 15,19, 21 and 22 to scan I can remove all other channels and only scan those 4. I expected that ability on the newer midland micros but unfortunately that's not possible. I contact Midland and they suggested the pl tones work around for the 275. They also indicated I could do what I want on my MXT400, but that required software. I'm waiting to hear back from them on how to obtain the software.
#7
Posted 12 January 2021 - 01:54 PM
https://forums.mygmr...pdates/?p=17118
I’ve used the software that’s available in that Dropbox and it works. Need a USB to 3.5 cable to program. This is the one I purchased...
https://www.rtsystem...able_p_748.html
- WRJZ943 likes this
Also tagged with one or more of these keywords: Programming
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
