amaff Posted May 29, 2024 Report Posted May 29, 2024 11 minutes ago, WSCF389 said: I’m running the ra25 GMRS radio in my shack right now and I’m impressed with it. You can’t change many settings unfortunately it’s all locked up That is fixable Quote
WSCF389 Posted June 2, 2024 Report Posted June 2, 2024 Do you happen to have a chirp file I can upload to it? Quote
WRYS709 Posted June 2, 2024 Report Posted June 2, 2024 Last I checked the Ra-25 still does not work with CHIRP. Quote
amaff Posted June 2, 2024 Report Posted June 2, 2024 It doesn't. But the Anytone / Retevis / Radioddity software...well, it isn't completely awful and it does the job lol Quote
WRYS709 Posted June 2, 2024 Report Posted June 2, 2024 2 hours ago, amaff said: It doesn't. But the Anytone / Retevis / Radioddity software...well, it isn't completely awful and it does the job lol I do not have access to the Ra-25; only the DB20-G and the AT-779UV. In my experience, downloading and experimenting with the Ra-25 software, it creates code plugs that cannot be opened and hence nor modified and used by the Radioddity and Anytone CPS software. Is your experience different? Quote
amaff Posted June 2, 2024 Report Posted June 2, 2024 I honestly can't speak to the Retevis software. I've only used the DB20-G software (as that's the radio I have) Quote
WSDU488 Posted April 9 Report Posted April 9 What rechargeable battery can I buy for this radio. I want to put it in a man pack for on the go. Could I use a Power-Sonic Rechargeable Sealed Lead Acid Battery PS-1270 12V 7.0 AH @ 20-hr. 12V 6.5 AH @ 10-hr? Here's the link: https://amzn.to/4lqtbu6 Can someone help me with this? Quote
Socalgmrs Posted April 9 Report Posted April 9 23 minutes ago, WSDU488 said: What rechargeable battery can I buy for this radio. I want to put it in a man pack for on the go. Could I use a Power-Sonic Rechargeable Sealed Lead Acid Battery PS-1270 12V 7.0 AH @ 20-hr. 12V 6.5 AH @ 10-hr? Here's the link: https://amzn.to/4lqtbu6 Can someone help me with this? You can use any 12v battery you want from a very small one to a huge one you would not want to carry. Just like any other 12v dc based mobile/base radio. The real question is why would you want to carry it around when a 5w hand held and a basic 771 antenna can do well over 60miles line of site. And add a better base/mobile antenna and you’re gonna hit 100miles. What’s the infatuation with dragging around a base/mobile 20w radio? If it’s a shtf situation dragging a round a big radio and battery is not on my list. Food water and other brass essentials are. Quote
Jaay Posted April 10 Report Posted April 10 1 hour ago, Socalgmrs said: You can use any 12v battery you want from a very small one to a huge one you would not want to carry. Just like any other 12v dc based mobile/base radio. The real question is why would you want to carry it around when a 5w hand held and a basic 771 antenna can do well over 60miles line of site. And add a better base/mobile antenna and you’re gonna hit 100miles. What’s the infatuation with dragging around a base/mobile 20w radio? If it’s a shtf situation dragging a round a big radio and battery is not on my list. Food water and other brass essentials are. We're wishing your batteries would just go DEAD, with Silly responses like that. dosw 1 Quote
Jaay Posted April 10 Report Posted April 10 2 hours ago, WSDU488 said: What rechargeable battery can I buy for this radio. I want to put it in a man pack for on the go. Could I use a Power-Sonic Rechargeable Sealed Lead Acid Battery PS-1270 12V 7.0 AH @ 20-hr. 12V 6.5 AH @ 10-hr? Here's the link: https://amzn.to/4lqtbu6 Can someone help me with this? Check www.powerwerx.com OR batteriesamerica.com they can help you with whatever you want to do. Quote
WRYZ926 Posted April 11 Report Posted April 11 There is nothing wrong with wanting a portable GMRS setup that will put out 20-50 watts. I like using 10 AH or 12AH lipo4 batteries for 20 watt or less radios. Most 10 AH lipo4 are the same size as the batteries in computer battery backup systems. The lipo4 batteries are quite a bit lighter. I like the Redodo brand of lipo4 batteries when it comes to 50 AH or 100 AH batteries. A group 24 lipo4 batterie will be half the weight of a standard group 24 lead acid deep cycle battery. And just ignore Negative Nancy with his negative waves. Socalgmrs, WRUU653, WRNU354 and 1 other 3 1 Quote
Socalgmrs Posted April 11 Report Posted April 11 39 minutes ago, WRYZ926 said: There is nothing wrong with wanting a portable GMRS setup that will put out 20-50 watts. I like using 10 AH or 12AH lipo4 batteries for 20 watt or less radios. Most 10 AH lipo4 are the same size as the batteries in computer battery backup systems. The lipo4 batteries are quite a bit lighter. I like the Redodo brand of lipo4 batteries when it comes to 50 AH or 100 AH batteries. A group 24 lipo4 batterie will be half the weight of a standard group 24 lead acid deep cycle battery. And just ignore Negative Nancy with his negative waves. If you have ever needed to carry a ruck for any length of time you and others would understand my point. If I’m hiking for fun and I just want to hike to the top of the highest peak and talk to strangers I’ve got an ht. It does 60miles easy. If it’s a shtf type of thing I don’t want to waste valuable weight dragging around a radio that will be mostly useless anyway. Your support of this tells me about your life experiences or lack there of. Food water and protection from the weather and people is priority not a useless radio. Besides what type of coax gonna use? Light weight and full of loss? How high and how is an antenna gonna get? one more thing. You’re wearing a bomb. Lithium is not stable. If it charges to much fire. If it discharges to much fire. If you drop it fire. If it gets to hot fire. If it gets to cold fire. See the pattern. Fire bad. So your hiking for the fun of it and you slip and you dont even know you damaged the battery untill your bag is in fire. Then you set the whole mountain on fire. . Quote
WRYZ926 Posted April 11 Report Posted April 11 14 hours ago, Socalgmrs said: If you have ever needed to carry a ruck for any length of time you and others would understand my point. If I’m hiking for fun and I just want to hike to the top of the highest peak and talk to strangers I’ve got an ht. It does 60miles easy. If it’s a shtf type of thing I don’t want to waste valuable weight dragging around a radio that will be mostly useless anyway. Your support of this tells me about your life experiences or lack there of. Food water and protection from the weather and people is priority not a useless radio. Besides what type of coax gonna use? Light weight and full of loss? How high and how is an antenna gonna get? Yes I have rucked plenty. I was both airborne and air assault qualified, assigned to airborne units. And when my assigned weapon was not the M60, then I would get assigned to carry the PRC-77 radio. So yes I know a thing or two about rucking extra weight. Now go strap on a 75-80 pound ruck sack, carry the M60 machine gun with 1000-1500 rounds of ammunition along with your main and backup parachute before you say anything else about how I supposedly don't know anything about carrying weight. I was also a combat engineer so I carried even more stuff than the average infantryman. And I have done so in combat on a few occasions. Let's break down the weight infantryman ruck -70 pounds combat engineer ruck - 75-80 pounds Main and reserve parachutes - 53 pounds. M60 machine gun unloaded - 23 pounds 500 rounds of spare ammo - 35 pounds Those weights didn't even include any explosives or mines I also had to carry. You showed your rear again by assuming that I don't have any experience rucking heavy weights. And we all know what assume actually means. WRNU354, SteveShannon, CoffeeTime and 2 others 3 2 Quote
CoffeeTime Posted April 11 Report Posted April 11 May God bless and comfort your joints and spine. Thank you for your service! Best Regards! WRYZ926, WRUU653 and SteveShannon 3 Quote
WRYZ926 Posted April 11 Report Posted April 11 And yes we all know the dangers of lithium batteries and how hard they are to put out if they catch fire. But a lead acid battery can explode just as easily when abused. Most combat vehicle, AKA tanks, use a bank of 8 12v DC batteries hooked up in series/parallel for 24 volts out. And they are high AH batteries that are needed to start those big V12 diesel engines or turbo shaft engines. Most armored personnel vehicle use 6 or 8 12V batteries while most wheeled vehicles use 4 batteries. And I have seen those batteries explode when mishandled, abuse, and/or damaged. One would have to abuse either battery type to have any safety issues. Quote
WSHH887 Posted April 11 Report Posted April 11 Okay, this got me to thinking. I mentioned in another thread about putting a DB-5 in a sling pack. But it requires a power source. Turns out I have eight older, but not dead, small 12 volt batteries that came out of an ECV. I juiced one up, hooked it up to the radio and everything worked. Left it on all night scanning and this morning it's still working. next to see how long it works with intermittent transmissions. It's kind of fun finding stuff in my garage and repurposing it for radio use. Quote
