taco6513 Posted January 21, 2021 Report Posted January 21, 2021 Just another dumb question.. You are not allowed to have a repeater on MURS as there are no repeater offsets to use in this band.The Anytone D-578UV pro I have can do a DMR repeater function on one channel. Transmit on time slot #1 and receive on time slot #2. Would this be legal? Just using one channel. DMR and encryption are permitted on MURS. What are you thoughts... ThanksWRCW870KI5GXD Quote
Radioguy7268 Posted January 21, 2021 Report Posted January 21, 2021 Where did you read that DMR was allowed on MURS? I've been of the understanding that MURS is analog only. Is this part of the Part 95 "short digital bursts" for GPS location data like what was allowed in GMRS ? I could be wrong - so feel free to enlighten me. I never sit up at night reading the FCC rules anymore. I've been under the impression that MURS still allowed some analog Wideband on just 2 channels - but not DMR. Also - is the Anytone D-578UV a Part 95 Certified radio? Is it Part 90? Quote
gman1971 Posted January 22, 2021 Report Posted January 22, 2021 MURS allows for digital data only afaik, no digital voice is allowed. So you can do things like remote control via digital using MURS. Repeater operation in MURS is not allowed, regardless of repeater configuration. Even the suggestion of using an 65 Watt AT-578 on MURS with encryption is not something I would be posting about in a public GMRS forum I own one of those and I think its a part 90 radio. G. Quote
gortex2 Posted January 22, 2021 Report Posted January 22, 2021 MURS does not allow DMR. Nor does GMRS. Quote
taco6513 Posted January 22, 2021 Author Report Posted January 22, 2021 I stand corrected. DMR, P25, and other digital voice mode are NOT allowed on MURS.The 578 is a Part 90 radio.The power level may be set as low at 5 watts. Programmed per channel.65 Watt radio? I wish. 50 watts VHF and 40 watts UHF.Thanks for the correction. Still learning.WRCW870KI5GXD Quote
gman1971 Posted January 23, 2021 Report Posted January 23, 2021 You're right, 50w max, my mistake. 50 and 65 won't make much of a difference The max allowed power for MURS is 2W, not 5W. G. AdmiralCochrane 1 Quote
n4gix Posted January 23, 2021 Report Posted January 23, 2021 MURS allows for digital data only afaik, no digital voice is allowed. So you can do things like remote control via digital using MURS. Many farmers and ranchers use MURS for gate alarms, controllers for irrigation pumps, et cetera. gortex2 and gman1971 2 Quote
WRQI583 Posted July 11, 2022 Report Posted July 11, 2022 People use MURS around me for dog tracking collars, that's it. Highly annoying! Quote
