I’ve been trying to build a base station. Bought a HYS UHF Yagi Portable Installation Outdoor Antenna Base Stations 9dBi UHF 70cm/UHF 400-470 MHz, and LMR400 coax.
I have a telescopic mast and originally put everything together just to see what kind of range I would have with the antenna at 15’. My SWR reading was at 1.5. I only bought 30’ of LMR 400. When I pulled the mast out I had almost 35’ so went online and bought 50’ of what I thought was going to be LMR400.
When I received the 50’ of coax, it was MFD-400 which I can tell is slightly smaller in diameter and more flexible than the LMR-400. So I decided to use it anyway. The MFD-400 runs from the antenna to the wall..then a lightning arrestor...then LMR-400 runs through the wall to my radio, BTECH GMRS 50x1. The antenna was raised to about 32’.
I plugged in my Surecom SW102 and my SWR reading is 2.95 on two different frequencies. The only thing I did to the new cable was cut it to length and solder the tip of a new PL-259 connector. The one thing that stands out to me is that I’m using two different types of coax. Could that be my issue? I did not mess with the tuning adjustment on the antenna since the original SWR reading was 1.5.
WRKH870
Any ideas what my problem is/problems are?
Edited by WRKH870More clarification
8 answers to this question
