WSAA930 Posted March 27, 2024 Report Posted March 27, 2024 On 3/23/2024 at 7:51 PM, WRYS709 said: What version is your firmware? V3.0 FWIW I took the squelch up to 7 in multiple steps, just to test. It seems to have made it better, for the most part. Other radios I have only gone to 3-5, just difference in equipment I guess? Quote
WRYS709 Posted March 27, 2024 Report Posted March 27, 2024 6 hours ago, WSAA930 said: V3.0 FWIW I took the squelch up to 7 in multiple steps, just to test. It seems to have made it better, for the most part. Other radios I have only gone to 3-5, just difference in equipment I guess? Looks like your situation is somewhat unique, but I am glad to hear you have it figured out. Quote
Davichko5650 Posted May 22, 2024 Report Posted May 22, 2024 Got this as part of a bundle with the GM-30 HT, so far very much liking it, compared to my ancient MXT275 it seems to receive much better, and has split tones for the repeaters. Here's a couple views of the mounting. Already had the cupholder mount working for my FT-891, so stacked it on top, convient screws atop the Yaesu to bolt down the bracket on the DB20. Just gotta score a couple more 3m Mic mounts and we're all set for the next off-road run! Easy to program right on the radio, but looking at doing more with the CPS once I get the time. Quote
WSAA930 Posted June 1, 2024 Report Posted June 1, 2024 I may have missed this, but..... Does the DB20-G dual monitor? I know there is the "A/B" channel selection, but I cannot get mine to monitor both only the "main". Scan works fine. Any tips? Thanks! Quote
WRYS709 Posted June 1, 2024 Report Posted June 1, 2024 53 minutes ago, WSAA930 said: I may have missed this, but..... Does the DB20-G dual monitor? I know there is the "A/B" channel selection, but I cannot get mine to monitor both only the "main". Scan works fine. Any tips? Thanks! On 5/22/2024 at 8:10 AM, Davichko5650 said: Using your photo above, you have Channel 25 in the A Bank and VFO in the B Bank Hit the FUN button to enter Menu Mode and use the V/M and Main as up and down keys to run to Menu 19:DSPSUB. Using the Up and Down arrow keys your selections in this menu 19 are: Off, FREQ, VOLT and it looks like you are in FREQ mode in Menu 19, which is correct for dual monitor. Hit the FUN button to exit Menu Mode for now. Now Hit the Main button to swap the B Bank VFO into the top (main monitor) and A Bank Channel 25 goes to the bottom (secondary monitor). You can now exit VFO Mode and have the B Bank enter Channel Mode by hitting the V/M button and then select your secondary monitor channel using the Up and Down Arrow keys. Hit MAIN to restore your A Bank Channel 25 to your Primary monitor and the newly selected B Bank Channel goes down to the Secondary monitor. Unless you find a way around this upcoming problem that I will note, I do not like this feature because I find that whichever channel receives a signal first will take priority in the receiver. So if I am listening to a conversation in the A Bank and they let the carrier go and at that moment someone hits a carrier on the B Bank Channel, it will take priority on my receiver and I cannot hear the other party's response on the A Bank. Maybe there is an option around this, but I have not yet found it, so I go back to Menu 19:DSPSUB and turn it to OFF and just use the single monitor. WSAA930 1 Quote
WSAA930 Posted June 2, 2024 Report Posted June 2, 2024 1 hour ago, WRYS709 said: Using your photo above, you have Channel 25 in the A Bank and VFO in the B Bank Hit the FUN button to enter Menu Mode and use the V/M and Main as up and down keys to run to Menu 19:DSPSUB. Using the Up and Down arrow keys your selections in this menu 19 are: Off, FREQ, VOLT and it looks like you are in FREQ mode in Menu 19, which is correct for dual monitor. Hit the FUN button to exit Menu Mode for now. Now Hit the Main button to swap the B Bank VFO into the top (main monitor) and A Bank Channel 25 goes to the bottom (secondary monitor). You can now exit VFO Mode and have the B Bank enter Channel Mode by hitting the V/M button and then select your secondary monitor channel using the Up and Down Arrow keys. Hit MAIN to restore your A Bank Channel 25 to your Primary monitor and the newly selected B Bank Channel goes down to the Secondary monitor. Unless you find a way around this upcoming problem that I will note, I do not like this feature because I find that whichever channel receives a signal first will take priority in the receiver. So if I am listening to a conversation in the A Bank and they let the carrier go and at that moment someone hits a carrier on the B Bank Channel, it will take priority on my receiver and I cannot hear the other party's response on the A Bank. Maybe there is an option around this, but I have not yet found it, so I go back to Menu 19:DSPSUB and turn it to OFF and just use the single monitor. Just checked that menu sub - had it set to FREQ and it seems (seems....) to be working right now! Weird, maybe it was an oddity. So far, this radio has been working really well (follow up to my last post a month or more ago). Just been using it as a base here at the house, but size and volume wise would am considering installing as a true mobile. WRYS709 1 Quote
WSAA930 Posted August 4, 2024 Report Posted August 4, 2024 This radio is still working quite well overall. Has anyone had luck with CHIRP programming? I wish the CPS I had was more user friendly...... biggest drawback to this unit really is the programming! Thanks Quote
Frdbronco8 Posted December 19, 2024 Report Posted December 19, 2024 For clarification, if you "unlock" this can you still TX on the GMRS channels or do you have to change it back to GMRS? Quote
amaff Posted December 19, 2024 Report Posted December 19, 2024 46 minutes ago, Frdbronco8 said: For clarification, if you "unlock" this can you still TX on the GMRS channels or do you have to change it back to GMRS? There's a few different frequency range options it has available. The most wide open one will allow transmit on GMRS, yes. It's been a while since I've looked at the options but I believe the GMRS and the 'full' unlock are the only ones that allow it. EDIT: Modes: GMRS Europe (EU Amateur bands, I'd imagine, but I haven't investigated it at all) 136-174, 400-470 <==widest open 144-148, 420-450 Quote
Frdbronco8 Posted December 20, 2024 Report Posted December 20, 2024 2 hours ago, amaff said: There's a few different frequency range options it has available. The most wide open one will allow transmit on GMRS, yes. It's been a while since I've looked at the options but I believe the GMRS and the 'full' unlock are the only ones that allow it. EDIT: Modes: GMRS Europe (EU Amateur bands, I'd imagine, but I haven't investigated it at all) 136-174, 400-470 <==widest open 144-148, I tried this and it wouldnt let me write a new program to the radio with gmrs channels. Aaid something about outside of frequency. Also showed these two channels when i read from radio. I was able to manual dial in a gmrs freq and transmit on it. Would love to have my gmrs programmed and have the ability to TX on a vfo frequency in an emergency if needed. Quote
amaff Posted December 20, 2024 Report Posted December 20, 2024 Did you set the software Model Information (to the left of Edit there at the top) to match the mode the radio is set in? SteveShannon 1 Quote
MozartMan Posted December 20, 2024 Report Posted December 20, 2024 @Frdbronco8 Like amaff said. You need to match model. I have AnyTone AT-779UV, but it basically the same as Radioddity. Here is what I have in the radio and the software. WRUU653, wayoverthere, amaff and 1 other 2 2 Quote
SteveShannon Posted December 20, 2024 Report Posted December 20, 2024 Unfortunately, you cannot transfer a configuration file from a radio with one frequency selection to a radio with another. Nor can you change the frequency selection on the radio you’re programming and then import a configuration file from the same radio when it had a different frequency selection, even if all of the frequencies are compatible. That’s the most aggravating thing I’ve found about this radio. amaff, WRUU653 and wayoverthere 2 1 Quote
WRYS709 Posted December 20, 2024 Report Posted December 20, 2024 9 hours ago, Frdbronco8 said: For clarification, if you "unlock" this can you still TX on the GMRS channels or do you have to change it back to GMRS? 6 hours ago, Frdbronco8 said: Would love to have my gmrs programmed and have the ability to TX on a vfo frequency in an emergency if needed. Attached below is a Codeplug that mimics the Part 95e Rules for GMRS once the radio has been "opened." This will allow you to have more control while following the "rules." Be Sure the Model Information menu detail is the same as the Band that you opened it to Anytone AT-779UV GMRS 202310130140.dat WSGJ919 1 Quote
