WRYS709 Posted December 26, 2024 Report Posted December 26, 2024 I may have posted this on another thread, but I did an "impulse buy" of the Baofeng UV-12 for $15.50 from AliExpress. It is basically the Ham Radio version of their FRS radio and it is open to transmit on MURS. I have not found the Baofeng CPS programming software to download yet, but using the Retevis RB27 template on Chirp works to program this radio with my FTDI USB to K-1 programming cable. Of course it does not qualify for MURS under FCC rules, but it is an option nonetheless. Quote
bobbo784 Posted February 1 Report Posted February 1 On 11/29/2024 at 11:48 AM, FishinGary said: I have a Radioddity MU-5 that I like so far. I might get a Smiley Stick for it. I had a Btech MURS V2 that I returned, because I just wasn't happy with it. It was actually not a bad radio, but I just didn't care for the lack of a dedicated WX mode and the fact that you had to turn it off and on to switch between channel and VFO mode. The lack of scanning in VFO mode was the deal-breaker for me. These aren't really reasons you buy a MURS radio, but I like having them and when they aren't present or they don't function the way I think they could I can't help but think there are better options. Finally someone mentioned these awesome radios for MURS.I use mine all the time,cheap to buy and great quality.Radioddity also has a GMRS version that is amazing. FishinGary 1 Quote
UncleYoda Posted February 1 Report Posted February 1 What type of antenna connection does the MU-5 have? Quote
ecbatesiii Posted February 2 Report Posted February 2 I just purchased Retevis RB17V (https://www.retevis.com/rb17v-2-watt-5-channel-murs-radio-2-pack-us) and I think they comply with FCC MURS part 95 since each radio only has 5 MURS channels and no way of setting tones that I can figure out. Great battery 4400mAh. Quote
WRUU653 Posted February 2 Report Posted February 2 1 hour ago, ecbatesiii said: no way of setting tones that I can figure out It’s done using the software. Quote
FishinGary Posted February 9 Report Posted February 9 On 2/1/2025 at 3:26 PM, UncleYoda said: What type of antenna connection does the MU-5 have? SMA-M UncleYoda 1 Quote
WRTC928 Posted February 11 Report Posted February 11 Are there any MURS radios that will let you have more than 5 memory slots? I'd like to have the option to have one bank with tones enabled and one without. It seems like the makers of MURS radios never anticipated that. Quote
wrci350 Posted February 11 Report Posted February 11 1 hour ago, WRTC928 said: Are there any MURS radios that will let you have more than 5 memory slots? The Radioddity MU-5 has 20 slots so you can definitely have with and without tones. One thing to note is that slots 6-20 are just the five MURS frequencies repeated three times so you can't (for example) have 151.820 with 8 different tones, but you could have each frequency with no tone and then three more times (each) with a CTCSS or DCS tone. WRUU653 and SteveShannon 2 Quote
WRTC928 Posted February 11 Report Posted February 11 4 hours ago, wrci350 said: The Radioddity MU-5 has 20 slots so you can definitely have with and without tones. One thing to note is that slots 6-20 are just the five MURS frequencies repeated three times so you can't (for example) have 151.820 with 8 different tones, but you could have each frequency with no tone and then three more times (each) with a CTCSS or DCS tone. Well, that's not bad. It seems unlikely I'd ever want more than 4 iterations of the same channel anyway. Quote
wrci350 Posted February 12 Report Posted February 12 The Wouxon KG-805M has 128 slots and looks like you can program the same MURS frequency as many times as you want. I would have included that in my ealier reply but I had to charge mine first ... some of the Wouxun radios (including the KG-805M) are notorious for having a parasitic battery drain when stored. I think the Baofeng Tech MURS-V2 will let you do what you want as well, but I don't seem to have the programming software installed, the download from the BTech site is broken and won't install, and I don't feel like installing CHIRP so I cannot test on the one I have. WRUU653 1 Quote
SteveShannon Posted February 12 Report Posted February 12 54 minutes ago, wrci350 said: some of the Wouxun radios (including the KG-805M) are notorious for having a parasitic battery drain when stored. Slip the battery off the radio when stored. Quote
wrci350 Posted February 12 Report Posted February 12 46 minutes ago, SteveShannon said: Slip the battery off the radio when stored. Exactly ... but you shouldn't have to do that. SteveShannon and Jaay 2 Quote
nokones Posted February 17 Report Posted February 17 I have several HT1000s, one XTS1500 model II, and two XTS5000 model IIIs and no cheap POS radios from Pandaland. gortex2 1 Quote
HHD1 Posted March 12 Report Posted March 12 On 12/7/2021 at 10:39 AM, Lscott said: Other than the few purposed built radios for MURS what other radios have people used for the service? Baofeng Ar-5RM WSAA635 1 Quote
Jaay Posted March 12 Report Posted March 12 Lately, I've tried MURS on my Wouxun KG-935H and it works Very well ! HHD1 1 Quote
WSAA635 Posted Thursday at 08:02 PM Report Posted Thursday at 08:02 PM I set all my radios up with the 5 MURS channels in case I need to use them. Quote
WRTC928 Posted Thursday at 08:38 PM Report Posted Thursday at 08:38 PM On 2/1/2025 at 6:02 PM, ecbatesiii said: ...each radio only has 5 MURS channels and no way of setting tones that I can figure out. That's a deal-breaker for me. I ordered one (a Retevis IIRC) a while back that did have the ability to set codes, but it was limited to 5 channels, so I sent it back. I want to have a set of channels "wide open" and at least one other set with tones. Quote
Lscott Posted Friday at 01:26 AM Author Report Posted Friday at 01:26 AM 4 hours ago, WRTC928 said: That's a deal-breaker for me. I ordered one (a Retevis IIRC) a while back that did have the ability to set codes, but it was limited to 5 channels, so I sent it back. I want to have a set of channels "wide open" and at least one other set with tones. Real certified MURS radios are a bit hard to find. However there are plenty of old Part 90 radios that can be made to "work", depending on one's definition, with the right programming. The main issue is the power level. For HT's it's usually 1 watt on low and 5 watts on high. MURS allows only 2 watts ERP. I started this thread some years back asking the question. Interesting answers I got were old Part 90 radios programmed to meet frequency, bandwidth and power spec's were OK if the radios were certified BEFORE MURS was created. I'll bet a fair number of people are using old Part 90 radios, same with MARS/CAP mod'ed Ham gear, at 5 watts. Might find the occasional "mobile" at 50 watts. Oops, people don't really do that do they? Quote
LeoG Posted Friday at 02:26 AM Report Posted Friday at 02:26 AM So 1 watt with a 3dB gain antenna. Quote
Lscott Posted Friday at 03:54 AM Author Report Posted Friday at 03:54 AM 1 hour ago, LeoG said: So 1 watt with a 3dB gain antenna. That's about it. Quote
WRYS709 Posted 6 hours ago Report Posted 6 hours ago On 7/31/2025 at 1:02 PM, WSAA635 said: I set all my radios up with the 5 MURS channels in case I need to use them. Don’t forget: MURS 1-3 are narrowband FM. Quote
WSAA635 Posted 4 hours ago Report Posted 4 hours ago 1 hour ago, WRYS709 said: Don’t forget: MURS 1-3 are narrowband FM. Yep. Also, all the Public Safety channels I scan are NB as well. Quote
WRYS709 Posted 3 hours ago Report Posted 3 hours ago 32 minutes ago, WSAA635 said: Yep. Also, all the Public Safety channels I scan are NB as well. Yes, but scanning (receiving) does not require a NB preset. Transmitting on MURS 1-3 does. Quote
