reaper Posted March 23, 2022 Report Posted March 23, 2022 I am just curious about the usefulness of 900mhz ht rigs. What kind of range can you expect and power output question i see 1 watt it there any thing more. Quote
axorlov Posted March 23, 2022 Report Posted March 23, 2022 Motorola DLR 1030 and 1060 give me less range than 4W Kenwood TK-3170. Not by much, though. In urban environment I'd say maybe 75% of range I'm getting from TK-3170. I still did not have a chance to compare good GMRS to DLR radios in the mountains. marcspaz 1 Quote
Radioguy7268 Posted March 23, 2022 Report Posted March 23, 2022 The Motorola 900 MHz digital FHSS radios are great for in-building coverage. They work pretty well outdoors in the open also. 1 watt is a little misleading when comparing them to "full power" UHF 4 or 5 watt portables. Transmit power is only useful if it overcomes the noise floor that you're trying to transmit over. Where those 1 watt 900 MHz FHSS radios shine, is that they have an effective receive signal level that's down in the -125 dBm range. Your typical UHF portable is lucky if it's beginning to receive anything at -119 dBm (and even if it does, then it's probably quite scratchy). So the 900 MHz radio comes in at better than a 6 dB winner in the receive category. Search that up on the dBm to Watts conversion scale, and you'll see that your UHF portable would need to transmit a decent signal at 4 watts or more just to begin achieve comparable performance - while the 900 MHz radio is hopping frequencies to avoid interference, plus pushing out a digital signal that's intelligible even at the very threshold of receive. Forget comparing horsepower numbers. In the radio world, you need to compare receivers. That's where the magic is happening. Watts are for salespeople and marketing types. PACNWComms, WRUK803, WRPD494 and 1 other 4 Quote
BoxCar Posted March 23, 2022 Report Posted March 23, 2022 13 minutes ago, Radioguy7268 said: Forget comparing horsepower numbers. In the radio world, you need to compare receivers. That's where the magic is happening. Watts are for salespeople and marketing types. The best receiver won't do anything if there isn't enough power in the transmission to activate it. It take all three, power, sensitivity and an effective radiator. Quote
Lscott Posted March 24, 2022 Report Posted March 24, 2022 On 3/22/2022 at 11:58 PM, axorlov said: Motorola DLR 1030 and 1060 give me less range than 4W Kenwood TK-3170. Not by much, though. In urban environment I'd say maybe 75% of range I'm getting from TK-3170. I still did not have a chance to compare good GMRS to DLR radios in the mountains. What kind of range were you getting with the TK-3170 at 4 watts? Quote
axorlov Posted March 24, 2022 Report Posted March 24, 2022 Red lines are two DLR-1060 talking to each other, blue lines are two TK-3170 talking to each other. Test was done at the same time: I was riding bicycle with DLR and TK in my bag, while friend was sitting at the picnic table in the park. Table is located in some sort of depression, about 5", so the result on the flat ground could be better. The housing situation on the north and on the east are dense. There are small lots, 4000-6000 sq ft, not bigger. Housing is one- and two-story. Some two-story multi unit apartments. Quote
axorlov Posted March 24, 2022 Report Posted March 24, 2022 Another example of two TK-3170 talking to each other. Note, there is no line of sight. I was walking on the shore trail from NW toward SE. Trail is low, near the water and follows all landscape features. Friend was walking on the same trail toward NE, descended from the point on the E down to the water. We had communications broken only few times, when either me or my friend were deep in the shore canyons. There was never a direct line of sight between the radios. But thanks for the reflection and refraction of the 462MHz in mountainous terrain communications were reliable for the most part of the travel. Quote
gman1971 Posted March 25, 2022 Report Posted March 25, 2022 On 3/23/2022 at 4:01 PM, BoxCar said: The best receiver won't do anything if there isn't enough power in the transmission to activate it. It take all three, power, sensitivity and an effective radiator. Power is always limited, the antenna cannot always be changed, so, given equal power and a similar radiator, a better receiver will always beat a lesser one. The DLR 900 vs TK UHF range similarities hints me that there might be a good 6-7 dBm difference in noise threshold between the two bands. Surprising how well these DTR/DLR radios work given the limited amount of power they have. G. Quote
Lscott Posted March 25, 2022 Report Posted March 25, 2022 3 hours ago, gman1971 said: Power is always limited, the antenna cannot always be changed, so, given equal power and a similar radiator, a better receiver will always beat a lesser one. The DLR 900 vs TK UHF range similarities hints me that there might be a good 6-7 dBm difference in noise threshold between the two bands. Surprising how well these DTR/DLR radios work given the limited amount of power they have. G. That might be a good illustration of free space “path loss”, due to the capture area of the antenna at 900 being less that at 460. https://en.wikipedia.org/wiki/Free-space_path_loss gman1971 1 Quote
WRPC505 Posted June 5, 2022 Report Posted June 5, 2022 (edited) It's nice to see this particular topic; I'm looking to add 900 MHz to my radio arsenal, either ham or license-free. I need all the information I can get. Warren, WRPC505 / WQ1C Edited June 5, 2022 by WRPC505 Correction to show I'm only researching at this time. Quote
wayoverthere Posted June 5, 2022 Report Posted June 5, 2022 13 minutes ago, WRPC505 said: It's nice to see this particular topic; I'm looking to add 900 MHz to my radio arsenal, either ham or license-free. I need all the information I can get. Warren, WRPC505 / WQ1C About to go down the rabbit hole myself, both in terms of 33cm, and my first Motorola (waiting on a xpr6580, been eyeing Kenwood mobiles too). http://kw902.com/ has a fair bit of info for Kenwood, while batlabs has some on that side of the coin. Seems to be lots of info on the 900mhz xprs. WRPC505 1 Quote
WRPC505 Posted June 5, 2022 Report Posted June 5, 2022 28 minutes ago, wayoverthere said: About to go down the rabbit hole myself, both in terms of 33cm, and my first Motorola (waiting on a xpr6580, been eyeing Kenwood mobiles too). http://kw902.com/ has a fair bit of info for Kenwood, while batlabs has some on that side of the coin. Seems to be lots of info on the 900mhz xprs. I checked out the KW902 page that you suggested; definitely lots of info there. I'm not in a rush at this point, but my reasoning for looking into this is also 33cm and perhaps the ISM stuff. I'll acquire a couple of units eventually; it's a matter of convincing the wife that it's another way of communicating if need be (which it is). wayoverthere 1 Quote
wayoverthere Posted June 5, 2022 Report Posted June 5, 2022 31 minutes ago, WRPC505 said: I checked out the KW902 page that you suggested; definitely lots of info there. I'm not in a rush at this point, but my reasoning for looking into this is also 33cm and perhaps the ISM stuff. I'll acquire a couple of units eventually; it's a matter of convincing the wife that it's another way of communicating if need be (which it is). Yeah, the ism ones are nice for that. I've seen reports that those work well on cruise ships too. WRPC505 1 Quote
TNFrank Posted Wednesday at 09:54 PM Report Posted Wednesday at 09:54 PM The Radtel RT-900 is suppose to do 33cm and is only $25 for the non-bluetooth model. I have one on order and I'll try to post a video to my YouTube channel. It might be worth picking one up to play around with. Quote
BoxCar Posted Thursday at 01:48 AM Report Posted Thursday at 01:48 AM 3 hours ago, TNFrank said: The Radtel RT-900 is suppose to do 33cm and is only $25 for the non-bluetooth model. I have one on order and I'll try to post a video to my YouTube channel. It might be worth picking one up to play around with. Takes 2 to play because of range/power. Quote
Lscott Posted Thursday at 01:57 AM Report Posted Thursday at 01:57 AM 3 hours ago, TNFrank said: The Radtel RT-900 is suppose to do 33cm and is only $25 Looked it up. Tops out at 520MHz. The RX around 300MHz might be useful. Military air communications use frequencies in that range. For $25 don’t expect good performance. I’m about 20 miles west of Selfridge Air National Guard Base here in Michigan. https://www.airforcetimes.com/news/your-air-force/2025/04/29/trump-announces-new-fighter-jet-mission-at-michigan-air-base/ For a few years my folks had a house on a canal going to Lake Saint Clare just a couple blocks south of the entrance to Metro Park. You could stand in their back yard and watch the military flights taking off and landing all day long. Would have been cool to monitor the radio traffic that’s not encrypted. Quote
TNFrank Posted Thursday at 07:45 PM Report Posted Thursday at 07:45 PM 17 hours ago, Lscott said: Looked it up. Tops out at 520MHz. The RX around 300MHz might be useful. Military air communications use frequencies in that range. For $25 don’t expect good performance. I’m about 20 miles west of Selfridge Air National Guard Base here in Michigan. https://www.airforcetimes.com/news/your-air-force/2025/04/29/trump-announces-new-fighter-jet-mission-at-michigan-air-base/ For a few years my folks had a house on a canal going to Lake Saint Clare just a couple blocks south of the entrance to Metro Park. You could stand in their back yard and watch the military flights taking off and landing all day long. Would have been cool to monitor the radio traffic that’s not encrypted. I have one and it WILL do 33cm/900MHz, trust me. You set it to "Super Mode" and you can do from 18MHz to 999MHz. It only says "Dual Band" on the web site but it'll do 10M, 6M, 2M, 1.25M, 70cm, 33cm, CB FM, MURS and GMRS and alot of other Frequencies in between. Quote
Lscott Posted Friday at 04:24 AM Report Posted Friday at 04:24 AM 8 hours ago, TNFrank said: I have one and it WILL do 33cm/900MHz, trust me. You set it to "Super Mode" and you can do from 18MHz to 999MHz. It only says "Dual Band" on the web site but it'll do 10M, 6M, 2M, 1.25M, 70cm, 33cm, CB FM, MURS and GMRS and alot of other Frequencies in between. If you can put it on a scope and frequency counter to verify that. Then the next test is output power. That I expect to suck. Trying to design a tuned power amp stage to have that kind of bandwidth is going to cost a lot more than $25. I know many people thought their D878’s could do 1.25M since they could program in the frequencies. However the real results at the antenna port just wasn’t there to make it worth the trouble. Quote
TNFrank Posted Friday at 04:38 AM Report Posted Friday at 04:38 AM My Surecom will only test up to 525MHz so I can't get a power reading at 900MHz but I did test all the other frequencies. There's plenty of videos on YouTube about the RT-900 you can watch and I plan on doing one tomorrow to post to my channel. I'm also getting some properly tuned antennas for 900MHz to use because nothing I currently have is tuned for that frequency. Also, without actually getting one you can't just presume that it's junk. It's actually worked very well at 2M, 1.25M and 70cm hitting repeaters over 20 miles away with the Nagoya 320a antenna I have on it. I'd say pick one up and give it a try, what have you got to loose? At the most you've dropped $25 bucks on something that will work on several different bands and would be a good beater radio to keep in the truck or as a back up to your other radios. Quote
Lscott Posted Friday at 02:08 PM Report Posted Friday at 02:08 PM 9 hours ago, TNFrank said: My Surecom will only test up to 525MHz so I can't get a power reading at 900MHz but I did test all the other frequencies. There's plenty of videos on YouTube about the RT-900 you can watch and I plan on doing one tomorrow to post to my channel. I'm also getting some properly tuned antennas for 900MHz to use because nothing I currently have is tuned for that frequency. Also, without actually getting one you can't just presume that it's junk. It's actually worked very well at 2M, 1.25M and 70cm hitting repeaters over 20 miles away with the Nagoya 320a antenna I have on it. I'd say pick one up and give it a try, what have you got to loose? At the most you've dropped $25 bucks on something that will work on several different bands and would be a good beater radio to keep in the truck or as a back up to your other radios. For $25 you won't get the performance you expect. There are other things you should look at such as RX sensitivity, de-sense, channel isolation, spectrum free from harmonics, spur response, frequency accuracy and stability etc. Most people don't have the equipment to do these kinds of tests. If you know somebody with a good quality commercial radio grade service monitor I would stick the radio on it and run some tests. Some decent used ones run around $1K plus used. I believe one of the members of this forum got a used one in this price range a while back specifically for testing his radios and repeaters. A few that can do auto tune up, radio calibration, and digital mode testing can run over $10K to $20K plus used. For example the cheap, $25, Baofeng UV-5R early version had dirty transmitters. They were multi-band radios. You could talk on several all at the same time! I'm not knocking your desire to do a video on the radio. But remember you give people the idea the radio is the best thing since sliced bread, people buy them because they're cheap, and now the local bands have issues with crappy signals on the air. UV-5R VHF Harmonics Test.pdf Quote
TNFrank Posted Friday at 06:24 PM Report Posted Friday at 06:24 PM See my video on the RT-900 in the Equipment Review section on the Forum. At 2M and 70cm I'm able to hit a Repeater on the White Tank Mts. at over 20 Miles away with a 3" antenna from a Suburban Area with trees, houses, etc. I'm sure this radio will work well enough for folks to dip their toe into other Bands to see if they want to invest more in a "Higher End" radio but for me on my tight budget this one will be just fine. SteveShannon 1 Quote
TNFrank Posted Friday at 08:43 PM Report Posted Friday at 08:43 PM Update on 33cm/900MHz. I now have 2 of these radios and while they do seem to TX on that Frequency there's no RX on either. Not sure if it's a firmware issue(since there is newer firmware out for them) or what but all the other Frequencies work just fine. No matter what the manufacture states they will do all the other Frequencies that I stated except 33cm/900MHz. Here's the proof. SteveShannon 1 Quote
TNFrank Posted 6 hours ago Report Posted 6 hours ago I did get TX and RX on 902.200MHz with the 3" stubby. This guy also got 33cm/900MHz to work but the power out put HD got was very low. So, the RT-900 WILL do 33cm but not very well. Quote
