WRQC290 Posted June 13, 2022 Report Posted June 13, 2022 On 6/12/2022 at 6:46 AM, WRQI583 said: many hams over the years and probably more so regular civilians World peace is possible if we just keep hammering home the fact that these are not separate groups. DeoVindice and Blaise 2 Quote
Lscott Posted June 13, 2022 Report Posted June 13, 2022 22 hours ago, WRKC935 said: Naaa, I think we have similar jobs and see similar silliness. But, I think you were missing my point. If someone modifies a commercially sold ham radio that is 'type accepted' for ham use under part 97, and you cut the block out of it and transmit on some other service, be it commercial LMR, public safety pool or even GMRS, it's illegal because it's not a type accepted radio for that service. Service being controlled by another part of the FCC regulations. We are 95, ham is 97, commercial is 90.x for SMR and 90.y for public safety. Anything is pretty much legal on ham (part 97) as long as it's spectrally pure enough and below the maximum power level for the band it's on. Of course, GMRS and SMR are not that way, the radios have to be tested and accepted for the specific service they are operated on. GMRS there is little enforcement and there is a lot of lee-way. Not that the LMR is closely watched either, but there is more enforcement there than GMRS or ham. The key point was “transmit”. You can have a radio programmed for other services which it’s not certified for by the FCC. Just as long as you don’t use the PTT button you should be fine. I believe some countries just having the wrong frequencies programmed in your not licensed to use, just RX only, is a violation of their radio regulations. Some foreign Hams visiting are shocked to discover here in the US it isn’t against the law. I think we’re lucky here, it could be changed by Congress at anytime. Ham radios are only certified for Part 15. The FCC’s concern is the ability to intercept cell phone transmissions. They also check for transmitter spurious emissions. There are limits the radios can’t exceed. That’s one of the major complaints about the low end CCR, cheap Chinese radios, like the much hyped UV-5R. The attached file shows a test somebody did on a sample. Also the schematic, source claims it for the above radio but I can’t confirm it, shows just some basic filtering on both the RX and TX paths. Both files are what I have in my technical library folder for this radio. I haven’t taken the time to see if there is anything more recent available. UV-5R VHF Harmonics Test.pdf SCHEMATIC Baofeng UV-5R.pdf WROC838 1 Quote
WRKC935 Posted June 14, 2022 Report Posted June 14, 2022 OK, so part 15 and not 97..... I am good with that. To the statement about radio programming, I know at least one local city that has a law on the books that no one can have a radio programmed for their system. It doesn't limit ownership, just the programming in the radio. And I doubt they are the only place that's got that sort of law. And yes, I know the funky bowel (Baofeng) radios are crap and have crap signal. They 'work' in some applications. I do know that taking one 200 feet in the air even in a rural area, 30 miles from the nearest large city makes the receiver in them go bonkers. But, when your receiver will listen from DC to daylight, that's sort of what you should expect. Quote
Lscott Posted June 14, 2022 Report Posted June 14, 2022 8 hours ago, WRKC935 said: To the statement about radio programming, I know at least one local city that has a law on the books that no one can have a radio programmed for their system. It doesn't limit ownership, just the programming in the radio. And I doubt they are the only place that's got that sort of law. I wonder if that law has been challenged in court? As I mentioned before you can program a radio for frequencies you're not authorized so long as you don't transmit on them. Back when over the air pay TV was the "thing" a lot of people built decoders to interface to their TV's in my area. I had one, built on a solder less breadboard. One of the services simply transmitted their signal on a microwave band and used a down converter connected to the TV, no scrambling or encryption. People were building simple two transistor converters in coffee cans or put up a simple BBQ grill type antenna on the roof with the simple down converter on the back. Radio Shack was selling the strip-line transistors. You could get the PCB layout and circuit off the fairly new Internet at the time. The company had teams driving around looking for those antennas and taking people to court. I don't believe they were very successful claiming theft of service since they did nothing to protect the signal from interception and use. I think the major legal option was if it's transmitted over the air there is NO expectation of privacy. The two companies using different methods soon went out of business. It was way to easy to get the programming for free. WROC838 1 Quote
SteveShannon Posted June 14, 2022 Report Posted June 14, 2022 Here’s the FCC page that discusses “intercepting and divulging” communications. https://www.fcc.gov/consumers/guides/interception-and-divulgence-radio-communications It’s interesting how it’s written. It appears that the FCC has a very narrow range of options available to them. For instance, listening to cellular conversations isn’t prohibited, but the law prohibits the FCC from authorizing equipment that provides the ability. My search also found that some places do attempt to limit ownership of police scanners. In some cases they prohibit using scanners in the commission of a crime. In other cases they simply prohibit civilian possession. I suspect a good lawyer could defeat those simple possession laws, but of course that costs money. WROC838 1 Quote
WRPC505 Posted June 14, 2022 Report Posted June 14, 2022 13 hours ago, WRKC935 said: OK, so part 15 and not 97..... I am good with that. To the statement about radio programming, I know at least one local city that has a law on the books that no one can have a radio programmed for their system. It doesn't limit ownership, just the programming in the radio. And I doubt they are the only place that's got that sort of law. Would that city be located in Virginia? That state has some of the most restrictive monitoring laws I've ever seen. Warren, WRPC505 / WQ1C WROC838 1 Quote
wayoverthere Posted June 14, 2022 Report Posted June 14, 2022 3 hours ago, Sshannon said: My search also found that some places do attempt to limit ownership of police scanners. In some cases they prohibit using scanners in the commission of a crime. In other cases they simply prohibit civilian possession. When I was stopped by LE not too long ago "for the trailer ball obstructing the license plate," both officers separately asked if the radios in my truck were police scanners (icom 2730 and anytone at779uv). WROC838 1 Quote
BoxCar Posted June 14, 2022 Report Posted June 14, 2022 I believe Maryland has a law against using a police scanner in a motor vehicle. The law is on the books to protect motorists from pirate tow truck drivers and companies responding to assistance calls by the police. The motorist also has to affirm to the police officer they accept the uninvited tow operator over the police contracted service, wayoverthere 1 Quote
Lscott Posted June 14, 2022 Report Posted June 14, 2022 25 minutes ago, wayoverthere said: When I was stopped by LE not too long ago "for the trailer ball obstructing the license plate," both officers separately asked if the radios in my truck were police scanners (icom 2730 and anytone at779uv). Best advise I've heard is ensure the radio(s) are turned OFF when you're stopped. Some Hams have had their legitimate radios confiscated by stupid LEO's that don't know the law, particularly about exemptions for Ham radio license holders. If they can hear public safety traffic audio they could convince a judge they had "reasonable suspicion" a crime was afoot etc. Other than providing the required documents specified by the state's MVD you don't have to answer any of the LEO's questions. They are not trained communication professionals. While they still may take the radio(s) at least in court you can make the claim they had no expertise to make any determination as to the nature of the "device" they saw. Might even have recourse to recover damages. WRPC505, WROC838 and wayoverthere 2 1 Quote
WRFP399 Posted June 14, 2022 Report Posted June 14, 2022 On 6/11/2022 at 2:23 PM, WRQC290 said: @Lscott , I'm an internet certified armchair lawyer specializing in Bird Law, so I can say with authority that intentionally interfering with public safety communications has zero to do with spectrum allocations and everything to do with creating an imminent threat to the public at large. IMHO such a case wouldn't get dismissed and the argument could be made that local criminal court is the only appropriate venue in this instance. The only question this raises in my mind, is can the fcc go after a person for improperly using radio equipment in violation of the terms of their license, while at the same time locals prosecute the separate crime of interfering with public safety without creating a double jeopardy situation? If not, despite the federal supremacy clause - the stricter penalty for the criminal act, state law would reign supreme and negate FCC's jurisdiction anyway, no? Alaska Statute: AS 11.46.475. Criminal Mischief in the First Degree. (a) A person commits the crime of criminal mischief in the first degree if, having no right to do so or any reasonable ground to believe the person has such a right, (1) the person intentionally damages an oil or gas pipeline or supporting facility; (2) with intent to cause a substantial interruption or impairment of a service rendered to the public by a utility or by an organization that deals with emergencies involving danger to life or property, the person damages or tampers with property of that utility or organization and causes substantial interruption or impairment of service to the public; (3) with intent to damage property of another by the use of widely dangerous means, the person damages property of another in an amount exceeding $100,000 by the use of widely dangerous means. (b) Criminal mischief in the first degree is a class A felony. Quote
wayoverthere Posted June 14, 2022 Report Posted June 14, 2022 12 minutes ago, Lscott said: Best advise I've heard is ensure the radio(s) are turned OFF when you're stopped. Some Hams have had their legitimate radios confiscated by stupid LEO's that don't know the law, particularly about exemptions for Ham radio license holders. If they can hear public safety traffic audio they could convince a judge they had "reasonable suspicion" a crime was afoot etc. Other than providing the required documents specified by the state's MVD you don't have to answer any of the LEO's questions. They are not trained communication professionals. They both dropped it after I told them "no, that one is ham radio, and this one is gmrs". That scanners don't generally have microphones would sort of support the 'lack of expertise' kind of thinking. that I don't have any public safety stuff in the scan list of either one probably isn't a bad thing either. Lscott and WROC838 2 Quote
Lscott Posted June 14, 2022 Report Posted June 14, 2022 1 hour ago, WRFP399 said: Alaska Statute: AS 11.46.475. Criminal Mischief in the First Degree. (a) A person commits the crime of criminal mischief in the first degree if, having no right to do so or any reasonable ground to believe the person has such a right, (1) the person intentionally damages an oil or gas pipeline or supporting facility; (2) with intent to cause a substantial interruption or impairment of a service rendered to the public by a utility or by an organization that deals with emergencies involving danger to life or property, the person damages or tampers with property of that utility or organization and causes substantial interruption or impairment of service to the public; (3) with intent to damage property of another by the use of widely dangerous means, the person damages property of another in an amount exceeding $100,000 by the use of widely dangerous means. (b) Criminal mischief in the first degree is a class A felony. That I can believe could be a charge. It's not an area FCC had jurisdiction over, since their area is spectrum management and licensing. Quote
WRQC290 Posted June 15, 2022 Report Posted June 15, 2022 7 hours ago, wayoverthere said: both officers separately asked if the radios in my truck were police scanners Wonder what would happen if you said "yes, and your LED strobes are causing RF interference, please turn them off"? wayoverthere, Raybestos and WRPC505 1 2 Quote
Lscott Posted June 15, 2022 Report Posted June 15, 2022 1 hour ago, WRQC290 said: Wonder what would happen if you said "yes, and your LED strobes are causing RF interference, please turn them off"? They take your radio. Problem solved. Quote
WRQC290 Posted June 15, 2022 Report Posted June 15, 2022 2 minutes ago, Lscott said: They take your radio. Problem solved. No, no, no. You just have to flash your hambadge then they'll know you outrank them and must stand down. Blaise, Raybestos, WROC838 and 1 other 2 2 Quote
WRFP399 Posted June 15, 2022 Report Posted June 15, 2022 7 hours ago, WRQC290 said: No, no, no. You just have to flash your hambadge then they'll know you outrank them and must stand down. Na dude...those badges are only for the direction finding task force agents of the ARRL. Raybestos 1 Quote
Lscott Posted June 15, 2022 Report Posted June 15, 2022 9 hours ago, WRQC290 said: No, no, no. You just have to flash your hambadge then they'll know you outrank them and must stand down. Just wear your CERT, RACES and ARES hats. If that doesn't work tell the LEO you won't be making that annual donation to the policeman's association, yeah the one that calls you up several times a year on the phone. Raybestos and WROC838 2 Quote
Blaise Posted June 15, 2022 Report Posted June 15, 2022 On 6/13/2022 at 11:40 PM, WRKC935 said: I know the funky bowel (Baofeng) radios are crap and have crap signal. They 'work' in some applications. I do know that taking one 200 feet in the air even in a rural area, 30 miles from the nearest large city makes the receiver in them go bonkers. Can you please expand on this statement? I have several, and have used them at altitudes from 30 - 3000 feet (mostly listening for satellites), and have never experienced anything I would remotely classify as "going bonkers". Are you saying they can receive more signals at altitude? And if so, why wouldn't that be expected? WROC838, WRPG745 and WRTU454 3 Quote
back4more70 Posted June 15, 2022 Report Posted June 15, 2022 12 hours ago, WRQC290 said: No, no, no. You just have to flash your hambadge then they'll know you outrank them and must stand down. It reminds me of the morons who buy the concealed carry weapons badges. Too funny. WROC838 1 Quote
WROZ250 Posted June 15, 2022 Report Posted June 15, 2022 12 hours ago, WRQC290 said: No, no, no. You just have to flash your hambadge then they'll know you outrank them and must stand down. Bootlegged Badge! That call does not come back to John Smith! LOL! Quote
WRKC935 Posted June 16, 2022 Report Posted June 16, 2022 12 hours ago, Blaise said: Can you please expand on this statement? I have several, and have used them at altitudes from 30 - 3000 feet (mostly listening for satellites), and have never experienced anything I would remotely classify as "going bonkers". Are you saying they can receive more signals at altitude? And if so, why wouldn't that be expected? They would start hearing frequencies other than the one it was tuned to. Would get intermod, hear paging transmitters (High power but not overly close) And at times loose the ability to hear a transmitter on the tuned frequency. We figured this was due to the first RF stage being swamped with RF due to a total lack of filtering. Now scanners will do the very same thing, at least the inexpensive ones because they are designed to hear everything everywhere. Quote
gman1971 Posted June 16, 2022 Report Posted June 16, 2022 @WRKC935 These radios are, AFAIK, all direct conversion receivers. So, there should be no first stage like a classical dual conversion superheterodyne. When the external signals exceed the "bandwidth" it has to reduce gain to fit everything within the bandwidth, otherwise you'll hear a cacophony of intermod mess. A tracking filter that would allow for such DC to daylight listening capabilities would be far more expensive that can be fitted on a $9.95 Baofeng (overpriced to cost x5 times that sadly)... The HF ICOM radios that have these type of sweet tracking filters cost like $3500-$13000... so... there is that. You can help these CCRs with a preselector, or a cavity, it will be good enough, but portability and some sensitivity will be lost... so... that is one tradeoff. G. WROC838 1 Quote
WRTF739 Posted June 18, 2022 Report Posted June 18, 2022 good point, i dont think ill ever get my tech lic for ham radio no real need too gmrs is just that good. Dont need beam 1000 miles away when I got my squad a couple of meters. Quote
tep182 Posted August 24, 2022 Report Posted August 24, 2022 On 6/12/2022 at 1:21 AM, WROZ250 said: To be sure, I am not advocating anyone break the rules, but I will say that worrying, for example, if your GMRS radio is part 95e compliant isn't worth worrying about. Thanks. Most people generally want to follow rules that are reasonable and rational. For example, "this product may cause cancer in California". A warning sticker is cheaper than playing the certification pirates' shakedown game. Other certifications may not be a scams to protect big business from competition or generate revenue. People might be more inclined to be good neighbors if they were told about "spurious emissions" instead of "part 95e". Perhaps there is a YouTube channel that demonstrates how Baofeng is ruining the bands... and not just speculation about potential harm. Other hobbies also cultivate elite fanatics that despise cheap functional versions. Also some hams seem so afraid of an Eternal September... they nearly killed their hobby. Maybe Baofeng is the next America Online floppy. There are more E. coli outbreaks caused by USDA-certified facilities than Amish farms. WRPG745 and WROC838 2 Quote
KAF6045 Posted August 25, 2022 Report Posted August 25, 2022 3 hours ago, tep182 said: For example, "this product may cause cancer in California". A warning sticker is cheaper than playing the certification pirates' shakedown game. When I lived in Sunnyvale, I always wanted to purloin a Prop 65 warning sign and put it on my apartment door. After all, I had a dozen tins of air-gun pellets (LEAD!), a few thousand rounds of pistol&rifle ammo (more LEAD!), Winsor&Newton drawing inks (FORMALDEHYDE!), acrylic and oil paints (CADMIUM! Chromium! other similar compounds), paint solvents (and not just turpentine and acetone, but methyl ethyl ketone (MEK) ). tep182 and DeoVindice 2 Quote
