I've read 'til my head aches, but still can't find an answer. Can someone set me straight?
I'm trying to spec a base-station, and I'm looking at the '50 Watt' requirement. As near as I can tell, virtually none of the commercially available GMRS transmitters really output 50 watts. It's usually somewhere between 45 and 48, from what I see. But even if they *did*, antenna cable and connector losses seem like they're going to eat a minimum of 10% of your power, even over fairly short runs, so really, there's no hope of ever transmitting anywhere *near* the 50 watt limit, and realistically you'll be closer to 40 watts.
Now I realize that transmission power is less important to range in this band than antenna placement, gain, etc., but all other variables being equal, if I'm not mistaken, transmitting with 25% more power is going to get you as much as 11% more range and 25% more coverage area. That's a lot more than nothing!
Is this just a loss GMRS operators accept, or is there more to it? Are folks using amps to bump their unit's output power up over 50 watts to make up for losses? Is there a trick to this that I'm missing?
Blaise
15 answers to this question
