WRUT470 Posted October 11, 2022 Report Posted October 11, 2022 I’m a new member and just recently got my GMRS license. I understand how repeaters work but my questions are: 1. If the repeater says OPEN SYSTEM do you need permission to use it? I see a tab that says request access even though both the input and output tones are shown. 2. How far can a GMRS 5W HT radio go to hit a repeater? 3. Just to be sure, I would need to input both tones to be able to hear and receive communication? Thanks in advance for your help! WRUU925 and WRYK451 2 Quote
OffRoaderX Posted October 11, 2022 Report Posted October 11, 2022 Welcome! #1: No.. If they publish the tones, that means they want everyone to see them #2: "It depends".. you can expect anywhere from 1/2 mile to 80 miles #3: You only need the TX/Encode tone (the one you transmit) to use the repeater. The RX/Decode only makes it so you only hear traffic from the repeater and not kids down the street talking on simplex, etc. WRYK451, WRUU653 and WRUU925 2 1 Quote
WRUT470 Posted October 11, 2022 Author Report Posted October 11, 2022 This is exciting thank you for answering me! Quote
MichaelLAX Posted October 11, 2022 Report Posted October 11, 2022 Looks like these are open to you: Kazoon 725 156.7 Open-700 100.0 Brooklyn (may be too far) Try asking for permission on SquidNet 650 and Lemon Creek 700 and KeasbeyNJ 700 Quote
drk1970nj Posted October 11, 2022 Report Posted October 11, 2022 Kazzon is dead Lemon creek doesn’t respond Brooklyn probably will and mine you can either get on via zello or request through mygmrs Sent from my iPhone using Tapatalk Quote
WRUT470 Posted October 11, 2022 Author Report Posted October 11, 2022 I really appreciate all the help and information you guys gave me! I am just getting into GMRS so I have a lot to learn and helpful people like you make it easier! Thanks drk1970 I will send request! drk1970nj 1 Quote
drk1970nj Posted October 15, 2022 Report Posted October 15, 2022 Anytime Sent from my iPhone using Tapatalk Quote
WRUW275 Posted October 19, 2022 Report Posted October 19, 2022 Hi, new member here also, I've programmed a couple repeaters near me that show TX and RX tones are needed however, the only way I could open/connect with one was to remove the RX tone. (Could hear the squelch(?) response from the repeater) Why is this? Does the RX tone mute the repeater response. Thanks Quote
drk1970nj Posted October 19, 2022 Report Posted October 19, 2022 Hi, new member here also, I've programmed a couple repeaters near me that show TX and RX tones are needed however, the only way I could open/connect with one was to remove the RX tone. (Could hear the squelch(?) response from the repeater) Why is this? Does the RX tone mute the repeater response. Thanks Sometimes owners put tones on both ends do to interference from other repeaters local or distance repeaters on the same frequencies if it’s listed to put a receive tone in and tx that will be the only way to get into the repeater or hear the repeater….I do not have a receiving tone on this one so others can hear it on the frequency as far as transmit it is toned .Referring to mygmrs is your best tool Sent from my iPhone using Tapatalk Quote
gortex2 Posted October 20, 2022 Report Posted October 20, 2022 You do not need a RX Tone" in your radio but will hear other repeaters or users on that frequency. I run all my channels with csq or no ton. You only need the tone to trigger the repeater so tx on your radio. The repeater may have no hang time also which would not open up your radio after talking. None of mine are set for hang time. Mainly to eliminate users "kerchunking" and i see no reason for the hang. If in monitor mode or carrier squelch you will hear the repeater after the tone drops on 2 of them. Quote
SteveShannon Posted October 20, 2022 Report Posted October 20, 2022 12 hours ago, WRUW275 said: Hi, new member here also, I've programmed a couple repeaters near me that show TX and RX tones are needed however, the only way I could open/connect with one was to remove the RX tone. (Could hear the squelch(?) response from the repeater) Why is this? Does the RX tone mute the repeater response. Thanks If you couldn’t hear the repeater until you removed the receive tone, chances are you had the wrong tone programmed. A receive tone acts a little like a bandpass filter. If you set a receive tone your squelch only opens up for transmissions that include that tone. If you remove the receive tone you receive all transmissions on that frequency, regardless of which tone they transmit. It’s like having three friends: Alice, Bob, and Charlie. Alice transmits and receives using tone A. Bob transmits and receives using tone B. Charlie transmits and receives using tone C. When you want to talk to Alice, you must transmit using tone A; neither Bob nor Charlie hear you. Likewise, if you transmit using tone B, only Bob hears you. Same for Charlie; he only hears what is transmitted using tone C. You can hear each one individually by setting your receiver to their individual tone, but if you want to hear all of them, you must leave your receiver set to no tone. Quote
WRUU925 Posted October 20, 2022 Report Posted October 20, 2022 On 10/11/2022 at 5:20 PM, WRUT470 said: I really appreciate all the help and information you guys gave me! I am just getting into GMRS so I have a lot to learn and helpful people like you make it easier! Thanks drk1970 I will send request! Thank you for asking this question I am also new at this and just got my license and a Wouxun kg 935g. Quote
WRUT470 Posted October 20, 2022 Author Report Posted October 20, 2022 Glad it helped you out! I have a Wouxun also. Did you find the 935 to be beginner friendly? I am currently researching a mobile set up. I keep reading on the forum to help me learn. Quote
WRUW275 Posted October 20, 2022 Report Posted October 20, 2022 A lot of great information here, thanks so much for the replies. Still a little muddy on understanding but sure it will clear up as I learn more. Quote
MichaelLAX Posted October 20, 2022 Report Posted October 20, 2022 [Repeater] -- [Transmit Frequency] [Receive Frequency] | | [Transmit Tone] [Receive Tone] You want to transmit on the Repeaters Input Receive Frequency 467.550 - 467.725 with the needed Receive Tone so that the Repeater will receive your transmission and then re-transmit it on the Repeaters Output Transmit Frequency 462.550 - 462.725. Some Repeaters also add a Tone to their retransmission of your transmission, Transmit Frequency, but it is optional for users of this Repeater to set their receive tone to be able to hear the Repeater. It's a bit confusing but your GMRS transmit frequency is set to 467.550 - 467.725 with the needed Tone, and your GMRS receive frequency is set to 462.550 - 462.725 with the Tone being optional and usually recommended to be no Tone until perhaps you are satisfied that all is working well. WRUU653 and SteveShannon 2 Quote
