First off, I did all the research and thought I should be able to fool the software (CE59 V4.01 USA) by backdating to 2010 as was mentioned here. The software did accept W5 and I was able to upload it to the radio just fine. It would transmit as it should, but it will not receive at all. I found if I go back in the software and select N both receive and transmit work as it should. I just can't get this to wide band. Radio has Firmware V1.85.
I found a copy of (CE59 V2.24w) which supposed to be export software and loaded that and it did the same as above whether I back dated or used the current date. I'm not sure if this is pilot error and I'm overlooking something stupid or is there something in the radio's firmware preventing wide band? I know the radio is designed for narrow band due to FCC rules, but from what I've read people have been successful at using this radio on the ham bands or GMRS. Any help would be greatly appreciated. Thanks.
tcp2525
Link to comment
Share on other sites
11 answers to this question
