Got two new Wouxun KG-S88G handhelds. Super het receivers. Reception seems to depend heavily on the exact position of the radio. If I place it HERE then it's great, full-scale reception of the repeater. If I move it a few inches over to THERE, reception can go to near 0, sometimes not even breaking the squelch (set at 1, where 0 is open). If I move it around a foot or so further, it may suddenly become great again. If it stays put where the reception is great, it stays great. Both radios behave the same, either with the stock antennas or the 15" Nagoya GMRS-tuned antennas. Two radios, four antennas, all do this.
This testing is being done on the 2nd story of a house with aluminum siding. Faraday cage with windows, possibly bouncing signals all over the place inside.
Meanwhile, the cheap FRS Midlands receive almost anywhere, and usually better than the Wouxuns. When one of the new units are placed in a good spot then they best the FRS, but most places the FRS best the superhets.
Handheld transmission does make it into the local-ish repeater and I got a successful radio check, although that was down the street while sitting in the Jeep with fibreglass top, not from inside the house.
In testing between both new radios from across the subdivision, the new radio did hear better than the FRS. When I went further away to where reception was lost and switched to the mobile unit at 15W, inside the house the FRS received the mobile better than the new Wouxun. But my wife admitted that the new unit may not have been exactly upright, and the 15" whip was installed at the time. Angle of antenna? Perhaps keep the stock antennas for a more wide-angle dispersion at the expense of range?
So do I have two bad radios, or is this a characteristic of superhet receivers, or perhaps are the FRS designed for hyper-sensitivity at the expense of selectivity, for example?
bd348
21 answers to this question
