Do operators keep a common log of contacts?? Is there a common log book used??
WRQC301
I have tried to keep a log of contacts that I have made. But wish I had software that would keep contacts somewhat organised.
Any and all help is much appreciated.
Thank you, Dennis   WRQC301
4 answers to this question
With GMRS generally being a "bring your own contacts" type of service, I doubt there is anything geared directly towards it.  However, I would assume you can simply use a traditional logbook or use an application from the amateur service, such as N3JFP, and just log it as any band you want. 70cm/UHF would be the closest option.
I found this online
https://www.businessformtemplate.com/preview/Amateur_Radio_Station_Log
It's available in .doc format
Any word processor that reads & writes .doc files will let you edit the file to your needs &/or wants
Or you can just design your own using tables in a word processor [that's what I did]
The fields that I have are: name - call sign - QTH - repeater [that I spoke with them on] - notes
Or a spreadsheet will probably work also
Whatever works best &/or easiest is up to the user, you can always change it or update it later on
73
