kidphc Posted March 8, 2023 Report Posted March 8, 2023 Found there wasn't much info on the signal stalk. So might as well put it up for people to see. First off, the signal stalk installed. Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Uncut Laird b4505cns.Swr sweep.Always impressed with this antenna. It was mounted in the same place the signal stalk was located.Sent from my SM-S901U using Tapatalk marcspaz 1 Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Just now, marcspaz said: Where is it? Sadly hidden and blened in with the telephone pole. Retaking the photo. marcspaz 1 Quote
marcspaz Posted March 8, 2023 Report Posted March 8, 2023 52 minutes ago, kidphc said: Sadly hidden and blened in with the telephone pole. Retaking the photo. Ah! Cool. I'm looking on my phone and my near vision isn't great, even with glasses. New picture looks great! I can't like anything else today. Such an odd limitation. kidphc 1 Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Initial swep of the uncut signal stalk measures 20".About 2.5 swr at 467.725 Mhz. 1.75 swr down at 440Mhz.Sent from my SM-S901U using Tapatalk Quote
SteveShannon Posted March 8, 2023 Report Posted March 8, 2023 3 minutes ago, marcspaz said: I can like anything else today. Such an odd limitation. It’ll reset during the day. It is an odd limitation. Paying for premium membership was almost worth it just for that! WRUU653 and marcspaz 2 Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Cut off a hair more than an inch (1") whip measurement 19"..446 Mhz (national 70cm calling Swr was at 1:1.4 swr.472.7250 Mhz ch22 repeater input the Swr was at 1:1.49 swr.450 Mhz swr (target mid band) was at 1.08 Swr.Note: weird curly q in the Smith chart. Never seen that before.Sent from my SM-S901U using Tapatalk Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 No. Signal reports as of today, just got it installed.Btw. Don't run out and buy one just yet. It is a 2m 1/4 wave and 3/4 wave 70cm antenna.3/4 have a weird radiation pattern and a take off angle of about 60‐70 degrees.So who knows, how this will work in the real world.I should of have taken 2m sweeps but failed to. I really wanted an antenna taller than the 1/4 for 70cm p25 and gmrs, i was also hitting the 1/4 wave in some garages. 2m was not a consideration, so I didn't even bother.Because of the garage/tree thing I started searching for nintinol antennas. 2 came up signal stalk and sti flexi ( about 2x the price).The sti was ruled out for the first round due to the cost and the cut chart would of had it back at 1/4 wave for gmrs/70cm. Might still try it in the future. Going to look at my buddy Seth's sti antenna to see if it is more flexible.** the signal stalk is flexible. But no where near a signal stick. You will not be able to loop a signal stalk like a signal stick. I think you can loop the Sti (will check when I get the chance).*** DO NOT try to trim with cutters. I recommend a bolt cutter or cut off wheel. Even my pneumatic cutting off wheel at the shop took some time to cut through it. On the order of 5-10 seconds. Usually, it will go through a steel whip in 2 seconds.Sent from my SM-S901U using Tapatalk WRUU653 1 Quote
marcspaz Posted March 8, 2023 Report Posted March 8, 2023 I am going to be north-bound in about 40 minutes. If you send me a text with some repeater info, I can help with signal reports. When I get to my office, depending on what you're running, we may be able to do simplex testing to. Let me know if you don't find anyone local to you. Quote
marcspaz Posted March 8, 2023 Report Posted March 8, 2023 48 minutes ago, Sshannon said: It’ll reset during the day. It is an odd limitation. Paying for premium membership was almost worth it just for that! It's working again! SteveShannon and kidphc 2 Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Unfortunately, at work. So I"ll just do the signal test as I use it normally. Thanks though marcspaz 1 Quote
WRUU653 Posted March 8, 2023 Report Posted March 8, 2023 45 minutes ago, Sshannon said: It’ll reset during the day. It is an odd limitation. Paying for premium membership was almost worth it just for that! I have been considering this as I always feel like I’m not giving recognition where it’s deserved. back to signal stalk tuning SteveShannon and kidphc 2 Quote
gortex2 Posted March 8, 2023 Report Posted March 8, 2023 Not much different than the Sti Co Super flex whips. kidphc 1 Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Not much different than the Sti Co Super flex whips. Well minus the price. For $40 vs the usual 80-100Sent from my SM-S901U using Tapatalk wayoverthere 1 Quote
SteveShannon Posted March 8, 2023 Report Posted March 8, 2023 15 minutes ago, kidphc said: Well minus the price. For $40 vs the usual 80-100 Sent from my SM-S901U using Tapatalk Plus Signal Sticks are made in the USA by the guy who also runs HamStudy. kerstuff, wayoverthere, WRQC527 and 2 others 5 Quote
WRQC527 Posted March 8, 2023 Report Posted March 8, 2023 Two thumbs up from me for the Signal Stick. Best HT antenna I've had, if you don't mind the length. Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Two thumbs up from me for the Signal Stick. Best HT antenna I've had, if you don't mind the length. Agreed. Been happy with mine. Part of the reason I was willing to try a signal stalk.Of course, little things like signal stick (3d printed antenna connection) not being finished (layer lines from 3d printing) let you know it is a small operation. On the signal stalk the ferrule to the nmo doesn't match the colors of the nmo base.Sent from my SM-S901U using Tapatalk Quote
wayoverthere Posted March 8, 2023 Report Posted March 8, 2023 4 minutes ago, kidphc said: Agreed. Been happy with mine. Part of the reason I was willing to try a signal stalk. Of course, little things like signal stick (3d printed antenna connection) not being finished (layer lines from 3d printing) let you know it is a small operation. On the signal stalk the ferrule to the nmo doesn't match the colors of the nmo base. Sent from my SM-S901U using Tapatalk Theyve moved over to an injection molded base on the signal sticks within the last couple of batches (bought a sma male one in black around black Friday last year), it's a nicer finish now. They also appear to be using glow in the dark tips on all of them, irrespective of color, which is a nice touch. kidphc 1 Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Theyve moved over to an injection molded base on the signal sticks within the last couple of batches (bought a sma male one in black around black Friday last year), it's a nicer finish now. They also appear to be using glow in the dark tips on all of them, irrespective of color, which is a nice touch.Yeah mine had a glow in the dark tip. But 3d printed base. Nice to know they are making changes. Especially, with the warranty if something happens you get a replacement.Lifetime warranty doesn't apply to the stalk antenna. But he sells replacement parts.Sent from my SM-S901U using Tapatalk wayoverthere 1 Quote
kidphc Posted March 8, 2023 Author Report Posted March 8, 2023 Not much different than the Sti Co Super flex whips. I thought the sti flexi was more flexible. Well I thought by some of the pictures.Is it about the same?Sent from my SM-S901U using Tapatalk Quote
wayoverthere Posted March 8, 2023 Report Posted March 8, 2023 1 hour ago, kidphc said: Yeah mine had a glow in the dark tip. But 3d printed base. Nice to know they are making changes. Especially, with the warranty if something happens you get a replacement. Lifetime warranty doesn't apply to the stalk antenna. But he sells replacement parts. Sent from my SM-S901U using Tapatalk My first one was full glow in the dark, so I wasn't sure when they spread those tips across the range Quote
gortex2 Posted March 9, 2023 Report Posted March 9, 2023 15 hours ago, kidphc said: I thought the sti flexi was more flexible. I've laid the sti co almost flat to the roof out of the NMO and it didn't damage it. Its made for mobile abuse. I use them on the SXS and Gators now as its more durable than the 1/4 wave stainless. kidphc 1 Quote
kidphc Posted March 9, 2023 Author Report Posted March 9, 2023 ***Initial signal reports. Usual route i take home. So a fair comparisons, since I know where the holes are for spotty or weak coverage. With the Signal Stalk, most reports were scratchy and having background noise on transmit. I was also getting hashing on receive. The dip around the Morman temple was reported as really really bad copy. As a comparision,the usual reports when using the Laird B4505 CNS were like sitting in the room next to me, clean as a base station. The dip around the Morman temple usually reported with this antenna as scratchy with sometimes a drop out. Quote
marcspaz Posted March 9, 2023 Report Posted March 9, 2023 It sounds like a step back, if I am reading it right. Do you feel it's close, or are you not happy? Quote
