Newbie Trying to Program UV-5G & UV-9G to Repeaters
I have received permission to use three repeaters in my area. Now I have to program my radios. Should I use CHIRP or the radio itself? I've seen a lot of YouTube videos but they all were for the HAM version UV-5R. Any guidance would be appreciated.
9 answers to this question
It's very easy to program a repeater on a GMRS radio vs a ham radio.  I always like to get started by learning how to program on the radio so I understand how it works, then when I want to program a lot of repeaters, I'll use CHIRP.
Programming a repeater on a GMRS radio literally requires only ONE entry:  Just select the correct repeater channel, and enter the TX/Encode CTCSS/DCS tone, and you're done.  Optionally, when your ready to get fancy, you can enter the RX/Decode tone.
I have been accepted to 3 repeaters, but I must be doing something wrong because I still cannot talk to anyone.
On 10/6/2023 at 11:44 PM, Sshannon said:
Agreed, but without knowing exactly what you’re doing it’s impossible to help.
I am trying to get used to this forum. Is there a way to direct message you?
There sure is.  At the top of the screen is a bell and envelope (that’s somewhat platform dependent).  Clicking on the envelope allows you to send PMs.
Or you can go to someone’s profile and click “Message”.  I’ll send you a message so you can simply reply if that’s easier.
Repeater: FM 462.575MHz, Input/Output 69.3Hz Used CHIRP to input it into a Baofeng UV-5G. Results silence.
Sorry, I was busy typing up a reply to your PM. I just hit send.
You must use channel 24 on the UV-5G.  That sets the transmit frequency to 467.575 MHz.  For repeaters in GMRS, there's always a 5 MHz offset.
Second, for testing I usually recommend leaving the receive code empty.  That allows all transmissions on that frequency to be heard.
Several people have reported that the UV-5G only transmits in memory mode.
Good luck!
Steve
