I've got a couple Wouxon KG-XS20g's coming and I'm planning on making one into a base station for the house. I'm going to mount a GMRS single band antenna to the peak of our two story house (IF I can get a second ladder that will straddle the lower peak...) and route that cable into the garage where the base station will live. I've measured and the run will be 43ft total, so I figured I'd get a nice round 50 footer. All of my research suggests the oft recommend LMR400 should be the go to, but I have a few questions I'm hoping you folks can put to rest for me. I likely wouldn't get times microwave but one of the house brands from DX engineering or USA Coax...
Â
1. Has anyone here used USA Coax (MPD Digital)Â and can speak to their in house brand cable? I'm looking at the MPD400 ultraflex. DX engineerings website says they're 50ft wont be in stock until 12/28/23...
2. The antenna comes with an N female connector, the radio comes with an SO-239 (I believe that's the name), I can get MPD Digital to custom make me a cable with the correct ends (N male and PO-259) for a good price (I feel) BUT... should I go this route or get N male on both ends and use a small patch cable at the radio? My gut says the less connections/adapters the better, but lots of folks seem to like to use the patch cables at the radio side.Â
3. The way I'd like to route the cable would be best with a 90* plug coming off the antenna, however I have read on here to avoid 90's. Is this true for my situation or are we talking more along the lines of connecting 2x 50ft cables with a 90 adapter in the middle that's bad?Â
4. Solder or crimped ends? MPD offers both, I myself am in IT and have made and pulled literal miles of ethernet in my time, always crimped with great conductivity even up to 10Ghz, however I also do a lot of electronics repair/development work and will take a soldered connection over a crimped any day of the week. My guess would be that the individual making the cable at MPD would be capable of doing both. Is there a benefit to one over another if they had the tools and experience to do both correctly? I've seen comments on here that folks prefer crimped, I'm guessing that's if DIYing the cable?
5. I live in the PNW and it rains 6 months out of the year here. I know the N connector is "Water resistant" but I'm wondering about further water proofing, I have some decent shrink tubing that could put over the connector at the antenna, otherwise I could silicone the ish out of the exterior of the connector, I have some proper 33+ electrical tape I could wrap it in, but I wanted something a bit more permanent.Â
KBSherwood
Hello everyone,
Â
Comments/opinions?Â
Thank you very much!
6 answers to this question
