WRZH564 Posted November 5, 2023 Posted November 5, 2023 Chirp downloads; however, will not open. Â Anyone else having problems opening Chirp on iMac? Quote
1 OffRoaderX Posted November 6, 2023 Posted November 6, 2023 Thats exactly how its supposed to look... So, you do not have  File|Edit|View|Radio  menu options in the far, upper-left of your screen? (SCREEN, not WINDOW) ? Like this?:  WRUU653 1 Quote
0 WRYZ927 Posted November 5, 2023 Posted November 5, 2023 Download the .exe file and you will solve your problem. Â Quote
0 WRUU653 Posted November 5, 2023 Posted November 5, 2023 8 minutes ago, WRZH564 said: Chirp downloads; however, will not open. Â Anyone else having problems opening Chirp on iMac? macOS Intel and Apple Silicon macOS, but requires installation of Python 2.7Â this is what worked for me. Quote
0 WRUU653 Posted November 5, 2023 Posted November 5, 2023 5 minutes ago, WRYZ927 said: Download the .exe file and you will solve your problem. that's for windows is it not? WRXB215 1 Quote
0 OffRoaderX Posted November 6, 2023 Posted November 6, 2023 30 minutes ago, WRUU653 said: that's for windows is it not? Correct. He has no idea what he is saying so he can be safely ignored. Make sure you are downloading the MacOS version - go here:Â https://trac.chirp.danplanet.com/chirp_next/next-20231031/ As mentioned it *might* need Python installed but IIRC, that is not necessary with the new "Chirp Next" version.. But I could be wrong. If so, you can safely ignore me. WRYZ926, WRYZ927, WRUU653 and 1 other 2 2 Quote
0 WRYZ926 Posted November 6, 2023 Posted November 6, 2023 27 minutes ago, OffRoaderX said: Correct. He has no idea what he is saying so he can be safely ignored. Make sure you are downloading the MacOS version - go here:Â https://trac.chirp.danplanet.com/chirp_next/next-20231031/ As mentioned it *might* need Python installed but IIRC, that is not necessary with the new "Chirp Next" version.. But I could be wrong. If so, you can safely ignore me. I did not have to install Python to get CHIRP Next to work on my 2018 Mac mini with the Intel chip. The Windows exec file definitely will NOT work on a Mac without running Windows in Parallels or on a virtual machine. WRXB215 1 Quote
0 WRYZ927 Posted November 6, 2023 Posted November 6, 2023 Yeah, my apologies, I missed the apple part.  @OffRoaderX, be more douchy if you can. It really helps! Quote
0 OffRoaderX Posted November 6, 2023 Posted November 6, 2023 8 minutes ago, WRYZ927 said: @OffRoaderX, be more douchy if you can. It really helps! It does help to make online experts think twice before they tell people completely wrong information.  If that makes me douchy, then I'll drink another glass of vinegar... WRYZ927 and fe2o3 2 Quote
0 OffRoaderX Posted November 6, 2023 Posted November 6, 2023 1 hour ago, WRZH564 said: Chirp downloads; however, will not open. Â Anyone else having problems opening Chirp on iMac? For clarification - does the .ZIP file not open? Or, does the Zip file open, but then the application wont open? Â For either response, what happens? Do you get any errors? If so, what do they say? Quote
0 WRYZ927 Posted November 6, 2023 Posted November 6, 2023 7 minutes ago, OffRoaderX said: It does help to make online experts think twice before they tell people completely wrong information. Â If that makes me douchy, then I'll drink another glass of vinegar... You should really make it a double. Â Cheers! Quote
0 WRZH564 Posted November 6, 2023 Author Posted November 6, 2023 56 minutes ago, OffRoaderX said: For clarification - does the .ZIP file not open? Or, does the Zip file open, but then the application wont open? Â For either response, what happens? Do you get any errors? If so, what do they say? Hey Randy, and thanks for trying to help. Â The file dumps into my "downloads" folder. Â When I double click it to open, the attached image is all I see. Â Can navigate anywhere from that point. Â Douchy...LOL. Quote
0 WRUU653 Posted November 6, 2023 Posted November 6, 2023 38 minutes ago, WRZH564 said: Hey Randy, and thanks for trying to help. Â The file dumps into my "downloads" folder. Â When I double click it to open, the attached image is all I see. Â Can navigate anywhere from that point. Â Douchy...LOL. That's what you will see when you open the program. Now hook up your radio and select download from radio and choose your radio make and model from the drop down menu at the top of your screen . Â WRHS218 1 Quote
0 WRUU653 Posted November 6, 2023 Posted November 6, 2023 2 minutes ago, OffRoaderX said: Like this? Haa, lol what he said. You are quick SteveShannon 1 Quote
0 WRZH564 Posted November 6, 2023 Author Posted November 6, 2023 14 minutes ago, OffRoaderX said: Thats exactly how its supposed to look... So, you do not have  File|Edit|View|Radio  menu options in the far, upper-left of your screen? (SCREEN, not WINDOW) ? Like this?:   Quote
0 WRZH564 Posted November 6, 2023 Author Posted November 6, 2023 Thank you for the help. Â I'm up and running. OffRoaderX and WRUU653 2 Quote
0 WRZH564 Posted November 6, 2023 Author Posted November 6, 2023 OffRoaderX, you knew exactly how I failed, didn't you? Quote
WRZH564
17 answers to this question
