Do I need to manually set it? I tried changing it and I just the very irritating "Cancel " message when I hit the menu to confirm as you would normally working with the menu items. It just says cancel and doesn't save any value I put in there manually with the keypad on the radio.
My thinking was that the offset was the difference between the transmit and receiving frequencies with a repeater and had to be manually entered? Is this totally wrong as I'm sure it is?
The manual sucks. It says how to edit the offset but doesn't explain what to do manually if it cancels on you.. I tried doing exactly what the manual said which was press menu, then enter the number to get to the offset menu which is like 31 and then enter the offset and then press menu again. Did not work? Someone please tell me what I'm doing wrong?
WRZF693
Hi guys and gals..
I have a question or two about offset?
First, what it is and what is it used for?
Thanks so much in advance.. Nice forum..
Tim
10 answers to this question
