WRYF747 Posted December 16, 2023 Report Posted December 16, 2023 We know it's illegal to have cross-band repeaters on GMRS with the intention to use any said GMRS repeater channel as the downlink, but is it illegal to use the reverse method of this? Even on a trunking system as a patched talkgroup? Quote
Radioguy7268 Posted December 16, 2023 Report Posted December 16, 2023 Generally speaking, the FCC frowns on re-broadcasting from one service to another. If I understand your question, you would just want to hear what's going on with a GMRS group in a listen only mode? No ability to talk back? If so, then I'd say it would depend on what particular rules govern the service you are trying to patch into. I can tell you that most trunking system administrators would frown on anything that automatically keys up on the system & uses up airtime just from an Erlang vs. Grade of Service standpoint. Quote
WRYF747 Posted December 16, 2023 Author Report Posted December 16, 2023 15 hours ago, Radioguy7268 said: Generally speaking, the FCC frowns on re-broadcasting from one service to another. If I understand your question, you would just want to hear what's going on with a GMRS group in a listen only mode? No ability to talk back? If so, then I'd say it would depend on what particular rules govern the service you are trying to patch into. I can tell you that most trunking system administrators would frown on anything that automatically keys up on the system & uses up airtime just from an Erlang vs. Grade of Service standpoint. Well, not exactly. I'd like to have the ability to talk to my friends on the system while having it on a more private repeater. Also, this would belong to my system, not patched onto someone else. Quote
BoxCar Posted December 16, 2023 Report Posted December 16, 2023 Connecting the two different services would violate the regs. Quote
SteveShannon Posted December 16, 2023 Report Posted December 16, 2023 38 minutes ago, WRYF747 said: Also, this would belong to my system, not patched onto someone else. I’m not sure if I follow. I’m not going to speculate about the legality without fully understanding what you’re describing. It sounds like you want your friends to use GMRS handheld or mobile radios to talk to an GMRS repeater which is patched to another, more private system of some sort. What is that “more private system?” A diagram would be helpful. AdmiralCochrane and WRXB215 2 Quote
Radioguy7268 Posted December 17, 2023 Report Posted December 17, 2023 If I follow what you're asking, you would have radio users on one system (non-GMRS) with the ability to generate traffic on a GMRS repeater. It's not going to be legal. If you end up relaying their voice traffic from this 'private' system over to an analog GMRS repeater, I also question how 'private' the system would remain. You would be basically be wiretapping your own private system, and then broadcasting the audio over an open analog channel. WRXB215 and SteveShannon 1 1 Quote
