WRZD706 Posted December 27, 2023 Report Posted December 27, 2023 We are planning a trip from MI to AK this summer. How prevalent will the use of GMRS be on the route? I see that there are many repeaters in the US south of Canada and a few in AK. How does Canada handle GMRS? Do they also have repeaters? Is there a database of them if so? I am not intending to rely on GMRS for anything serious, but rather use it for road conditions ahead and entertainment to pass the miles by. Is CB a better service? Is there a mobile GMRS radio that can receive CB that I can convince my wife we need in the RV? Quote
BoxCar Posted December 27, 2023 Report Posted December 27, 2023 You need to check with Industry Canada (their FCC) for the regulations regarding use of your radios while in Canada. Amateurs are allowed to operate within the Canadian frequency allocations but many other users cannot. SteveC7010 1 Quote
SteveShannon Posted December 28, 2023 Report Posted December 28, 2023 GMRS radios in Canada must be 2 watts or less, marked “IC” (Canada’s FCC) and permanently attached antennas. There are no repeaters. WRUU653 1 Quote
WRQC527 Posted December 28, 2023 Report Posted December 28, 2023 5 hours ago, WRZD706 said: Is there a mobile GMRS radio that can receive CB As soon as I say no, someone here will spend the rest of the week trying to prove me wrong, so I'll say most likely no, even though there is no mobile GMRS transceiver that I've ever heard of that receives CB. Also, since there's no special regulations in Canada for CB use, you might have better luck with CB. Truckers tend to communicate road conditions with each other via CB, at least in my experience. Especially when the weather turns nasty. Quote
OffRoaderX Posted December 28, 2023 Report Posted December 28, 2023 4 hours ago, WRZD706 said: Is there a mobile GMRS radio that can receive CB that I can convince my wife we need in the RV? Not a mobile, its an HT, but the Wouxun's KG-Q10G is a GMRS radio that also receives CB.. So far, as of today the only one on the market. WRXB215 1 Quote
Lscott Posted December 28, 2023 Report Posted December 28, 2023 If you’re going to do any significant driving through the west side of Canada you may run into what are called “radio controlled roads” which are on VHF. That might be more of a use to you than the Canadian version of GMRS. Canada VHF LADD Channel List .pdf WRUU653 and WRXB215 2 Quote
Lscott Posted December 28, 2023 Report Posted December 28, 2023 If you're definitely using your GMRS radio in Canada then you should be aware of the Industry Canada, their FCC, rules. They are closely similar to the US FRS rules. Per the Annex E specifications GMRS radios in Canada are restricted to no more than 2 watts ERP, effective radiated power. That's a significant restriction. Canada GMRS-FRS Rules.pdf Canada FRS - GMRS Channels.pdf Canada Annex E - GMRS and FRS.pdf Quote
