Guest Mike S. Posted February 14, 2024 Report Posted February 14, 2024 My call signs was issued today so I can't yet join. I have a multi-piece through-hold NMO connector. How much should the barrel (or tip within the barrel) protrude from the threaded collar? I searched on-line and did not see an answer (except by buying the NMO spec). Quote
SteveShannon Posted February 14, 2024 Report Posted February 14, 2024 On 2/14/2024 at 5:22 AM, Guest Mike S. said: My call signs was issued today so I can't yet join. I have a multi-piece through-hold NMO connector. How much should the barrel (or tip within the barrel) protrude from the threaded collar? I searched on-line and did not see an answer (except by buying the NMO spec). Expand See if this helps: https://www.air802.com/files/CN2NMOLP-TM.pdf WRWE456 and WRXB215 2 Quote
gortex2 Posted February 15, 2024 Report Posted February 15, 2024 When installing an NMO you want the outside ring the same height or a bit lower than the center. On a standard mount thats how it should be. With a 3/8" style mount you want the center slightly above the brass ring. WRXB215 1 Quote
