Tidradio TD-H3 questions.
Ok, so I got my radio today and I've been setting it up using both the supplied software from Tidradio and the bluetooth app. With the factory software I couldn't see the headings of the columns but I managed a work around by taking a screenshot from a video of a guy using the software then using that to let me know what each column was. Factory software wouldn't let me add airband channels but the bluetooth app did.   It took me a while to figure out that you have to set the Scan function to "Add" or you can't change channels.
Now to the question. How can I skip channels that I don't want to scan and only scan the few that I do want? With the Baofengs using CHIRP it's easy, you just check the "Skip" box and you're good to go. There's no such box in either the factory software or the app. Thanks in advance.
12 answers to this question
If that's the case with the H3 I may just end up programing all my airband channels into it without GMRS and use it as an airband scanner.
Maybe a future firmware update will fix this.
OK, so I set up the radio, unlocked and AM "on" and programed all my local Airbands and added the 5 MURS channels so I'd have something to communicate with since the Airband antenna is rated for 100MHz to 300MHz and would be useless on GMRS frequencies. I guess this will just be my Airband/MURS radio which is fine since I've got a few others for GMRS and local Highway Patrol(scan only) to play with. All in all it seems like a solid little radio and I'd like to pick up an H8 10watt to play with when funds allow.
One thing also to note if you do eventually get an amateur radio lisence, that radio should do pretty well there especially at 10watts, as well. And in SHTF situations it's also good to program in the amateur call frequencies, because in the case of life or death I'd rather have as many options as possible.
To program skipped channels wirh Odmaster, select the channel you’d like to modify, go down to “Scan Add” and select “on” to scan that channel or “off” to skip.
Likewise, to program on the radio, in Menu #16 “Scan Add” select “on” to scan that channel and select “off” to skip.
If you are using CHIRP to program you can also just put an S in the Skip column (Second to last) for channels you dont want to scan
and as mentioned to do it in ODmaster or on the radio face...
On 2/29/2024 at 3:13 PM, WSAA635 said:
The H3 is only a 5 watt radio. The H8 is the 10 watt. I may pick one of those up as well to add to my collection. The H3 really feels like a well build radio but only time will tell.
To add to that...the H8 is 10 watts ONLY on VHF.
All the extra power will really do is shorten your battery life. Your range will not be significantly greater.  If you’re buried in vegetation it might help.
