Raptor1 Posted March 18, 2024 Report Posted March 18, 2024 01. How do you program a radio for a repeater that requires different DTCS codes for Tx and Rx? 02. Which radios support the programming of repeaters that have DTCS requirements for different DCS codes? Example: Tone Mode Setting: Split Tone > Encode Tx DCS (XXX) > Decode Rx DCS (YYY) Quote
OffRoaderX Posted March 18, 2024 Report Posted March 18, 2024 Is this a trick question? 1) Go into the settings for TX DTCS tone and enter it, then go into the settings for RX DTCS and enter that 2) Virtually all GMRS radios manufactured after 2017, and a large majority of ones manufactured before 2017.. The list of radios that do not support this is very small. Quote
Raptor1 Posted March 18, 2024 Author Report Posted March 18, 2024 Greetings Randy, Interestingly enough, my ICOM IC2730A only has one DCS point on it's programming menu to enter the single code data. As you already know, selecting the correct tone mode setting is also required. When I am using CHIRP or RT System programming software and I read from my ICOM IC2730A, I see a column titled DCS. I do not see anything titled DCS Tx or DCS Rx. Manual shows my ICOM IC2730A does support: • TONE: • TSQL: • DTCS: • TSQL-R: • DTCS-R: • DTC.OFF: • TON.DTC: I suspect my Icom IC2730A does not support Split Tone > DTC.DTC. I hope I am wrong. Quote
OffRoaderX Posted March 18, 2024 Report Posted March 18, 2024 There's your problem, right there.. The iCom IC2730A is not a GMRS radio.. Good luck! back4more70 and irishjerseyguy 2 Quote
Raptor1 Posted March 18, 2024 Author Report Posted March 18, 2024 Thank you. I've contacted ICOM support with the same question, it will be interesting to see their response. That's if I get one. Quote
WRXB215 Posted March 18, 2024 Report Posted March 18, 2024 Here is part of the description from DX Engineering: CTCSS and DTCS tones are built-in for quiet stand-by and repeater access. CTCSS split tone function allows you to set CTCSS tones separately for repeater uplink and downlink. A single DTCS code may be polarity reversed independently for repeater uplink or downlink. IC-2730A receivers cover 118-174 and 375-550MHz. Quote
gortex2 Posted March 19, 2024 Report Posted March 19, 2024 On 3/18/2024 at 1:41 AM, Raptor1 said: Thank you. I've contacted ICOM support with the same question, it will be interesting to see their response. That's if I get one. I am pretty confident the responce if you get one will be a copy of the user manual. As said its a HAM radio and not GMRS. To be quite honest this is what I use split tones (DPL and CTCSS) to keep all the ham and CCR crap off my repeaters. Radioguy7268 1 Quote
WRXB215 Posted March 19, 2024 Report Posted March 19, 2024 31 minutes ago, gortex2 said: To be quite honest this is what I use split tones (DPL and CTCSS) to keep all the ham and CCR crap off my repeaters. You're so mean. Quote
BoxCar Posted March 19, 2024 Report Posted March 19, 2024 Not really, you can have an easy $1500 to $2000 wrapped up in a good repeater's radio and antennas. Now let's guess about the power supplies. gortex2 1 Quote
