warthog74 Posted April 13, 2024 Report Posted April 13, 2024 Spent the afternoon ripping my dash apart. I had ordered an aftermarket stereo and mounting/wiring kit that arrived today. As i was putting the kit together i noticed the tray under the stereo looked tall enough and deep enough for my Leixen VV998 dual band radio. Sure enough, it fit nice and snug. I drilled out the back of the tray to run the coax and power cable, and made a few more holes for venting. The radio has a setting to use the microphone as a speaker so i didn't have to worry that i covered the internal speaker or find room to mount an external speaker. I think it looks good, and it sits flush with the stereo face plate. While i was at it i got rid of the mag mount, and finally installed the NMO hood mount. JBRPong and Hoppyjr 2 Quote
WRQC527 Posted April 13, 2024 Report Posted April 13, 2024 Nice. I was able to do the same thing in my Sienna with my FTM-7250 with the useless cubby. warthog74 1 Quote
WRXR255 Posted April 13, 2024 Report Posted April 13, 2024 The lady on top looks horrified, so im not sure its good. warthog74 1 Quote
WRQC527 Posted April 14, 2024 Report Posted April 14, 2024 30 minutes ago, WRXR255 said: The lady on top looks horrified, so im not sure its good. Could be his wife, now that she's seen what buying radios does to the bank account. WRXR255 and warthog74 2 Quote
Guest Posted April 14, 2024 Report Posted April 14, 2024 What antenna is that on the lip mount? Obviously it’s a no ground plane antenna? Quote
warthog74 Posted April 14, 2024 Author Report Posted April 14, 2024 2 hours ago, WRXR255 said: The lady on top looks horrified, so im not sure its good. Lol. That’s Alissa White-Gluz. Quote
warthog74 Posted April 14, 2024 Author Report Posted April 14, 2024 1 hour ago, WRXP381 said: What antenna is that on the lip mount? Obviously it’s a no ground plane antenna? Browning MURS / GMRS tuned antenna i got about 9 years ago before my original GMRS license expired. It came with a mag mount. I’m guessing it uses the metal from the vehicle for a ground plane. Here’s the Ebay Link. Quote
Guest Posted April 14, 2024 Report Posted April 14, 2024 11 minutes ago, warthog74 said: Browning MURS / GMRS tuned antenna i got about 9 years ago before my original GMRS license expired. It came with a mag mount. I’m guessing it uses the metal from the vehicle for a ground plane. Here’s the Ebay Link. I would just be concerned you’re not getting the greatest ground plane with that antenna mounted on the edge of the hood like that. Cb antennas would work fine that way but a uhf ground plane antenna usually would needs 12” min all the way around and to be above the cab/passenger compartment. It’s seams that may be a very front right heavy transmit and receive location. Quote
warthog74 Posted April 14, 2024 Author Report Posted April 14, 2024 It will have to due. So far it seems fine in my brief testing this afternoon. Not many options on a truck with a bed liner and tonneau cover and your garage door is only 7’ tall. At least it looks better than a mag mount tossed in the center of the hood. SteveShannon 1 Quote
tcp2525 Posted April 14, 2024 Report Posted April 14, 2024 Very nice install. If you have a GMRS radio with a detachable face you can always use the sunglass holder, which will fold up when not in use. I put the ham radio there and the GMRS in the center counsel storage. Both are hidden when not in use. warthog74, Hoppyjr and WRZK593 3 Quote
warthog74 Posted April 14, 2024 Author Report Posted April 14, 2024 Slick. Sadly no sunglasses holder as this truck has a sunroof. I thought about detaching the face of my TYT TH9800 and putting it in the tray if this didn’t work out, but glad it did. I like keeping the TYT in the house as a base unit. If something happens to the Leixen it’s only a $70 loss. It’s basically a glorified Baofeng HT in a mobile form factor, but it works well enough and is capable of 25w if needed. SteveShannon and WRZK593 2 Quote
nokones Posted April 14, 2024 Report Posted April 14, 2024 My clean install in my Jeep Wrangler Rubi with nothing being ripped apart. warthog74, tcp2525, SteveShannon and 1 other 4 Quote
nokones Posted April 14, 2024 Report Posted April 14, 2024 My clean install in my Chevrolet Silverado with nothing being ripped apart. Hoppyjr, SteveShannon and tcp2525 2 1 Quote
warthog74 Posted April 14, 2024 Author Report Posted April 14, 2024 Neat. Too much clutter for me personally. My dog would have drool splattered all over those electronics in the center console. tcp2525 1 Quote
tcp2525 Posted April 14, 2024 Report Posted April 14, 2024 15 hours ago, warthog74 said: Slick. Sadly no sunglasses holder as this truck has a sunroof. I thought about detaching the face of my TYT TH9800 and putting it in the tray if this didn’t work out, but glad it did. I like keeping the TYT in the house as a base unit. If something happens to the Leixen it’s only a $70 loss. It’s basically a glorified Baofeng HT in a mobile form factor, but it works well enough and is capable of 25w if needed. What make and model is your truck? I was assuming it is a newer F150, but I'm not rally sure. Mine is an older F150 with sun roof. Quote
warthog74 Posted April 14, 2024 Author Report Posted April 14, 2024 12 minutes ago, tcp2525 said: What make and model is your truck? I was assuming it is a newer F150, but I'm not rally sure. Mine is an older F150 with sun roof. It's an older ’06 F150 Lariat SuperCrew 4x4 with 237,000 miles on it. The rims are from a 2018 F150. Still runs like new. Hoppyjr 1 Quote
tcp2525 Posted April 14, 2024 Report Posted April 14, 2024 2 minutes ago, warthog74 said: It's an older ’06 F150 Lariat SuperCrew 4x4 with 237,000 miles on it. The rims are from a 2018 F150. Still runs like new. Very nice! I have a 2013 Limited. I finally upgraded to 20" wheels from a 2023 F150 after ruining two 22" rims from Baltimore potholes. I love the 20s and wished I did it sooner. warthog74 1 Quote
warthog74 Posted May 28, 2024 Author Report Posted May 28, 2024 Coming back to this, and a little off topic, but... I recently picked up a NIB Bear Tracker 885 CB/Scanner combo for a steal (half off suggested retail price) off of marketplace. Yes, it's a CB and it doesn't have NRC, SSB or FM, but i don't care. I wanted it for the p25 scanner capability, weather alerts, and bear tracker. Anyway, i removed the ashtray and made a custom mount. The radio just fit width-wise. Sadly i couldn't get it flush as there wasn't a lot of room behind the dash. At any rate, i like it. It's clean, and all wires are hidden. Hoppyjr 1 Quote
wrci350 Posted May 28, 2024 Report Posted May 28, 2024 Sweet. What are you doing for an antenna? Quote
warthog74 Posted May 28, 2024 Author Report Posted May 28, 2024 For the CB side i'm just using a plain jane 2' Diesel fiberglass whip on a hood mount. For the scanner the 885 came with a wire antenna with suction cups on the end. I ran it to the back window of my truck. I'm sure there are better ways to do it, but that stock wire antenna worked great this weekend picking up signals from 30-40 miles away, so i'll stick with it for now. Quote
nokones Posted May 28, 2024 Report Posted May 28, 2024 And my clean install of my GMRS Radio, CB Radio, Trail Navigation System, and Cellphone in my 23 Wrangler 2 Dr. " IZARUBICON". warthog74, SteveShannon and Hoppyjr 3 Quote
