WSCB609 Posted April 20, 2024 Posted April 20, 2024 467.625 uplink...(channel 20) ..uplink tone is D423. is this ctcss or dsc? I have a radioddity DB20-g radio. How do I set the uplink tone. The owners manual is useless ! Quote
0 OffRoaderX Posted April 20, 2024 Posted April 20, 2024 "uplink" = TRANSMIT any "D" tone = DCS/DTC/DPL So just select DCS/DTC tone D423 from the Transmit Tone menu whilst on the correct repeater channel, save it, and you're done. Should take no more than 15 seconds start to finish. PRO TIP! -- The numbers of CTCSS and DCS tones do not overlap, so if you ever aren't sure, just scroll through both menu options until you see the number you are looking for - it will only be in EITHER DTC or CTC, never both. SteveShannon, WSCB609, Raybestos and 3 others 4 2 Quote
0 nokones Posted April 20, 2024 Posted April 20, 2024 And any tone with a decimal point is a CTCSS/PL tone in Hertz i.e. 82.5, 110.9, and 123.0 and they are an analog tone. The numbers that have three digits with no decimal is a DPL/DCS and a digital code i.e. 047, 311, 445, and 754 and most cases identified with a "D" preceeding three numerical digits, and a suffix "N" or a Alpha character "I" (eye). The "N" for a non-Inverted digital code and the "I" for an Inverted digital code. The "N" and "I" codes are two different codes i.e. D723N or D723I (eye). WSCB609, WRUU653 and SteveShannon 2 1 Quote
0 WSCH851 Posted April 20, 2024 Posted April 20, 2024 2 hours ago, WSCB609 said: 467.625 uplink...(channel 20) ..uplink tone is D423. is this ctcss or dsc? I have a radioddity DB20-g radio. How do I set the uplink tone. The owners manual is useless ! WRUU653, WRHS218 and WSCB609 2 1 Quote
0 WSCB609 Posted April 21, 2024 Author Posted April 21, 2024 Thank you for all the answers ! This is going to be a great learning experience ! WRUU653 and SteveShannon 2 Quote
WSCB609
4 answers to this question
