LeoG Posted August 28, 2024 Posted August 28, 2024 1 hour ago, SteveShannon said: You weren’t talking about buying another random unit; you wanted BTech to send him one. Cept that first quote isn't me. Quote
SteveShannon Posted August 28, 2024 Posted August 28, 2024 2 minutes ago, LeoG said: Cept that first quote isn't me. You’re right. My mistake. Quote
LeoG Posted August 28, 2024 Posted August 28, 2024 3 minutes ago, SteveShannon said: You’re right. My mistake. I was wondering when I said something that could possibly get a cherry picked repeater. Now I understand. No biggee Steve. Stuff like that happens all the time. WRUU653 and SteveShannon 2 Quote
LeoG Posted August 28, 2024 Posted August 28, 2024 I sent an email to BTech to ask questions about the repeater. Figured I'd put the questions and then answers (below) up for everyone to see since it might be something someone would like to know. Hello, I have several questions I was wondering if you could answer about the RPT50 repeater. I've gone through the user manual that I downloaded from your website and I find some conflicting information between what the website says about the repeater and what the manual says. Also have some general questions about the repeater. 1.Is there a squelch for the receiver? I saw no mention of it in the manual. If there is no adjustable squelch what level is the squelch set at? Or is it only squelched by PL tones? 2.I assume it has full CTCSS and DCS tones for receive and transmit. Can it do split tones? ie: different tones for receive and transmit. Does the CW ID signal with tones or no tones, is it switchable? 3. What should the approx wattage output be using the duplexer (RX/TX Socket), most likely will be using 462.600MHz +5MHz? 4. The manual states DC power can be 13.8vdc +/-15% which is what I would consider a normal power supply. On the website it says 12 vdc +/-0.5v which is an odd voltage since any battery system is going to be 12.8v-13.2v nominal. Can the DC power input be used as a battery backup that switches over automatically during a power outage? Or is it just an alternate power supply to the internal 120 volt driven supply? 5. In the manual it says the handheld microphone is functional as a PTT microphone along with keypad for programming. One of the updates says this is only for programming. Is there an optional microphone that can be used for transmitting? Or is there no way to transmit from the repeater without using another radio to interact with it? 6. The manual says the unit has a volume control. Does this have a listenable receiver and a built in speaker to listen to incoming transmissions? 7. Does the repeater come with the latest updates installed? I only have a Win7 computer and I've heard the program only runs on a Win11 OS. Does that mean I won't be able to update or use the software to program the repeater? 8. On the CW ID system is it only a single set time to ID? Or can it be set to ID after 15 minutes of repeater activity and stay silent when there is no repeater activity. Does the ID have a busy function so it doesn't interfere with people talking and waits for a time when the repeater isn't busy? 9. Are the TX and RX sockets active which could be used with separate antennas with proper configuration if you don't want to use the internal duplexer? 10. Are there any plans to activate the 3 separate ports on the rear of the repeater? If so which ones and when might that happen? And then I got a response from Katy the next morning: Hey Leo, Thanks for reaching out with your detailed questions about the RPT-50 repeater! I’ll go through each one to clear up any confusion. 1. Squelch for the Receiver The RPT-50 repeater doesn’t have an adjustable squelch level in the traditional sense. It’s primarily squelched by CTCSS or DCS tones. This means it will only open the squelch when the correct tones are received. 2. CTCSS/DCS Tones and Split Tones Yes, the RPT-50 supports both CTCSS and DCS tones for transmit and receive. You can also set split tones, meaning you can have different tones for receive and transmit. The CW ID can be configured to transmit with or without tones, depending on your preference. 3. Approximate Wattage Output After the duplexer, you can expect an approximate output of around 45W. This is typical when using frequencies like 462.600 MHz with a +5 MHz offset. Make sure your power supply is stable and within the recommended voltage range to avoid any power-related issues. 4. DC Power Requirements and Battery Backup The manual indicates the power supply should be 13.8VDC ±15%, which is standard for many radios and repeaters. However, the website mentions a stricter 12VDC ±0.5V requirement. To clarify, we recommend using a power supply providing 13V to 13.5V, as this will ensure optimal performance without stressing the internal components. While the repeater can handle higher voltages for short periods, consistently using a higher voltage could potentially harm the duplexer. The DC power input can serve as a battery backup that switches automatically during a power outage, but it’s not designed as a primary power supply. 5. Handheld Microphone Functionality The handheld microphone that comes with the RPT-50 is primarily for programming purposes. It does not function as a PTT microphone for transmitting voice. Unfortunately, there isn’t an optional microphone available that can be used directly with the repeater to transmit. To transmit through the repeater, you must use another radio. 6. Volume Control and Built-In Speaker Yes, the RPT-50 repeater has a built-in speaker and a volume knob for received transmissions. You can listen to incoming transmissions directly from the repeater. 7. Firmware Updates and Software Requirements The repeater does not come with the latest updates installed, but to make any further updates or to program the repeater, you will need a Windows 10 or later computer. The software does not support Windows 7, so you might need to find a Windows 10 or 11 machine for future updates or programming tasks. 8. CW ID System Configuration The CW ID system on the RPT-50 is quite flexible. You can configure it to transmit an ID after a set period, like 15 minutes, following repeater activity, and you can set it to remain silent when there’s no activity. It also has a busy function that waits until the repeater is idle before transmitting the ID, so it won’t interrupt ongoing conversations. 9. TX and RX Sockets for Separate Antennas The TX and RX sockets are not active only the TX/RX antenna jack is used. 10. Activation of Rear Ports Currently, there are no confirmed plans or timelines for activating the three separate ports on the rear of the repeater. If there are future updates or plans, they will be announced through our official website or product manuals. WRNU354 and WRUU653 1 1 Quote
LeoG Posted March 18, 2025 Posted March 18, 2025 I think you said that you picked up another RPT50 to try, is that correct Randy? I was wondering if you got the V1.008R version which has the microphone activated for use as a base station. I got the update for the Mic Update and can't get my computer to interface with the repeater through the RJ45 jack using a USB to RJ45 bridge adapter. They said they would send me one but I found that I had one for my Wouxun radio to program it. Pretty sure they are the same thing as I checked in the Device Manager in Windows and it looks exactly like they describe it in the instructions. So now I'm waiting for their cable to come on Friday to see if mine is the issue or it's another problems to solve. Just curious if the newer versions are coming out updated from the factory. Quote
OffRoaderX Posted March 18, 2025 Author Posted March 18, 2025 9 minutes ago, LeoG said: I think you said that you picked up another RPT50 to try, is that correct Randy? I was wondering if you got the V1.008R version which has the microphone activated for use as a base station. https://youtu.be/AuCT-pSaCuw LeoG, WRNU354 and WSDM599 2 1 Quote
LeoG Posted March 18, 2025 Posted March 18, 2025 After watching your video. And next time please exclude the woman in the blue bathing suit... I see you still need to update the firmware yourself. It does not come factory updated. I find that disappointing because all new stuff should be at the current update unless you get it during the crossover period. I am having the issue of not getting the menu to show when in the CMD screen on the computer so I can't choose 1 (or 2, 3 or 5) because the command screen is blank other than the fluorescent green cursor. So I am waiting patiently for the cord they sent me to arrive. WSDM599 1 Quote
OffRoaderX Posted March 18, 2025 Author Posted March 18, 2025 2 minutes ago, LeoG said: I see you still need to update the firmware yourself. It does not come factory updated. I find that disappointing because all new stuff should be at the current update unless you get it during the crossover period. All of the new ones ship with the updated firmware - BTech gave me a choice of updated or not updated and I choose NOT-Updated so I could go through the process myself and complain about it if it was difficult/failed/whatever. SteveShannon 1 Quote
LeoG Posted March 18, 2025 Posted March 18, 2025 Ahhh, I see. Well so far my update is a no go. Quote
LeoG Posted March 20, 2025 Posted March 20, 2025 Can the CW ID be setup to stay silent during repeater inactivity and ID only when active. Does it wait for talking to stop before IDing? Or is that still the same with ID after every unkey or just timed based to infinity. Quote
WRDU469 Posted March 20, 2025 Posted March 20, 2025 It's mostly the same. BTECH told me they fixed a bug with one of the settings in CW ID, but there is not inactivity timer or hours you can set. You just get ID by timer, unkeying or can just turn it off. Quote
WRDU469 Posted March 20, 2025 Posted March 20, 2025 Btech also told me the CPS is not currently working on this new firmware version and they needed to update it. With the old firmware I could not get it work on Win11, but I could using Win10. After I updated the repeater, it would not work using Win10 anymore. I was told to wait for them to update it. So they know the CPS is broken. Fortunately, from what I can tell, I can do everything I need from the hand mic programming except name my channels. Other than that, the repeater works good. Quote
LeoG Posted March 20, 2025 Posted March 20, 2025 I'm just waiting for the cable to arrive so I can install the mic update. Looks like you have to do that before the 1.008R update. At least that's what it said to do in the instructions. My Wouxun cable for whatever reason won't work even though it has the right chip. I'm assuming I'll have difficulty with the new cable but can't know until I get it. I have a Win7 and Win10 computer and neither seems to connect to the repeater properly with the settings they've said to use. In the bottom left hand corner of the CMD screen it says Offlin and the baud rate of 115200 and some other things that are cut off. I assume Offlin means it's not connected. Quote
LeoG Posted April 9, 2025 Posted April 9, 2025 Did the update a while ago and it was successful. I had the cable with the chip built in and the cable they sent me was just a straight USB>RJ45 no chip. I'm guessing the chip is in the repeater. So ever since I did the update it's been tough for my house to reach the repeater. Today I remembered they put a squelch function in the works and I went to find it and the default is set to 6. Who sets the default that high? I dropped it to 1 and low and behold my wife can reach the shop. I've always been able to reach the house good. At 6 it was pretty sketchy and a lot of the time no audio, just the repeater courtesy tone. We'll see if it keeps working from now on or if this was just a coincidence. Quote
WRTC928 Posted April 12, 2025 Posted April 12, 2025 I bought one of these, but I haven't installed it yet. I need to get a mast up for the antenna. For now, it's going to be a 30' flagpole because my budget won't allow a real tower. However, I've mentioned before that my house is in a very good location for radios, being on an elevated position above a river. I have a buddy who lives on the other side of the river in a simplex "dead zone". Based just upon the distance, we should be able to talk simplex, but his home is blocked by terrain. We can talk on my base unit with a Comet 2x4 on a pizza pan about 9' off the floor, so I think getting the antenna up 30' will make it possible for us to talk HT to HT pretty much all over the area. I'm less optimistic about my friend who lives in a city about 20 miles north, but I used one of those online terrain calculators, and it looks like it's not impossible. It has 16 channels in the software, but you can only enter data into 8 of them with one weird exception. Using the BTech software, if you checkmark channel 9, it automatically enters values to transmit on 440.0000 MHz and receive on 450.0000 MHz. You can change the tones but not the frequencies. I haven't tried to find out if it actually functions in that mode, but it seems like a strange thing to include. At first, I was like, "Whaddaya mean I can't use all 16 channels!" Then I remembered it's a repeater. It will probably spend its entire life on the same frequency. I entered 8 just because I could, but it seems unlikely I'll use more than one. BTech says you can use it as a base station with the supplied mic, but that's not exactly true. Apparently, you can transmit and receive on any of the 8 programmed channels, but the rest of the GMRS band isn't available. That isn't really a big deal because most likely I'll only use the mic to respond to traffic on the repeater when I'm at home, but being away from home is kinda the point of a repeater. I may program them to some local repeaters that are a bit too far away for my base unit and see if the taller, higher-gain CA-712 antenna will let me reach them. WRNU354 1 Quote
LeoG Posted April 12, 2025 Posted April 12, 2025 1 hour ago, WRTC928 said: I bought one of these, but I haven't installed it yet. I need to get a mast up for the antenna. For now, it's going to be a 30' flagpole because my budget won't allow a real tower. However, I've mentioned before that my house is in a very good location for radios, being on an elevated position above a river. I have a buddy who lives on the other side of the river in a simplex "dead zone". Based just upon the distance, we should be able to talk simplex, but his home is blocked by terrain. We can talk on my base unit with a Comet 2x4 on a pizza pan about 9' off the floor, so I think getting the antenna up 30' will make it possible for us to talk HT to HT pretty much all over the area. I'm less optimistic about my friend who lives in a city about 20 miles north, but I used one of those online terrain calculators, and it looks like it's not impossible. It has 16 channels in the software, but you can only enter data into 8 of them with one weird exception. Using the BTech software, if you checkmark channel 9, it automatically enters values to transmit on 440.0000 MHz and receive on 450.0000 MHz. You can change the tones but not the frequencies. I haven't tried to find out if it actually functions in that mode, but it seems like a strange thing to include. At first, I was like, "Whaddaya mean I can't use all 16 channels!" Then I remembered it's a repeater. It will probably spend its entire life on the same frequency. I entered 8 just because I could, but it seems unlikely I'll use more than one. BTech says you can use it as a base station with the supplied mic, but that's not exactly true. Apparently, you can transmit and receive on any of the 8 programmed channels, but the rest of the GMRS band isn't available. That isn't really a big deal because most likely I'll only use the mic to respond to traffic on the repeater when I'm at home, but being away from home is kinda the point of a repeater. I may program them to some local repeaters that are a bit too far away for my base unit and see if the taller, higher-gain CA-712 antenna will let me reach them. When they said use it like a base station it never entered into my mind that it would be a fully functional radio, not even once. I figured you could transmit on the channel it was currently programmed to. I started out with the RT97S and that's how that one worked and I just assumed the RPT50 would be the same. It's nice to have the microphone so you don't need to have an HT to communicate if you are in the same room as the repeater. They did change the firmware again but when I got my repeater I was able to load all 16 channels, I have 8 setup as analog and 8 set up with digital tones. So it's easy to switch if it becomes necessary and I don't have to break out into programming. WSDM599 and PRadio 2 Quote
WRTC928 Posted April 16, 2025 Posted April 16, 2025 On 4/12/2025 at 10:19 AM, LeoG said: When they said use it like a base station it never entered into my mind that it would be a fully functional radio, not even once. I figured you could transmit on the channel it was currently programmed to. I started out with the RT97S and that's how that one worked and I just assumed the RPT50 would be the same. It's nice to have the microphone so you don't need to have an HT to communicate if you are in the same room as the repeater. They did change the firmware again but when I got my repeater I was able to load all 16 channels, I have 8 setup as analog and 8 set up with digital tones. So it's easy to switch if it becomes necessary and I don't have to break out into programming. That's interesting. I can't enter anything into rows 9-16. I'd like to do what you did. After I posted, I realized that it could actually function like a base station. Since a base station exceeds the power limits for channels 1-14, it functions on 15-22 anyway. It won't scan, but otherwise it will function like a base station; i.e, transmit and receive on the selected frequency without having to use the repeater function. Quote
LeoG Posted April 16, 2025 Posted April 16, 2025 Copy and paste is your friend. That was the only way I could get anything in there. Low power on the repeater is 5 watts I believe. SteveShannon and WRUU653 2 Quote
WRTC928 Posted April 17, 2025 Posted April 17, 2025 22 hours ago, LeoG said: Copy and paste is your friend. That was the only way I could get anything in there. Aha. Good to know. I'll try that. Quote
WRTC928 Posted April 17, 2025 Posted April 17, 2025 22 hours ago, LeoG said: Copy and paste is your friend. That was the only way I could get anything in there. Low power on the repeater is 5 watts I believe. Okay, one more thing. How do I tell it I don't want a CTCSS or DTS code enabled? "No SQ" doesn't seem to be one of the options. Quote
OffRoaderX Posted April 17, 2025 Author Posted April 17, 2025 33 minutes ago, WRTC928 said: How do I tell it I don't want a CTCSS or DTS code enabled? IIRC, there is a "none" option in the CTCSS/DTS drop down list. Quote
LeoG Posted April 17, 2025 Posted April 17, 2025 I also think there an option in the updated menu about being a non toned channel. Quote
WRTC928 Posted April 18, 2025 Posted April 18, 2025 4 hours ago, OffRoaderX said: IIRC, there is a "none" option in the CTCSS/DTS drop down list. Not on mine. That's the problem. The software I downloaded from BTech seems extremely rudimentary. For example, there are only 16 channels. Period. Supposedly, you can store up to 800 frequencies and scan them. There's no way to do any of that with this software. Quote
OffRoaderX Posted April 18, 2025 Author Posted April 18, 2025 4 minutes ago, WRTC928 said: The software I downloaded from BTech seems extremely rudimentary. I would check/confirm but mine is all boxed up and ready to give away to someone on Youtube. You should email the BTech Support with your questions - they are very good and very fast/responsive. SteveShannon, WRTC928 and WSDM599 2 1 Quote
gortex2 Posted April 18, 2025 Posted April 18, 2025 8 hours ago, WRTC928 said: Not on mine. That's the problem. The software I downloaded from BTech seems extremely rudimentary. For example, there are only 16 channels. Period. Supposedly, you can store up to 800 frequencies and scan them. There's no way to do any of that with this software. Isn't this a repeater ? If so there is no need for 800 frequencies. 99% of the time a repeater is on one channel and one channel only. WRUU653, WRXB215 and tcp2525 3 Quote
