OffRoaderX Posted May 12, 2024 Report Posted May 12, 2024 My DB40-G did not come with a programming cable. Has anyone purchased a DB40-G and if so did yours come with the cable? And, what type of cable is it? SteveShannon 1 Quote
1 SteveShannon Posted May 14, 2024 Report Posted May 14, 2024 1 hour ago, WRYS709 said: Can someone explain to me this style of thread, where instead of posts being listed chronologically, their listed in some obscure order (voting?)? I am now reticent to post on these threads, because I cannot tell who is responding to what! Maybe there is a "switch" that allows me to read them chronologically again? There is a switch. Immediately below the original question, over on the right, is a pair of buttons. You can choose to sort by VOTES or by DATE. WRXB215 and OffRoaderX 1 1 Quote
1 SteveShannon Posted May 13, 2024 Report Posted May 13, 2024 3 hours ago, WRXB215 said: Where did you buy it? Radioddity indicates it comes with one both in the picture and down further under "What’s in the box?" He mentioned that in his review. I think he’s trying to find out if anyone else has received it. Quote
1 WRYS709 Posted May 14, 2024 Report Posted May 14, 2024 Can someone explain to me this style of thread, where instead of posts being listed chronologically, their listed in some obscure order (voting?)? I am now reticent to post on these threads, because I cannot tell who is responding to what! Maybe there is a "switch" that allows me to read them chronologically again? Quote
0 WRXB215 Posted May 13, 2024 Report Posted May 13, 2024 17 hours ago, OffRoaderX said: My DB40-G did not come with a programming cable. Where did you buy it? Radioddity indicates it comes with one both in the picture and down further under "What’s in the box?" Quote
0 WRXB215 Posted May 13, 2024 Report Posted May 13, 2024 @Sshannon, @OffRoaderX Sorry, my bad, I've gotten behind on the videos. Quote
0 SteveShannon Posted May 14, 2024 Report Posted May 14, 2024 8 hours ago, WRXB215 said: @Sshannon, @OffRoaderX Sorry, my bad, I've gotten behind on the videos. No apologies needed on my behalf. I was just explaining. Quote
0 OffRoaderX Posted May 14, 2024 Author Report Posted May 14, 2024 2 hours ago, WRYS709 said: Can someone explain to me this style of thread, where instead of posts being listed chronologically, their listed in some obscure order (voting?)? I am now reticent to post on these threads, because I cannot tell who is responding to what! Maybe there is a "switch" that allows me to read them chronologically again? This is a "question", not a regular forum-post.. Upvoted answers to the question rise to the top, stupid/downoted answers float to the bottom. There is no 'switch' to change it. EDIT: I stood corrected - there IS a switch! SteveShannon 1 Quote
0 WRYS709 Posted May 15, 2024 Report Posted May 15, 2024 8 hours ago, OffRoaderX said: EDIT: I stood corrected - there IS a switch! Thanks for pointing that out. Now I can follows these threads again. Quote
0 Davichko5650 Posted May 24, 2024 Report Posted May 24, 2024 On 5/12/2024 at 2:34 PM, OffRoaderX said: My DB40-G did not come with a programming cable. Has anyone purchased a DB40-G and if so did yours come with the cable? And, what type of cable is it? My DB-20-G did have the cable in the box, it's a USB A to RJ-45 cable. Similar, but not the same as the cable for my Kenwood 281a. I'd think the DB40 cable would be the same? Then again, my wife warns me about thinking a lot, so.... Have yet to try the CPS software for the DB20, have read there's somewhat of a learning curve to it, and some driver install issues, maybe? And it's very easy to program right on the radio, so will look at CPS when I've the time Quote
0 amaff Posted May 24, 2024 Report Posted May 24, 2024 It's not the same type of cable as the DB20-G. That's an RJ-45 connector. This one is a DIN connector of some flavor. The CPS for the DB20 is a little clunky. The main 'trick' is to use the ">>" buttons for practically everything instead of trying to do it in the spreadsheet, IMO WRYS709 1 Quote
0 WA9BD Posted May 30, 2024 Report Posted May 30, 2024 Yes, mine came with a cable. It's a USB-A to 8 pin that plugs into the mic jack. The software provided by Radioddity is one step above worthess, however. You cannot Alpha tag memories, nor adjust any radio menu settings. If you enter Alpha tags using the radio keypad then write some new memories using the so-called "software", it will wipe out your alpha tags. Ask me how I know . I spoke to RT Systems at the Dayton (Xenia) hamfest and they said they might have a version of their software out for it in the future, but it's a back burner issue. They indicated that the programming for this radio is a "convoluted mess." Their words, not mine. Chirp saId that they will work on a version once they get a test radio and if "a programmer has the time/interest to do it". Again, their words. Have fun. OffRoaderX 1 Quote
0 OffRoaderX Posted May 30, 2024 Author Report Posted May 30, 2024 1 hour ago, WA9BD said: Chirp saId that they will work on a version once they get a test radio I wish I knew that. I give away all my radios, but I just gave away this one last week. SteveShannon and tcp2525 2 Quote
0 WRDG914 Posted September 23, 2024 Report Posted September 23, 2024 I got mine a couple of days ago, it came with the cable you mentioned and with a note to upgrade to new firmware which you'll have to read between the lines to interpret, its said to add VOX, and the extended wait time to 10 seconds and also allows for channel names to be edited..., ps: it came from Radioddity WA9BD 1 Quote
0 WA9BD Posted September 23, 2024 Report Posted September 23, 2024 5 hours ago, WRDG914 said: I got mine a couple of days ago, it came with the cable you mentioned and with a note to upgrade to new firmware which you'll have to read between the lines to interpret, its said to add VOX, and the extended wait time to 10 seconds and also allows for channel names to be edited..., ps: it came from Radioddity That's good info, thanks. I had no idea Raddy had come out with new firmware and CPS software. I just installed and updated firmware and edited all my memories with Alpha tags. Wrote to the radio and boom. Worked FB. Thanks again Quote
OffRoaderX
14 answers to this question
