Currently I have three antennas to choose from for a masthead installation (I own these three):
MXTA-26: My favorite antenna. If this goes on my sailboat mast head I'll have to buy another of the same, though I don't mind. Advertised as a 6dbi antenna.
HYS SDN1T: Advertised as a 3dbi antenna. This one is surprisingly bad. More on that in a minute.
MXTA-25: Ghost antenna. For those who dislike this antenna, I'll say it works quite well. Better than the SDN-1T by a fair margin.
(Not in the running) Midland stock mobile 2.1dbi magnetic mount antenna. Because it's not NMO it isn't going to work on the masthead.
Sailing may be a problem for higher-gain antennas: While motoring or sitting idle, the MXTA-26 would be a fantastic choice for a masthead installation. However, under sail, I might be heeling 5 degrees to 25 degrees (often a long time at 10-15 degrees. So I'm trying to decide if this will be appropriate for the masthead. If it is not going to be appropriate, based on its radiation pattern, I'll probably have to go back to the drawing board and order something else.
Why not the HYS SDN-1T? I actually bought this one specifically to use on the masthead. But then I started testing it. Ugh, it's not good. Today I set up a voice recorder hooked up to a UV5G at home, with the MXTA-25 magnetically mounted to a window air conditioner at home. Then I drove four miles away, 350 feet below, with a couple of bluffs creating some line of sight issues, and tested several options.
1: The MXTA26 attached to my mobile Retevis RA87, testing at 5, 20, and 40w. In every case this antenna performed very, very well. At 5w the quieting wasn't as good as at 20w and 40w. But I couldn't hear any difference between 20w and 40w, and transmissions were crystal clear. Again, this is advertised as 6dbi.
2: The HYS SDN1T: Attached this to the same Retevis RA87, and again tested at 5, 20, and 40w. At 5w it was hard to make out. At 20w and 40w there was a lot of background hiss; not very good quieting. It just didn't sound very good. Again, this is advertised as 3dbi.
3: The Ghost antenna (MXTA25). I wouldn't mind putting this on the masthead. I'll have to repeat the tests mentioned here first. But it's in a plastic housing, and I don't expect that it would be as trouble-free sitting on a masthead for a few years. For now I'm ruling that one out just because I think its plastic housing would deteriorate over years of sitting up there exposed.
4: The "stock" Midland small magnetic mount antenna. This is listed as 2.1dbi. I connected this to another UV-5G and tested at full power (<5w). It sounded BETTER than the HYS SDN-1T, even compared to the HYS antenna being used at 40w.
So now we have a definite loser. The HYS SDN-1T is WORSE than the little almost throwaway magnetic mount antenna that Midland includes for free with all of its mobile radios. The conclusion: I can't put that on my mast.
But that brings me back to the original issue: Will the propagation pattern of the MXTA26 be awful when I'm sailing and heeling a few degrees? If so, I'll have to resume my search for a good masthead antenna that is more in the 2.1-3dbi range, that works with an NMO mount which I've installed on the masthead.
Is there an online calculator, or a formula that I can use, to see how propagation is impacted by antenna angle, or what the propagation is for a given angle above or below "level" for an antenna based on its gain?
Update later in the day: I had some time to swap around and test using the HYS SDN-1T as a receiving antenna at home, and then comparing the MXTA25 to the MXTA26.
From one location about 4-miles out (where the MXTA26 previously had no problem getting through at any power from 5w to 40w), I compared the A25 and A26. The A26 performed very well, fully quieting at 15, 20, and 40w. Background noise at 5w. Then I swapped in the MXTA25. I was quite noisy at 40w, and from this location it didn't propagate well enough to break squelch at 5, 10, 15, and 20w -- only at 40w.
I tested again about 2 miles away and found the MXTA25 to be adequate at 5-40w with quite a lot of background noise at 5, 10, and 15w. And the MXTA26 was crystal clear at 10, 15, 20, and 40w, with slightly elevated background noise at 5w.
So if I were to rank their effectiveness:
MXTA26 - Very good simplex at 4 miles for 10-40w, some background noise at 5w.
HYS SDN-1T - Not great at 4 miles even at 40w. Usable but poor at 5w at this distance.
Midland Stock miniature magnetic mount antenna included with MicroMobile radios - About the same as the HYS SDN-1T symplex at 4 miles.
MXTA25 - Not usable simplex at 4 miles. Reasonable for simplex at 2 miles.
There's really no comparison, though. The MXTA26 outperformed the other three by a long shot. And I was surprised that the MXTA25 did as poorly as it did at 5w at 4 miles distance. The terrain isn't great; the receiving antenna is about 350 feet above the transmitting antennas, with several hills obstructing line of sight somewhat. Pretty good real-world test though.
dosw
7 answers to this question
