Both the MXTA27 lip mount, and the MXTA12 magnetic mount come with a length of fairly thin coax. I think they're each six meters, which is over nineteen feet. I don't know what cable they're using; they call it low profile coax.
I have some PL259 crimp-on connectors that are made for RG58, and a crimper tool. Before braving ahead at cutting my MXTA27 cable at six feet, I found some old television coax around the house and cut the connector off of it, just to see if I could use it to practice adding a new connector. I found that the copper braided shield was so thin, and supplemented with even thinner foil, that I couldn't really work with it; any amount of cutting of the outer cover would ruin about half the copper braid, no matter how gentle I was.
I assume this was because the cable I tested on was just super cheap stuff, not intended for modification. But that doesn't help me to know if I'm going to be successful with splicing a new connector onto a shortened MXTA27 or MXTA12 cable. Has anyone attempted this? Or am I better off just buying mounts that don't come with cable attached? Such mounts seem less common, in NMO form factor.
dosw
11 answers to this question
