NotARubiksCube Posted September 23, 2024 Report Posted September 23, 2024 Have patience... I'm a total GMRS noob. Most repeaters in my area are labeled "Open System" and the frequency and in/out tones are provided. Although it's labeled "open" and I have the information requried to use the repeater, there's an active "Request Access" button. Do I need to request access from the owner before using repeaters listed like this? thx Quote
WRUU653 Posted September 23, 2024 Report Posted September 23, 2024 Check for information below the repeater listing. Some owners will put additional information there. I know it doesn’t make much sense but I have heard that some people have not been able to remove the request button while others like to know who is using the repeater even though it is open. If you can’t get a response try asking on the repeater. If the button is there and no message to disregard it then it is a good idea to request permission. RayDiddio, LeeBo and TrikeRadio 3 Quote
LeeBo Posted September 23, 2024 Report Posted September 23, 2024 Even if the repeater is listed as “open”, I still request access. At least that way the owner knows I’ll be using it.Sent from my iPhone using Tapatalk SteveShannon, RayDiddio, WRUU653 and 2 others 5 Quote
WRUE951 Posted September 23, 2024 Report Posted September 23, 2024 Its the way MyGMRS has it set up.. If it's listed as an open system, use it. I've never once had a problem doing so. If the owner dosent want you using their repeater, they'll let you know. RayDiddio and Raybestos 2 Quote
WRYZ926 Posted September 23, 2024 Report Posted September 23, 2024 To quote Larry Potterfield from Midway USA " And that's the way it is" The request button is there no matter what. I setup our repeater as open and still have had a few people request permission to use it. I appreciate when people request permission but it is not required. RayDiddio and WSDD519 2 Quote
NotARubiksCube Posted September 23, 2024 Author Report Posted September 23, 2024 Weird. I'll err on the side of asking permission. That's probably what I would want if I were a repeater owner. WRUU653 1 Quote
WRXL702 Posted September 23, 2024 Report Posted September 23, 2024 Walter Cronkite With CBS News Always Use To Say - "And That's The Way It Is" When Ending His Nightly Newscast Way Before Midway USA Started As A Small Gun Shop In 1977. Just A Bit Of Trivia - That's The Way It Is......... Quote
wayoverthere Posted September 23, 2024 Report Posted September 23, 2024 1 hour ago, WRXL702 said: Walter Cronkite With CBS News Always Use To Say - "And That's The Way It Is" When Ending His Nightly Newscast Way Before Midway USA Started As A Small Gun Shop In 1977. Just A Bit Of Trivia - That's The Way It Is......... https://youtu.be/cOeKidp-iWo Quote
CentralFloridaGMRS Posted September 24, 2024 Report Posted September 24, 2024 Opened or closed the FCC said you can't block people from using a GMRS repeater. If you put up a repeater you better expect someone will use it. The FCC will only address issues if someone is causing problems on a repeater, not if they're talking on it however. If I put up a Repeater I wouldn't try to hide it or request people ask to talk on it. We have the Orlando 700 and as long as nobody is blocking transmissions anyone can talk on it. No you don't need permission from the repeater owner to use GMRS frequencies regardless of the repeater being private property. You're not violating private property laws by using a repeater that's on GMRS frequencies. If you want to control who can use your repeater you need a private business (IG) license. GMRS is a shared bases only except those that were grandfathered in years ago. WRUU653, WRCQ487 and dosw 3 Quote
WRUU653 Posted September 24, 2024 Report Posted September 24, 2024 31 minutes ago, CentralFloridaGMRS said: FCC said you can't block people from using a GMRS repeater Oh please show us where they said this . You are flat wrong. Here’s what the FCC says d) Individual licensee duties. The holder of an individual license: (1) Shall determine specifically which individuals, including family members, are allowed to operate (i.e., exercise operational control over) its GMRS station(s) (see paragraph (c) of this section); (2) May allow any person to use (i.e., benefit from the operation of) its GMRS repeater, or alternatively, may limit the use of its GMRS repeater to specific persons; (3) May disallow the use of its GMRS repeater by specific persons as may be necessary to carry out its responsibilities under this section. WSDM599 and RayDiddio 2 Quote
WRCQ487 Posted September 24, 2024 Report Posted September 24, 2024 FCC Rule Part 95.1705: (b) Individual licensee responsibility. The holder of an individual license to operate GMRS stations is responsible at all times for the proper operation of the stations in compliance with all applicable rules in this part. (d) Individual licensee duties. The holder of an individual license: (1) Shall determine specifically which individuals, including family members, are allowed to operate (i.e.,exercise operational control over) its GMRS station(s) (seeparagraph (c) of this section); (2) May allow any person to use (i.e., benefit from the operation of) its GMRS repeater, or alternatively, may limit the use of its GMRS repeater to specific persons; (3) May disallow the use of its GMRS repeater by specific persons as may be necessary to carry out its responsibilities under this section. https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E/section-95.1705 RayDiddio 1 Quote
WRUU653 Posted September 24, 2024 Report Posted September 24, 2024 6 minutes ago, WRCQ487 said: FCC Rule Part 95.1705: (b) Individual licensee responsibility. The holder of an individual license to operate GMRS stations is responsible at all times for the proper operation of the stations in compliance with all applicable rules in this part. (d) Individual licensee duties. The holder of an individual license: (1) Shall determine specifically which individuals, including family members, are allowed to operate (i.e.,exercise operational control over) its GMRS station(s) (seeparagraph (c) of this section); (2) May allow any person to use (i.e., benefit from the operation of) its GMRS repeater, or alternatively, may limit the use of its GMRS repeater to specific persons; (3) May disallow the use of its GMRS repeater by specific persons as may be necessary to carry out its responsibilities under this section. https://www.ecfr.gov/current/title-47/chapter-I/subchapter-D/part-95/subpart-E/section-95.1705 Copy cat RayDiddio, WRCQ487 and SteveShannon 3 Quote
CentralFloridaGMRS Posted September 24, 2024 Report Posted September 24, 2024 23 hours ago, WRUU653 said: Oh please show us where they said this . You are flat wrong. Here’s what the FCC says d) Individual licensee duties. The holder of an individual license: (1) Shall determine specifically which individuals, including family members, are allowed to operate (i.e., exercise operational control over) its GMRS station(s) (see paragraph (c) of this section); (2) May allow any person to use (i.e., benefit from the operation of) its GMRS repeater, or alternatively, may limit the use of its GMRS repeater to specific persons; (3) May disallow the use of its GMRS repeater by specific persons as may be necessary to carry out its responsibilities under this section. So please explain to me how they actually disallow someone? The FCC won't go after any licensed GMRS user that talks on a repeater as long as they are not jamming the repeater etc. So someone is using your repeater. You don't allow them to do so. You contact the FCC and you expect them to do what? That's my point on this issue. If you put up a repeater the FCC won't help you if you don't want someone talking on it. Quote
BoxCar Posted September 25, 2024 Report Posted September 25, 2024 The repeater is supposed to be under the owner's control whenever its powered up. The owner would then be able (provided they configured the option) to shut the repeater down and reinitialize it later, Quote
WRUU653 Posted September 25, 2024 Report Posted September 25, 2024 1 hour ago, CentralFloridaGMRS said: So please explain to me how they actually disallow someone? The FCC won't go after any licensed GMRS user that talks on a repeater as long as they are not jamming the repeater etc. Are you saying your that guy that "no means no" doesn't apply to? Because you're the one telling people they don't need permission. It's not a problem for me. I go by typical societal norms, if I were asked not to use a repeater I wouldn't use it. Why would I? Seems simple enough to me. If someone says no and you keep being a dick and using their repeater I'm gonna guess they would file a complaint and at the very least having said no, the repeater owner is no longer responsible for the actions of the denied persons actions on their equipment. Lots of people put up repeaters for private use, for family, for farms... I like the idea of open repeaters but you are not inherently entitled to use someones repeater. Telling a self professed noob that they don't need permission to use someones repeater while making false claims that the FCC said the repeater owner can't stop you is in poor judgment. That isn't correct and it isn't helpful to someone looking for real information. RayDiddio and SteveShannon 1 1 Quote
NotARubiksCube Posted September 25, 2024 Author Report Posted September 25, 2024 It seems to me that FCC intends the GMRS community to be mostly self-regulating, and act like grownups. I therefore presume that any rules they make that venture into the realm of unenforceable etiquette are simply intended to work on the honor system. If that's the case, then the only real value of the rule is to provide a basis to resolve conflicts resulting from someone without permission using a repeater as a tool to jam its frequencies on an ongoing basis. In a case like that, I suppose they could see fit to expend the necessary resources to go jackass hunting. WRUU653 1 Quote
CentralFloridaGMRS Posted September 25, 2024 Report Posted September 25, 2024 11 hours ago, WRUU653 said: Are you saying your that guy that "no means no" doesn't apply to? Because you're the one telling people they don't need permission. It's not a problem for me. I go by typical societal norms, if I were asked not to use a repeater I wouldn't use it. Why would I? Seems simple enough to me. If someone says no and you keep being a dick and using their repeater I'm gonna guess they would file a complaint and at the very least having said no, the repeater owner is no longer responsible for the actions of the denied persons actions on their equipment. Lots of people put up repeaters for private use, for family, for farms... I like the idea of open repeaters but you are not inherently entitled to use someones repeater. Telling a self professed noob that they don't need permission to use someones repeater while making false claims that the FCC said the repeater owner can't stop you is in poor judgment. That isn't correct and it isn't helpful to someone looking for real information. I'm taking the side of the repeater owner who wants it to remain private. My point being that the FCC will not help you in any way if you report someone for using your repeater. People take two sides on this. One is that the repeater is private property and the other is it's on the public gmrs channels and the FCC won't do a thing to help you. As far as I know, nobody has ever been fined for talking on a private repeater. I just find it interesting that the FCC doesn't have any way to actually fine anyone that talks on one. WRUU653 1 Quote
WRUU653 Posted September 25, 2024 Report Posted September 25, 2024 5 hours ago, CentralFloridaGMRS said: I just find it interesting that the FCC doesn't have any way to actually fine anyone that talks on one. Why would you say they have no way to fine you? If you have been told not to use it and you are reported and they catch you, they certainly can fine you. If they do or not is another matter. It’s probably not a huge issue on their plate. 5 hours ago, CentralFloridaGMRS said: I'm taking the side of the repeater owner who wants it to remain private Not when you tell people they don’t need permission you’re not. 5 hours ago, CentralFloridaGMRS said: One is that the repeater is private property and the other is it's on the public gmrs channels The repeater is private property and you are free to talk on GMRS channels without controlling or using the repeater. There are not two sides, the rules are what they are and any way you put it using a repeater that you have been denied permission to is wrong. It’s not just an opinion it’s in the FCC rules and it’s common decency. Quote
WRUU653 Posted September 25, 2024 Report Posted September 25, 2024 15 hours ago, NotARubiksCube said: I suppose they could see fit to expend the necessary resources to go jackass hunting. Well said, I had to quote you because I wasn’t able to give a like and a laughing emoji and the term “jackass hunting” made me laugh out loud. I got to clean up this coffee now SteveShannon and NotARubiksCube 1 1 Quote
WSDD519 Posted September 25, 2024 Report Posted September 25, 2024 On 9/23/2024 at 7:59 AM, WRYZ926 said: To quote Larry Potterfield from Midway USA " And that's the way it is" The request button is there no matter what. I setup our repeater as open and still have had a few people request permission to use it. I appreciate when people request permission but it is not required. Same here when I set ours up. Quote
CentralFloridaGMRS Posted September 26, 2024 Report Posted September 26, 2024 5 hours ago, WRUU653 said: Why would you say they have no way to fine you? If you have been told not to use it and you are reported and they catch you, they certainly can fine you. If they do or not is another matter. It’s probably not a huge issue on their plate. Not when you tell people they don’t need permission you’re not. The repeater is private property and you are free to talk on GMRS channels without controlling or using the repeater. There are not two sides, the rules are what they are and any way you put it using a repeater that you have been denied permission to is wrong. It’s not just an opinion it’s in the FCC rules and it’s common decency. Nobody has ever been fined for talking on a "private" repeater. Quote
WRUU653 Posted September 26, 2024 Report Posted September 26, 2024 1 hour ago, CentralFloridaGMRS said: Nobody has ever been fined for talking on a "private" repeater. That could be true, I wouldn’t doubt that, but that’s not the same as they have no way to do it and just because they haven’t doesn’t make it okay if you don’t have permission. Which was my point all along, not much more to say on the subject. WRXB215 1 Quote
