WSEA699 Posted November 3, 2024 Report Posted November 3, 2024 Hi all! I was on a local repeater recently and every so often there were tones coming through like the ones on fire calls. Thoughts? Thank you in advance! Quote
0 BoxCar Posted November 3, 2024 Report Posted November 3, 2024 Probably the station ID being broadcast in Morse Code. Quote
0 SteveShannon Posted November 3, 2024 Report Posted November 3, 2024 9 minutes ago, WSEA699 said: Hi all! I was on a local repeater recently and every so often there were tones coming through like the ones on fire calls. Thoughts? Thank you in advance! Could be as @BoxCar suggested, but maybe a user is sending dtmf tones. Quote
0 WSEA699 Posted November 3, 2024 Author Report Posted November 3, 2024 Definitely not morse code so it's probably dtmf tones. Thank you! Quote
0 Guest Posted November 3, 2024 Report Posted November 3, 2024 Are you sure it’s a gmrs repeater and not a public safety repeater? Quote
0 WSEA699 Posted November 3, 2024 Author Report Posted November 3, 2024 100% sure, it's the Ashland, MO repeater. I live in Columbia, MO which is 13 miles north and using the repeater I can reach my family here in town which I can't do with simplex. I love technology! Quote
0 SteveShannon Posted November 3, 2024 Report Posted November 3, 2024 29 minutes ago, WSEA699 said: Definitely not morse code so it's probably dtmf tones. Thank you! DTMF are the same tones you hear when you dial a phone. Quote
0 WSEA699 Posted November 3, 2024 Author Report Posted November 3, 2024 That's exactly what it sounded like. What would be the reason for transmitting dtmf tones on a gmrs repeater? Thanks again! Quote
0 SteveShannon Posted November 3, 2024 Report Posted November 3, 2024 3 minutes ago, WSEA699 said: That's exactly what it sounded like. What would be the reason for transmitting dtmf tones on a gmrs repeater? Thanks again! DTMF tones are frequently used to control repeater functions. Or someone simply doesn’t know how to use their handheld radio. WRXB215 and WRYZ926 2 Quote
0 WRXB215 Posted November 3, 2024 Report Posted November 3, 2024 2 hours ago, SteveShannon said: DTMF tones are frequently used to control repeater functions. Or someone simply doesn’t know how to use their handheld radio. Yep, sometimes people just start pushing buttons to see what will happen. AdmiralCochrane, SteveShannon and DeoVindice 3 Quote
0 WRYZ926 Posted November 3, 2024 Report Posted November 3, 2024 You can also use DTMF tones to call specific radios too. And the Ashland GMRS repeater is an excellent one and at a good location. I can get into it from Montgomery County which is about 50 miles east of Columbia. I do struggle a little getting into the Ashland repeater with 20 watts but normally do fine at 50 watts. Quote
WSEA699
11 answers to this question
