WRTC928 Posted December 7, 2024 Report Posted December 7, 2024 I passed the Technician test Thursday and I'm just waiting for the FCC. I need a good dual-band antenna for the top of my small car. It needs to be NMO compatible so I can use the mag mount I already have and not more than about 2 feet tall. For now, I'm going to use it with a Baofeng AR-5RM while I ponder exactly what I want as a permanent installation. So, what do you recommend? WRXB215 1 Quote
SteveShannon Posted December 7, 2024 Report Posted December 7, 2024 9 minutes ago, WRTC928 said: I passed the Technician test Thursday and I'm just waiting for the FCC. I need a good dual-band antenna for the top of my small car. It needs to be NMO compatible so I can use the mag mount I already have and not more than about 2 feet tall. For now, I'm going to use it with a Baofeng AR-5RM while I ponder exactly what I want as a permanent installation. So, what do you recommend? congratulations! Take a look at the comet sbb-2: https://www.dxengineering.com/parts/cma-sbb-2nmo WRTC928 1 Quote
WRYZ926 Posted December 7, 2024 Report Posted December 7, 2024 Another good one that is 16" tall is the Comet SBB1 NMO. That is what I am running on my 2023 Ford Escape. https://www.dxengineering.com/parts/cma-sbb-1nmo It's hard to beat the SBB1 or SBB2 when it comes to short dual band antennas. wayoverthere, SteveShannon and WRTC928 3 Quote
WRQC527 Posted December 7, 2024 Report Posted December 7, 2024 2 hours ago, WRYZ926 said: It's hard to beat the SBB1 or SBB2 when it comes to short dual band antennas The SBB2 is my favorite mobile dual band antenna. But after me snapping one off on the garage door and my wife snapping one off when she raised the tailgate of my van when I had the thing laid down, I didn't want to throw down for a third one. I run this one now, which has a spring. I've been happy with it. https://www.dxengineering.com/parts/dmn-az504sp?seid=dxese1&gclid=EAIaIQobChMIh6jprOKWigMV5CpECB0VjS8uEAQYASABEgKQNfD_BwE WRXB215 1 Quote
SteveShannon Posted December 7, 2024 Report Posted December 7, 2024 8 minutes ago, WRQC527 said: The SBB2 is my favorite mobile dual band antenna. But after me snapping one off on the garage door and my wife snapping one off when she raised the tailgate of my van when I had the thing laid down, I didn't want to throw down for a third one. I run this one now, which has a spring. I've been happy with it. https://www.dxengineering.com/parts/dmn-az504sp?seid=dxese1&gclid=EAIaIQobChMIh6jprOKWigMV5CpECB0VjS8uEAQYASABEgKQNfD_BwE Unfortunately that one isn’t recommended for use with a mag mount. WRYZ926 1 Quote
WRQC527 Posted December 7, 2024 Report Posted December 7, 2024 19 minutes ago, SteveShannon said: Unfortunately that one isn’t recommended for use with a mag mount. True. I gave up on mag mounts in favor of lip mounts. Too many pinched coax and water leak problems and I'm no fan of coax draped across the roof. Ultimately a lip mount would be my recommendation. SteveShannon and WRTC928 2 Quote
WRTC928 Posted December 8, 2024 Author Report Posted December 8, 2024 3 hours ago, WRQC527 said: True. I gave up on mag mounts in favor of lip mounts. Too many pinched coax and water leak problems and I'm no fan of coax draped across the roof. Ultimately a lip mount would be my recommendation. I'm sure I'll eventually come up with something more permanent. Since I tend to drive my vehicles until they fall apart, I may have a hole drilled and a permanent NMO mount installed. Before I do that, however, I want to make final decisions about where I want the radio, etc. WRQC527 and SteveShannon 2 Quote
wayoverthere Posted December 8, 2024 Report Posted December 8, 2024 11 hours ago, WRYZ926 said: Another good one that is 16" tall is the Comet SBB1 NMO. That is what I am running on my 2023 Ford Escape. https://www.dxengineering.com/parts/cma-sbb-1nmo It's hard to beat the SBB1 or SBB2 when it comes to short dual band antennas. I've had good results with the SBB1 as well, on a mag mount. it was short enough to clear the parking structure at work, mag mounted on the roof of my compact truck; it does work best with some ground plane though. with the new (full size) truck, im using a fender mount which just isn't enough for the SBB1, and it's no longer short enough on the roof,. that fender mount is carrying a Comet 2x4SR, which is the only thing i found in my box of spares that was happy there. i've also had good results with the 1/4 wave Signal Stalk from Signal Stuff. I did not have good results with the 1/2 wave version, and some testing indicates a need for more tuning (which i haven't gotten around to yet) WRYZ926 1 Quote
WRYZ926 Posted December 8, 2024 Report Posted December 8, 2024 I wish that I could run my 2x4SR on my Ford Escape. They are definitely good multi band antennas. Mine is mag mounted on the center of an expanded metal rack on my SxS and does very well. You are correct that the SBB1 needs a good ground plane. Mine is in the center of the roof on my Escape. It does well in that spot. wayoverthere 1 Quote
WRTC928 Posted January 2 Author Report Posted January 2 You guys did me right with the recommendation for the Comet SBB-1. I finally got around to putting it through its paces. It was spot-on all the way up and down the 2m and 70cm bands. The highest SWR I got was 1.3:1 with most of them being 1.0:1. It even did well on the GMRS frequencies, which are technically "out of band" for this antenna, but I'm not going to argue with those numbers. It's on a mag mount in the middle of my roof, which is probably a factor, but the Nagoya was too, and its performance was okay, but not impressive. wayoverthere, WRYZ926, AdmiralCochrane and 1 other 4 Quote
