1 hour ago, WRTC928 said:
I wish I could find a 70cm/2m antenna in the same form factor that would work as well as the Ghost. There are some available, but I'm skeptical of a "no-name" antenna selling for $16. I mean...there could be one out there, but I'm not going to buy one without seeing some reviews.
Also this Compactenna from DX Engineering: https://www.dxengineering.com/parts/can-2m-440?seid=dxese1&gclid=CjwKCAiAh6y9BhBREiwApBLHC1IcGA0rH-N1a1wQXIhDuTekfGba_nQh9ZEpj9l1uJz_W3QNi1ECGhoC2kUQAvD_BwE
6 hours ago, SteveShannon said:
I like this one, but it only tolerates 30 watts max. My mobile can do 50, and there might be a time when I wanted to use it. I'm probably going to go with the Compactenna eventually, but right now, my Comet is working just fine, so I'm not strongly motivated to replace it.
21 hours ago, nokones said:
A multi-band antenna will never be an optimum antenna for a specific band. The respective operating bands will be compromised in order to be marginal for the two bands
My favorite T-shirt says "TANSTAAFL" which is a fake Russian word popularized by author Robert Heinlein in the novel The Moon is a Harsh Mistress. It's actually an acronym for "There Ain't No Such Thing As A Free Lunch". You never get something for nothing and in order to gain in one area, you have to lose in another. The AR-5RM has three Tx bands: 70cm, 1.25m, and 2m. I only recently programmed some simplex frequencies on the 1.25m band which necessitated buying a tri-band antenna. I went with the Comet HT-224 which doesn't suck, but it gives up a noticeable amount in clarity to the NA-771 I had on it before. In turn, the NA-771 does not perform as well on GMRS frequencies as the NA-771G which is GMRS-specific. From my living room, I can work a 2-meter repeater about 20 miles away with a HT. This morning, I used the tri-band antenna for the first time, and although I still came through okay, I was told my signal was weaker than previously. With the 771 antenna I can blast into that repeater "like gangbusters" according to the net controller. I'm going to stick with the tri-band because it's good enough, but I did lose something in the transition,
Another thumbs up for the Midland Ghost antenna.
Without a doubt the Midland whip will get you more distance, but the Ghost will reach pretty much all of my local repeaters (some not so local also), so I have the Ghost on the majority of the time for my day to day driving around.  If I'm going to be taking a longer drive or trip, I'll switch to the whip.
