cbeam2 Posted 5 hours ago Report Posted 5 hours ago Does anyone have a recommendation for a window mount antenna to use HT in car? Quote
wayoverthere Posted 3 hours ago Report Posted 3 hours ago (edited) There is a Nagoya version out there with sma connectors: https://www.ebay.com/itm/124178030161 (not recommended per @Lscott 's experience with this type) Rugged Radios ses one with a nmo base, but will likely need a no ground plane antenna: https://www.ruggedradios.com/products/suction-cup-antenna-mount American radio supply has a couple others too: https://www.americanradiosupply.com/window-glass-mounts/ Edited 1 hour ago by wayoverthere edit with other's experience Quote
Lscott Posted 2 hours ago Report Posted 2 hours ago 59 minutes ago, wayoverthere said: There is a Nagoya version out there with sma connectors: https://www.ebay.com/itm/124178030161 I would not recommend that one. I have something similar, but with a BNC connector on the end. There is no ground plane resulting in a bad SWR match. The crappy coax shield is used as the other half of the dipole. wayoverthere 1 Quote
wayoverthere Posted 1 hour ago Report Posted 1 hour ago 22 minutes ago, Lscott said: I would not recommend that one. I have something similar, but with a BNC connector on the end. There is no ground plane resulting in a bad SWR match. The crappy coax shield is used as the other half of the dipole. Noted...I'll add that to my other post. I think if I were going this route, it'd probably be the rugged for the ability to use a no ground antenna. Quote
nokones Posted 49 minutes ago Report Posted 49 minutes ago I have very good luck with a Larsen Glass-Mount antenna. My VSWR on 462 megs is about 1.2:1 and 1.6:1 on 467 megs. https://www.arcantenna.com/products/pulse-larsen-kg450udpl-glass-mounted-whip-antenna Quote
nokones Posted 47 minutes ago Report Posted 47 minutes ago 2 hours ago, BoxCar said: Laird Laird does not have a Glass-Mount antenna Quote
