Posted (edited)
There is a Nagoya version out there with sma connectors: https://www.ebay.com/itm/124178030161 (not recommended per @Lscott 's experience with this type)
Rugged Radios ses one with a nmo base, but will likely need a no ground plane antenna: https://www.ruggedradios.com/products/suction-cup-antenna-mount
American radio supply has a couple others too: https://www.americanradiosupply.com/window-glass-mounts/
Edited by wayoverthere
edit with other's experience
  On 12/11/2024 at 9:16 PM, Lscott said:
I would not recommend that one. I have something similar, but with a BNC connector on the end.  There is no ground plane resulting in a bad SWR match. The crappy coax shield is used as the other half of the dipole.
Expand
Noted...I'll add that to my other post. I think if I were going this route, it'd probably be the rugged for the ability to use a no ground antenna.
There are several possible antennas that could be used. The key parameter is the bandwidth of the antenna. You'll need to see if it has enough bandwidth to cover both the amateur UHF frequencies as well as reaching up to 468 MHz for GMRS. It's doubtful you will find a satisfactory solution in a glass-mount
The two I know with wide enough ranges are the aforementioned comet 2x4sr (which has worked well for me as well, and is currently on my truck) and the tram 1181 (some have had good results, not so great for me). Both can be a little picky about having a good ground plane.
Reply to this topic...
