WSHI569 Posted April 7 Report Posted April 7 Hello, my Baofeng UV9G is set to 162.475 to listen to NOAA. I've heard nothing for the last hour. Does anyone have any thoughts? Thank You in Advance! Quote
amaff Posted April 7 Report Posted April 7 Try the other 6 NOAA frequencies? Without knowing where you are, we don't have any way to know what NOAA channel you SHOULD be hearing them on. HHD1 and Hoppyjr 2 Quote
WRYZ926 Posted April 7 Report Posted April 7 42 minutes ago, Socalgmrs said: Omg 6HOURS without noaa? if we only had any other way to hear about the weather!!!! Maybe someone should invent a World Wide Web and put weather info on it!!!! Some times noaa goes down. Sometimes for hours sometimes for days. It happens. We just have to learn about the weather like people did 50, 100, 200…… years ago. Stop with the negativity. We all know that you are just a hateful rude person with no friends. You really need to pull your head out of your forth point of contact and then see a doctor so that your headspace and timing can be reset. And to answer why someone would want to listen to the NOAA channels, the internet might go out during a bad storm or the person might be somewhere that there is no internet or cell service. WRXB215, EternalNoob, JBRPong and 9 others 10 2 Quote
Lscott Posted April 7 Report Posted April 7 3 minutes ago, WRYZ926 said: And to answer why someone would want to listen to the NOAA channels, the internet might go out during a bad storm or the person might be somewhere that there is no internet or cell service. If he's that worried then consult this site for the status of various NOAA weather stations. https://www.weather.gov/nwr/outages amaff 1 Quote
tcp2525 Posted April 7 Report Posted April 7 2 hours ago, WSHI569 said: Hello, my Baofeng UV9G is set to 162.475 to listen to NOAA. I've heard nothing for the last hour. Does anyone have any thoughts? Thank You in Advance! This is a common problem when you don't set your time zone to your location and leave it set to Beijing. WRUE951 and Raybestos 2 Quote
WRTC928 Posted April 7 Report Posted April 7 2 hours ago, Socalgmrs said: Omg 6HOURS without noaa? if we only had any other way to hear about the weather!!!! Maybe someone should invent a World Wide Web and put weather info on it!!!! Some times noaa goes down. Sometimes for hours sometimes for days. It happens. We just have to learn about the weather like people did 50, 100, 200…… years ago. dosw 1 Quote
Jaay Posted April 7 Report Posted April 7 3 hours ago, Socalgmrs said: Omg 6HOURS without noaa? if we only had any other way to hear about the weather!!!! Maybe someone should invent a World Wide Web and put weather info on it!!!! Some times noaa goes down. Sometimes for hours sometimes for days. It happens. We just have to learn about the weather like people did 50, 100, 200…… years ago. YOU ... ARE such a Moron, but then you already KNOW this. dosw 1 Quote
Jaay Posted April 7 Report Posted April 7 2 hours ago, tcp2525 said: This is a common problem when you don't set your time zone to your location and leave it set to Beijing. Transmitter Maintenance or a broken link from NOAA. Quote
tcp2525 Posted April 7 Report Posted April 7 37 minutes ago, Jaay said: Transmitter Maintenance or a broken link from NOAA. NOAA was working perfectly for me and I didn't notice any interruption of signal. I don't even think it is possible as they have to many redundancies built in. Quote
amaff Posted April 8 Report Posted April 8 6 hours ago, WSHI569 said: Hello, my Baofeng UV9G is set to 162.475 to listen to NOAA. I've heard nothing for the last hour. Does anyone have any thoughts? Thank You in Advance! Decided to sniff around once I was home. WSHI569's in Somersville, CT. 162.475 appears to be the closest one, and isn't reporting as degraded or as an outage. So the question is: can he receive it on another radio and this one's misconfigured / goofy? WRXB215 1 Quote
Lscott Posted April 8 Report Posted April 8 36 minutes ago, amaff said: So the question is: can he receive it on another radio and this one's misconfigured / goofy? I don’t see why not. The NOAA stations TX 24/7 using wide band FM so any radio that can receive the frequency should work. Also you really don’t need a squelch setting if you’re close enough. Plus you shouldn’t be using any kind of tone either. SteveShannon, Jaay and WRXB215 3 Quote
Jaay Posted April 8 Report Posted April 8 6 hours ago, tcp2525 said: NOAA was working perfectly for me and I didn't notice any interruption of signal. I don't even think it is possible as they have to many redundancies built in. NOT true, as it's happened Twice last year for KZZ65 Quote
RodB Posted April 8 Report Posted April 8 My local does have the random outage once in awhile, in my car I can usually pull in another semi local station Quote
WRYZ926 Posted April 8 Report Posted April 8 I can usually pickup two different NOAA weather stations at home. There is one in St Louis and one in Jefferson City that I can hear well. Quote
SteveShannon Posted April 8 Report Posted April 8 13 hours ago, tcp2525 said: NOAA was working perfectly for me and I didn't notice any interruption of signal. I don't even think it is possible as they have to many redundancies built in. They have 1035 transmitters. Currently 20 transmitters are down. tcp2525, kirk5056 and WRXB215 3 Quote
SteveShannon Posted April 8 Report Posted April 8 I have no idea if it’s related, but BTECH posted this notice: Monday, April 7, 2025 ARLINGTON, SD – If you own a GMRS-PRO or UV-PRO from BTECH, the new 0.8.3 firmware update is worth your attention and comes packed with fixes and improvements. One of the biggest highlights is the UV-PRO’s refreshed display, which is much easier to read in direct sunlight. Both radios also get a fix for a stubborn receive problem that showed up when NOAA alerts were enabled. This bug sometimes caused weaker reception and odd scanning behavior. It’s finally gone, and the radios now handle NOAA alerts the way they were always meant to. Below, you’ll find a full breakdown of what’s changed and why it matters. amaff, JBRPong, tcp2525 and 1 other 2 2 Quote
WRUE951 Posted April 8 Report Posted April 8 14 minutes ago, SteveShannon said: I have no idea if it’s related, but BTECH posted this notice: Monday, April 7, 2025 ARLINGTON, SD – If you own a GMRS-PRO or UV-PRO from BTECH, the new 0.8.3 firmware update is worth your attention and comes packed with fixes and improvements. One of the biggest highlights is the UV-PRO’s refreshed display, which is much easier to read in direct sunlight. Both radios also get a fix for a stubborn receive problem that showed up when NOAA alerts were enabled. This bug sometimes caused weaker reception and odd scanning behavior. It’s finally gone, and the radios now handle NOAA alerts the way they were always meant to. Below, you’ll find a full breakdown of what’s changed and why it matters. Is that firmware good for all UV-5R"s Baufangs included? Quote
SteveShannon Posted April 8 Report Posted April 8 Just now, WRUE951 said: Is that firmware good for all UV-5R"s Baufangs included? According to the first sentence it’s for the GMRS-Pro or UV-Pro. You might want to look at the BTECH site. Quote
WRUE951 Posted April 8 Report Posted April 8 I did look at their site and also Baofeng which does not show any firmware updates.. I remember reading here at some point that both BTECH and Baofeng radios are identical radios but i don't know if that is confirmed or not. Hell, i have an old Baofeng UV-5R laying around i never use, I'll try the BTECH firmware update on it. . If it bricks the radio,, the trash can will own it.. Quote
WRUE951 Posted April 9 Report Posted April 9 Nope, it didn't work and no bricked UV5R trying. All it got was a bunch of *** errors. Quote
Lscott Posted April 9 Report Posted April 9 On 4/8/2025 at 11:01 AM, WRUE951 said: If it bricks the radio,, the trash can will own it.. Gives me something else to look for when out at night trash picking. SteveShannon and amaff 2 Quote
WRUE951 Posted April 9 Report Posted April 9 28 minutes ago, Lscott said: Gives me something else to look for when out at night trash picking. Hell, you don't have to pick the trash. I'll give it to ya Lscott 1 Quote
SteveShannon Posted April 9 Report Posted April 9 53 minutes ago, Lscott said: Gives me something else to look for when out at night trash picking. Was that you pushing the shopping cart and wearing bunny slippers the other day? WRUE951 1 Quote
Lscott Posted April 9 Report Posted April 9 9 minutes ago, SteveShannon said: Was that you pushing the shopping cart and wearing bunny slippers the other day? No, but you would be surprised by how many old computers I've picked up in past years sitting by dumpsters in the apartment complex I used to live in. Grabbed a few parts out of one and stick in another, a cheap hard disk from the computer store down the street and I was all set. Loaded up a Linux system and put them on my network. Ran them for years until the power supplies died. Then took out the drives and dumped the dead carcasses in the trash bin. WRYZ926, WRUE951 and SteveShannon 3 Quote
