  2. This is the way I do it on both GMRS and ham. I give it in plain old alphabet first and if the other party doesn't understand then I give it again with the NATO phonetic alphabet. However, when someone uses the NATO exclusively, it doesn't bother me a bit.
  3. Like I said I get annoyed by it too. However I can see both sides of the argument. Gmrs radio and amateur radio communications via voice are generally conversational. There's no real need for things like tactical call signs and phonetic alphabet on the day-to-day basis. However there is plenty of opportunity when those things can be beneficial to The Operators. But that's not what annoys me. It's probably not what annoys Randy either, though I won't speak for him personally. What does annoy me is people who say their call sign at the beginning of their transmission and at the end of their transmission and in the middle of their transmission every single time they key up the microphone. We get it. We know who we're talking to. You only need to use your call sign three times in every hour of conversation. We don't need to hear it three times a sentence. And just so we're clear it's not a radio thing. I hate when people use words as fillers because they don't know what else to say. Words similar to "like" or dude, or ah, um, or whatever they use to fill in the silence between thoughts. My therapist says I'm getting much better at it though.
  4. Today
  5. I just say let them do what they want. It hurts no one. If it annoys you maybe you should work on that. It a style, a personality. Now it they start demanding you do the same then maybe it's them with the problem. If this is their "fun" why should they need to stop. Just sitting here now and someone came on with their phonetic call sign just to say they were on the repeater. Not talking to anyone. Didn't bother me.
  6. Alex284
    Michigan GMRS
    Thanks! They are for sure still sometimes linked. Detroit and mt. Clemens always is. Cheboygan, Flint, Saginaw always is. Sometimes they will link the two groups but not always. The north group seems to think Detroit is where tomfoolery comes from but we've all seen it from both sides. So they only link the two groups when it can be monitored now.
  7. In My Opinion - The NATO Phonetic Alphabet Should Only Be Used For A Clarification When Necessary On GMRS. It's Really Not Needed, Nor Should It Be Used For Regular Everyday GMRS Comms.
  8. I agree. Use of the phonetic alphabet important for hams in order to accurately discern call signs for all the reasons you listed. Unlike GMRS logging calls in amateur radio is important. Almost nobody logs calls in GMRS. I would say nobody but there have been a very few people on this forum who have expressed a desire to log calls. But I find it very easy to ignore people using their call signs frequently or using the phonetic alphabet.
  9. @OffRoaderX went far beyond sharing an opinion. I genuinely cannot imagine why anyone would be annoyed by use of the phonetic alphabet unless it's because "some people" think it's a symptom of trying to be a ham in a GMRS community. I think part of the reason hams use the phonetic alphabet so much is that amateur radio is international. It can be pretty hard to understand someone whose first language is not the same as your own, especially the pronunciation of some letters. Just think of how much "B" and "V" sound alike in Spanish. GMRS users almost never talk to someone in another country, so being understood is not as much of a challenge (unless you're in California). Furthermore, shorter wavelengths have higher frequencies, which typically improves clarity in voice signals. Even the difference between 70cm and 2m can sometimes be discernible. If you're playing around on 80 meters, you're going to repeat yourself quite a bit. GMRS, being at the higher end of the spectrum, rarely suffers from poor quality of voice signals. For the most part, if you can punch the signal through, you'll be understood. Simply put, GMRS users don't use the phonetic alphabet because we don't need to. It's easier for me to say "WRTC" than "Whiskey Romeo Tango Charlie", but sometimes I'm going to use the phonetic anyway. I have 33 years of using the phonetic alphabet in uniformed service and I also participate in amateur radio. It happens. I just don't understand why anyone gets their undies in a wad over it.
  10. Hi all! Just got in to GMRS/HAM. Anyone active in here?
  11. Look at the repeater map/database.
  12. Anybody have frequency and codes for keys repeater?
  13. WRDJ205
    DIY
    This…if you need a second set of repeater channels. Start slow and learn about setting up repeaters near you using the first set of “repeater channels”. Welcome!!
  14. Everyone does things a little different. Go with what works for you and your repeater.
  15. OffRoaderX
    DIY
    Only use that option when re-doing the floors in your bathroom or painting the house. Not sure if mowing your lawn counts, but you can give it a try.
  16. hxpx
    DIY
    I don't have a GM15 Pro, but I found this reddit thread - looks like it's a second set of repeater channels you can set up for different tones.
  17. WSIY957
    DIY
    Ok I'm very much a nubie, but I have a question that might seem dumb but here goes. I have a baofeng GM 15 Pro and I'm going through the menu and came across something called DIY I have no idea what it is or what to do with it. Please help, I think this could be a great hobby and I want to do things write and make some new friends along the way. I thank you all in advance for your time and wisdom. WSYI957,Piggl3t
  18. That's why we have 3 digit IDs that are sequential as you join the group.
  19. Welcome!
  20. Yesterday
  21. Hello all! New to GMRS, new to radio in general! I've got a couple of Baoefeng UV5G (PRO and PLUS) that I'm having fun learning how to use. Been working on pinging the repeaters for signal checks, but haven't heard back from the ether yet! I'll get there. Looking forward to learning this new mode of communication.
  22. It's not so much complaining, more sharing an opinion. It drives me nuts, too. Its actually a topic I cover briefly in all of my training classes.
  23. Sure...keep telling yourself that...while you're literally complaining about something that matters less than the color of your socks.
  24. WOW!!! Looks like some people could use a Snickers Bar about now. We can't blame it on people being cooped up in the house due to cold weather either. We aren't sticklers on the use of call signs on our repeater. You can either give your call sign at the beginning of your first transmission or at the end of your first transmission. I know the rules only state every 15 minutes and at the end of the conversation. But it's a curtesy to give it in the first transmission since we have a lot of people with the same names or they sound similar on the radio. It makes it easier to know who we are talking to. The only time we say anything about someone NOT using a call sign is if they are kerchunking the repeater. It' not hard to just say "your call sign testing". And if they want to give their call sign at the end of every transmission, we won't say much about that either. This is especially true if there are a few of us on the repeater talking as a group.. To each their own.
  25. Hello all, I have been in here for about a year. I enjoy all the discussions. Many have help greatly while others have left me in amazement. To clarify (not justify), this is a hobby and a tool at the same time. I interject humor because there far more things in this world to worry about. Therefore "don't sweat the small stuff". this is not a place to die on the cross. Sit back enjoy the conversations and learn a little along the way. I am as excited today as I was on 8/31/24 when I joined. Yeap, new to ya'll but not jaded yet but I do not believe I will become that way as a sense of humor wins. I ask that if you see a post from me which isn't polarized or even doesn't make sense, I would hope you would take a second to reevaluate your passion for the topic and learn what to let go....Justa sayin' WSEL330 - Former Jarhead
  26. I don't get it (sitting back nawing on crayons) Tick, tick...Am I a Retard or am I being controlled by the man, I mean the HAM...WOW, my life just shuttered like an old truck on ice. Man, this site is tipping my flat little world!
  27. I don't think it's comical or anything like the Jerry Springer garbage. I think it is a typical example of what the situation is here on the forum and on the air. We all have our opinions but nobody has any authority, so we deal with this anarchy. Some want to ignore rules that aren't enforced by the Feds. Others (repeater owners) want to make up their own rules with the idea they can enforce whatever restrictions they choose. Neither is good. I can just stick to simplex where I am the master of my domain and I do things my way within the Fed regs.
